Question about Whirlpool Duet GHW9150P Front Load Washer
Removed lint filter on model LHW0050PQ4 and it will not go back
I cannot get the lint filter to fit in the place from which it came...the rubber washer seems to big and no matter how hard I push it will not fit.
  • Shawn Smith May 11, 2010
    i need more information on what you have and what kind of lint filter this is where it goes ??
4 Suggested Answers
  • 6 Answers
SOURCE: I have a Whrilpool model LHW0050PQ4. Lights are blinking nonstop.
you need to turn off, unplug, plug back in, turn on, move cycle knob to stop, wait a few minutes, and then select cycle you desire, press start and hold handle firm against door 'till light stops blinking and it should go.
Posted on Jun 22, 2009
woodchuck789
  • 4070 Answers
SOURCE: I was washing wool that
The burning rubber smell is probably the belt. It is probably broken into. Remove the front of the washer on a top loader to access the belt at the bottom where the motor is.
Posted on Dec 29, 2010
TheMobilian
  • 8220 Answers
SOURCE: clothes from washer almost always have big pieces
The last time I saw one with this problem a lady had washed a big rug in there and the rubber backing came off. had to remove the pump and drain hoe to flush all of the junk out. Their is no filter on these machines.Remove the agitator and get the basket out. Then take the pump and drain hose out and flush out the junk. themobilian_2277.jpgthemobilian_10.jpegthemobilian_2278.jpgthemobilian_2280.jpg
How it works with manual HERE
More here
Posted on May 02, 2011
I have a lawn mower engine model 98963 type 9388 code 97698891 is there a filter inside the petrol tank ore where fitted motor starts then after short period cuts out appears not getting petrol
I have a 5hp B&S and was experiencing fuel leakage problems
when I pulled the hose of the tank fitting to fit a tap, I found a small filter up the tube and held in place by the rubber hose
IT is extremely fine and about 3 mm in dia so it is possible that you could have one and it is blocked
Jun 04, 2016 | Garden
How to remove back to fit battery
On some vehicles theres a tray that the battery sits on. These trays can be removed or the battery tie down bar can also be removed to fit the battery in place. If you are not able to place the tie down back in place you can use a bundgy cord to hold the battery in place. First you hook the cord into the vehicle before you place the in, make sure the hook part is not going to touch the battery bcaz it might puncture the battrry or wear a hole in the battery. So then u should make sure the strap or cord is not too lose and attach the other side so it will be safely secured in your vehicle. Preferably rubber, so if this helped you please give me credit for answering your question.
Nov 22, 2014 | Cars & Trucks
Fisher paykel repair manual
I think there are some letters missing from the model number you provided, so I am uanble to locate the specific dryer that you have. Generally you would squeeze the two buttons on the sides of the centre shaft of the lint filter and release after it has mounted into the dryer unit. That would clamp it to the centre mount. Hope this helps.
May 26, 2014 | Fisher and Paykel Dryers
CANT REATTACH INNER DOOR PANEL
sadly it sounds like a hands on problem and we do not make house calls . call local repair service
Aug 01, 2017 | Asko Dryers
I washed a rug and the backing came off. I beleive the filter is clogged, as it will no drain. How can I get to the filter
Without the model, I can't be sure, but here are some generic instructions that will probably help:
Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
OR
You will need to access the debris trap from the back of the machine. If there is no filter at the front, pull the machine out and you will see a roughly oval panel at the bottom of the rear of the machine. Unscrew the 3 or 4 screws and unclip. Directly below the drum, you will now see a rubber "Cup" like bulge in the black pipe, with a plastic tube connected to a plastic pipe. The cup is held in place by a large jubilee clip. Unscrew the clip, pull off the rubber boot to expose the debris trap (A conical plastic cage with a ping pong ball in it) Take out the ball and the plastic trap, clean out the debris and replace the trap and the ball (Note that the cage may have a slot in it that locates in the rubber boot, make sure it lines up, or it won't reassemble correctly). Now push the boot back onto the fitting at the bottom of the drum where it came from and tighten up the jubilee clip, making sure that it is fitted correctly (it too may have a small slot out of it that fits around a protrusion on the bottom of the housing).
Jul 19, 2011 | KitchenAid Washing Machines
The impeller on the drain pump came off the end of the shaft. It appears to be held in place by a friction fit over a rubber o-ring on the brass part that engages the impeller. Why would that part come off...
Hi from retired Englishman in SW France @ 20:22 Mon evening
For the time being I would just push it back on- quick fit!
It could have been moved by something going out in the drain water- a tooth pick or needle for instance which has managed to go through the lint tray/filter.
I am presuming you have the tray out to be able to see and fix the impeller.
If it comes off again a replacement pump would be the order of the day, methinks!
Good luck,
John C
Jan 31, 2011 | Maytag Neptune MAH6500A Front Load Washer
Do I need to clean the filter behind the lower front panel? I removed the panel but nothing in the owners manual that describes it. I heard that you need to do this every year or so for general...
Remove the lower kick plate. Unscrew the two screws holding the kick plate in place, and gently pull off to remove. The kick plate is the lower outside cover of the washing machine.
Place a small bucket under the white hose. Remove the cap on the white hose by untwisting it. Allow any remaining water in the hose to drain into the small bucket. There shouldn't be much water, but there can be some.
Look inside the white hose. Remove any visible obstructions or lint.
Look inside the hose cap. This is where the lint filter is. Remove any visible lint with your fingers. Rinse the hose cap under warm water to remove any remaining lint.
Twist the cap back onto the white hose. Put the kick plate back in place. Screw back on.
Oct 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
LG FRont Load Washer Dryer WD-1256RD filling up with lint
If you have not done it already, replace the lint filter. Follow instructions on manual. The lint filter access should be on front side of machine.
Other users had same problem on this model, I quote:
"I've only had it 2 weeks so far. It seems to be collecting lint/fluff all around the rubber door lining"
Source here.
Sometimes there may be too much lint if you use excessive softener and detergent.
Feb 08, 2009 | LG WD-12124RD Front Load Washer
Bosch WTL5400 Condensation Dryer
We continuously had a similar problem with signals forever coming on after just a few dryer loads. The problem was corrected when we took the back off of the dryer and cleaned the recirculating fan and removed a rubber glove that somehow came through the system and blocked the air flow at the heating element. Low air flow is the same as plugged filter and apparently the computer in our German-made Bosch dryer simply says that. We cleaned the area well, removed all traces of the glove and restored the dryer to operation. We have not had the filter problem since. We routinely clean the heater area at the back of the dryer to maintain our sanity. And we now dry our clothes. Bosch never responded to my query.
Dec 28, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
110 people viewed this question
Dan Webster
Dan Webster
Sal De
