Question about X-10 X10 Smart Repeater Remote Controls
My X10 Pro pool lighting controller worked for a while, then quit
My X10 was working great, after I had a bad pool light replaced (apparently this was causing the problem). Then, all of a sudden, it quit working completely. Sometimes I can turn on the pool lights at the panel, and then turn them off with my controller, but then nothing. I can plug in the controller into the GFI outlet inside my panel, and it works fine. Can anyone offer a suggestion?
Most likely the pool motor or other devices are making the powerline noisy. I suggest either getting an x 10 tester or unpluggin hosehold devices until you find teh source of the noise.
Stephen Lerouge
Home Automation Inc,
Southwest territory Manager
Posted on Mar 21, 2009
My pantair 720 prowler is not working. I have tried just about everything. The green light comes on for about 3-5 seconds and shuts off the unit.
unplug part that goes into pool plug in if it does the same bad control box if it works without unit in pool bad cable or inpool unit
Feb 21, 2013 | Pentair Prowler 720 Pool Cleaner
My pool light turns on by itself a lot. Almost every day. I don't have remote for it so I have to manually turn it off. What are the dials for? Can I disable the remote. I think a neighbor might be...
The dial with the letters is for setting the "house code". The dial with the numbers assigns a number for each controled device. If your neighbor's house code is the same as yours it is possible that their controller is tuning on your light. Change your house code to another number. Remember that all controllers and controlled devices must be on the same house code to work, so you have to change the house code on the remote also. If you don't want the remote to work just set it to a house code letter that is not being used by anything else. If you don't want the remote to work just for that device, just change the device number.
Jan 16, 2011 | X-10 X10 Pro PLW01 Standard Toggle Single...
My ice maker just quit working, I am still able to get water, so the line is not frozen. Any ideas
We just had to replace the entire control board to the tune of $318 (for service call, part, labor and tax). Our ice dispenser was working intermittently and the light was dim when it was not working. Apparently it was the board. After researching online a few other places there were also some other signs that it was going bad even before this.
Dec 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Pentair MiniMax NT pool heater not working
check breaker maybe popped check ignitor
Sep 29, 2017 | Pentair Minimax NT Heater
I have 2 of these installed on individual lights.
You can use the PHR03 wireless RF remote control or the PHR04 (key chain) both of which also _require_ the X10 pro transciever (PAT 01):
http://www.thehomeautomationstore.com/x10prowirelessremotes.html
You can also use the PMC01 Mini controller:
http://www.thehomeautomationstore.com/pmc01.html
You can also use the PHC02 Pro maxi controller:
http://www.thehomeautomationstore.com/phc02.html
Warning! This stuff is addicting :-)
Dec 10, 2009 | X-10 X10 Pro PLW01 Standard Toggle Single...
We have a Cadence 825 treadmill and the display has quit working. How do we fix it?
either the console is bad (which is no longer available) or the control pwb is bad (available for $114 on iconservice.com) Check for power to the controller. Red light should be on. (you must remove the hood cover 4 screws 2 on the sides and 2 in the rear) If light is on the controller then more than likely you have a bad cosole as I said it is apparently no longer available.
Nov 09, 2009 | Cadence Weslo 825 Treadmill Walking Belt
Hayward Colorlogic Light flashes like a strobe
OK I GUESS U HAVE A AUTHOMATIC CONTROL CHECK T RELAY FOR 120 V THAN CHECK FOR V AT THE JUCTION BOX IF V LIGHT MUST BE REPLACE.
Jul 07, 2009 | Hayward 12v LED Color Logic Pool Light...
Hayward HeatPro Heat Pump for pool won't turn on
Power to the unit but not the display + mice = bad board probably. Service call required...
May 27, 2009 | Hayward 116k BTU HeatPro Digital Heat Pump...
X10 switch paddle problems
please change switch and stop hitting it most likley is a short or bad connection could start fire
Jan 31, 2009 | X-10 X10 Pro PLW01 Standard Toggle Single...
X-10 X10 Smart Repeater Remote Controls Logo
1,175 people viewed this question
Top X-10 Televison & Video Experts
Electro Med Services...
Are you a X-10 Televison and Video Expert? Answer questions, earn points and help others
