Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
A pop and motor quit
Motor was running then i heard a pop and it quit? waht should i check?
    President:
  • 267 Answers
MOTOR IS BURNED OUT nothing you can do this was the problem with this mixer for years , then it was the worm gear problem now we are back to the motor poping . you cannot get the motor for a self install and if you send it to kitchenaid it will cost you mre than a new mixer on sale ........... look up reviews on the net , look for the ones that have had the mixer for a while . you will see your problem is common . good luck to you
Posted on Jan 15, 2009
Tripped circuit & heard pop on KA Artisan Mixer #RRK150 while using pasta press attachment. Now doesn't run. Fixable OR replace?
probably fixable. The load of the pasta press may have blown an internal fuse or overheat thermostat, taking the breaker with it. Open it up and take a look.
Kitchen Aid Artisan Mixer RRK150 spares Google Search
Apr 23, 2017 | Food Mixers
Kitchenaid kp26m1xer won't turn on
If the mixer died completely and no noise at all comes from the machine you need one of three things.
1. New brushes2. new speed control switch3. a new motor.
The KP26 is a 6 quart mixer of the new design, post 2002, it is easy to work on and relatively inexpensive for parts if it turns out to be the motor that will be about $100.00, the speed control about 30.00, the brushes on this mixer cannot be replaced you have to install a new motor, sry about that. Hope this helps let us know. But first check that the electric outlet you are working from has not tripped the breaker on the circuit too. I know I know it's silly to say but check the outlet first before you spend a dime on anything.
Mar 11, 2013 | KitchenAid 32685 Mixer
Killed my mom's mixer on accident and was planning on taking it part to see if I can fix it. only problem is I cant get the dang thing open. can anyone help, please?
It also has snaps that have to be popped loose in order to separate the bottom from the top it takes some force here. Even after the screws are out
Apr 07, 2012 | Kenmore KSM035 Stand Mixer
Mixer motor quit.
I think that the motor is still fine. Get a Copy of the Repair Part List from Kitchenaid.com.
First thing I would do is to check the two Motor Brushes (one on each
side of the Motor Housing). Make sure they are not worn out, and when
inserted, they must both make contact with the Motor Coils. If even
one of them is not in contact with the coils, the motor will not run.
You can also remove the Motor Housing and visually verify that they
are touching the Coils.
Jul 31, 2011 | KitchenAid K45SS Classic Stand Mixer
Mixer is still going but making a popping noise. Also has a burning smell - maybe a wiring problem?
HI.When the stand mixer produces a popping sound during mixing this problem has something to do with the motor.Motor has bossing on it.This might not be lubricated well and eventually lossen up.That's why it produces a popping sound.And with regard to the burnt smell might be on the coil of the motor's rotor or armature.Is the unit still functioning eventhough you smeeell burnt wire?Thank you for choosing FIXYA..
Jul 22, 2011 | Kenwood KM305 Stand Mixer
Mixer will not run, was runing last time used.
Did anything pop? Or did it just quit? I need the model.
Feb 16, 2011 | KitchenAid Classic Stand Mixer
Runs wide open then quits
Looking at the parts list:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208204551.pdf
find item 9. It is a hall effect sensor which measures the speed of the motor and feeds back that info to the controller - if it is open or shorted the motor will not be controlled and will either not run at all or run wide open.
Mar 24, 2010 | KitchenAid KV25G0X Stand Mixer
Motor runs, beater stopped rotating. Some gear sounds heard before it stopped. Beater will not turn at any speed setting.
drive gear or shear pin stripped. Common on this model. Return to repair centre. Expect to pay approx $150.00 to repair, sorry.
Sep 14, 2009 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
112 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
