Question about Toshiba 35A44 35" TV
Bad tactile switches on Toshiba 35A44 35" tv
Is this problem fixable at home?
  • JOhn Clauss Jun 13, 2007
    It started with the tv switching from tv mode to vid 1 vid 2 vid 3 back to tv. Now that occurs but also it cycles through the set up menus making it tough to watch
    President:
  • 3,130 Answers
I would repair this set in the house, yes! That set is a big old monster to carry around. The tech probably wants to take the set to the shop because they make more money that way. How do you know the tact switches are bad? What are the symptoms of this TV set?
Posted on Jun 13, 2007
What is the board called that turns it on/off and controls all display functions and where can i find a replacement board. the on/off switch on it is bad
Is the TACTILE Momentary switch really bad (no clicking feel to it?)
The board is called Function switch PCB aseembly. You may be able to find the switch at WWW.MOUSER.COM, WWW.DIGIKEY.COM
You can try looking for PCB assemblies on EBAY.
What is the symptom anyway?
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Oct 25, 2010 | Proview PL926WBi 19" LCD Monitor
Power button doesn't work
Not very likely to be the switch itself, the switch is a tactile momentary switch, more likely to have failed power supply due to bad caps just like the rest of failed monitors here, check to see if your adapter is putting out 12vdc, then we need to find out if it is getting 12vdc all the way to the main board and the inverter board:
Sep 03, 2010 | HP Compaq 1720 (Carbon, Silver) 17" LCD...
Menu Screen turns on/off on its own...alsoTv video flips through
The front panel Tactile Switches need to be replaced. Replace them all. This should be the part #. 23344507. You can order it through Encompass Elect. 800-638-3328.
Hope this helps,
Skyassoc
Jul 01, 2009 | Toshiba 32AF43 32" TV
Same Problem
The front panel Tactile Switches need to be replaced. the Part # of the switches is
23344507. You can get from Encompass Elect. at 800-638-3328.
Hope this helps,
Skyassoc
Jun 29, 2009 | Toshiba 36A43 36" TV
I was watching tv when suddenly the volume control indicator bar showed up and started going up and then down and the remote will not operate the tv. the set it self will allow me to change channels and...
The front panel Tactile Switches probably need to be replaced. The part # of the switches is 23344507. You can order them through Encompass Elect. 800-638-3328.
Hope this helps,
Skyassoc
Jun 26, 2009 | Toshiba 36A43 36" TV
Toshiba television will change from tv/video mode to
I would check to see if the Input button is stuck on the front panel of TV. If it is not stuck then it is probably still bad. Tactile switches are notorious for failing in this manor. The only real fix if it is not stuck down is replacing the switch.
I hope this helps,
Skyassoc
Jun 22, 2009 | Toshiba 36A43 36" TV
My 32"toshiba keeps changing from tv ,to video 1, to video 2
It's one or more tactile switches are leaking...
Bill
Jan 04, 2009 | Toshiba 32A33 32" TV
Black lines and menu problem
Check for bad caps in vertical circuit. Solder any/all bad connects. REPLACE vertical o/p IC w/OEM or better quality. I usually use Tosh,Hit,or Pana. 2)Check/replace tactil switch (menu)on front panel.
Sep 28, 2007 | Toshiba TZ50V61 50" Rear Projection...
What do I do for tv switching from tv to various video modes and cycling through set up screens
the tactile switches on the control panel cause this problem . they could'be stuck or have some kind of contamination like liquid. or just bad . cost to repair aroud 60.00 dls if this helps please let me know
Jun 12, 2007 | Toshiba 35A44 35" TV
Toshiba 42H82 remote problem
Bad volume down tactil switch? Remove suspect switch and see----
May 29, 2007 | Toshiba 42H82 42" Rear Projection...
Toshiba 35A44 35" TV Logo
138 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
