I have an Amana model number pgb 30c09020. It quit working about a month ago and if you pushed on the fan on the combustion blower, it would come on and work for a while. They got the code and replaced the combustion blower. It worked a week or two and then it started going off. When it gets to the temperature, it kicks off and will not come back on. If you flip the breaker off and back on, it will come on. Also, if you leave the door off the flame will stay lit. If you put the door back on it, the flame will go off.
Since everything seems to work when the door is open is an indication that the inlet air filter if blocked. Remove filter and clean it with a vaccum cleaner. IF the filter is clean check that the air inlet itself is not blocked by a peice of furniture that has been repositioned etc
My 4yr old Amana heat pump quit working - the thermostat display was blank. I replaced the...
(More)
My 4yr old Amana heat pump quit working - the thermostat display was blank. I replaced the thermostat but still no luck after confirming it was installed correctly. My S/N is 0407477962, Model VNC60C2A, P/N247407C. I was told it was a 12 Seer unit; unfortunately I can't find my manual or find it listed on your website. Any assistance would be greatly appreciated.
Is there such thing like a kit to convert amana ptac wall unit to work on my existing hard wire wall...
(More)
Is there such thing like a kit to convert amana ptac wall unit to work on my existing hard wire wall thermostat?
