Question about Alert ALRCST25M 25' Extension Cord with Circuit Breaker
Problem extension cord????
When I puged in my orbital sander it worked for a minute and then stoped. I tried another sander and it also stoped after about 30 secounds. I tryed them on another outlet but they have stoped working.I'am afraid to try any other tool with this extension cord.
    Sergeant:
  • 359 Answers
THESE ARE ALL MOTOR LOADS OR INDUCTIVE LOADS AS SOME WOULD SAY , TRY THIS GET A STANDARD DROP LIGHT OR LAMP AND PLUG IN THIS IS A RESISTIVE LOAD AND FAR LESS SUSCEPTIBLE IF THE LAMP DOES NOT BLOW THEN NOTHING WRONG WITH CORD OR VOLTAGE
Posted on Jan 14, 2009
Ryobi problems
This is not that bad of a problem we should be able to resolve this-
bring a lamp or radio which ever one you have used and know it works plug it into the wall outlet if your lamp or radio work then we know its the plug, now plug in yr Ryobi random orbital sander it should work to do not involve an extension cord while we are trouble shooting if neither have worked on the same plug you must have a 3 way light switch on the wall that needs to be turned on, try and slightly spread the the metal blades on yr Ryobi outward for a better contact between cord blades and wall plug make sure you have firmly pressed in the the on off switch.
Ryobi tests all of its factory reconditioned power tools before they are sent back to be sold in stores to the public...
Aug 10, 2014 | Ryobi Factory Reconditioned ZRRS290 2.6...
Oscillating drum sander runs a few minutes and stops
This usually occurs if the motor is overheating and the internal circuit breaker is tripping. After it cools down, it self resets. This can be caused by bad bearings or parts dragging the motor down, making it work hard enough to over heat and trip the breaker. If you are running it on an extension cord or circuit that isn't able to provide it with the amps it needs the motor will overheat and trip the breaker also.
Dec 02, 2012 | Delta 17-960 Oscillating Spindle Sander...
I am using a Model 343 type 2 Porter Cable random orbital sander. It worked just fine, I turned it off, and 20 minutes later it would not turn back on. No strange noises, smells, etc. it just wouldn't...
Plug in the sander, Turn it on and Wiggle the wire around the plug. If your sander jumps on and off your plug need to be replaced.This should be a easy fix if you are a bit mechanically inclined. If that doesn't work, get a ohm meter and see if your cord is hooped. If cord is fine then look at the brushes.
Jan 10, 2011 | Porter Cable Tools & Hardware - Others
HOW DOES IT WORK WITH NO CORD???
If the product your have this listed under is correct then you need to hook up an air hose to this sander to make it work...it works on compressed air...
heatman101
Aug 21, 2010 | Chicago Pneumatic Cp7200s Mini Random...
Dewalt d26451 type 1 random orbital sander. why does this sander jump around on the material and feel like it's fighting me all the time instead of sanding smooth and easy?
I have the same problem with a Porter Cable orbital sander I recently purchased. Whats happening is the sander is catching the edge of the board you're trying to sand and jerking back and forth as the sander base spins. It seems that if the board your're sanding is at least as wide as the sander base, the problem goes away, which does little good because there will be many times I we'll need to sand wood that is less in size. But you may try using a lesser grit sandpaper and see if that alleviates the problem somewhat.
Aug 10, 2010 | Dewalt Heavy - Duty 5" Random Orbit Sander...
The floor sander will work for a few seconds then cuts out. this is the second sander where this has occured, we have tried running extension cords to other outlets/ laundry hookups also
its not getting enough amperage. poor wiring or thin extension cords will cause this. make sure you use a thick cord that is rated high enough to supply the sander.
Aug 08, 2009 | Tools & Hardware - Others
Orbital sander doesnt orbit!
Never start the Sander without first placing it against the surface to be sanded. In free air the Sander will not osolate.
Jun 12, 2009 | Makita BO5010 5" Random Orbit Sander
Orbital sander
You should really take it back to place of purchase and get it replaced/fixed under waranty. If you try anything other than checking the fuse you will invalidate the warranty. Most manufacturers allow retailers to replace faulty tools within seven days of purchase. Be sure to take your receipt with you as a copy will be needed for the shops warranty claim.
Sep 23, 2008 | Bosch Power Tools Sanders Orbital Sanders
Alert ALRCST25M 25' Extension Cord with Circuit Breaker Logo
64 people viewed this question
Top Alert Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Alert Electrical Supply Expert? Answer questions, earn points and help others
