Question about Philips Magnavox 27MS343S 27" TV
Screen went to a 4 inch pic in the center of screen, then total black. All other functions work, just no pic
    Scholar:
    New Friend:
  • 70 Answers
If the picture shrink into the center of the screen about 4inch then goes blank. you do have problem with your vertical drive IC, it's either loose contact with the board or the vertical IC already malfunction.
Posted on Jan 16, 2009
My Samsung TV has lost the picture The pic went to very dark then went total black (no pic) Model #un40h5201afxz serial o2zv3cufbo43iw
Hello? there could be 2 issues with your set. 1 could be the screen is damaged and most likely its the t-con or 2 could be that the power inverter section that lights the screen is damaged. Number 2 is the most likely problem. The circuit board that connects to the inverter has components that are damaged.
Nov 15, 2016 | Samsung Televison & Video
Sony liquid crystal tv, was watching show then heard loud pop and tv went black but looks on. No pic or sound. has power but cant control tv at all. Complete silence and black screen.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
May 14, 2015 | Sony new bravia s-series 40-inch 1080p lcd...
I just bought a 23 in. hp monitor and i can not get the picture to fit the screen. vertical is fine but the horizontal will not go over. there is about an inch of black on left and 2 or 3 on right side,...
it is a lcd or crt moniter specify that first
if its lcd check the resolution copatiblity of your video card
it may not match the resolution of the lcd
if it is crt then there will be a control panel setting on the monitor
Dec 26, 2009 | Computers & Internet
61" tv quit working
This is a strange problem , but it sounds like you got a broken mirror.take the front (fresnel,lens) off and you`ll find out.
Nov 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Black box taking up over 1/2 the screen.
caption box selection is on. disable caption
Jun 29, 2009 | JVC AV-27530 27" TV
Black screen on EVERY input/channel
Turn off the closed capition
Jun 19, 2009 | JVC AV-27530 27" TV
Picture not centered on my philips 47'' lcd tv
NOTE:(Edited and copied from another thread on Fixya.com, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD
By dmorrow54 on Nov 13, 2007
Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
Guest
  • Rank: Guide
  • Rating: 0%, 0 Votes
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Add a comment
    • c7carl
    • 5 minutes ago
    WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
    Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
    Comment:
Feb 05, 2009 | Philips 47PFL5603D 47 in. LCD HDTV
Philips plasma tv vertical black stripe
Ok did this happen the first time u turn on the TV. ? If so u might have a ribbon cable disconnect from the logic or u might have a defective Plasma panel. If u have a defect like your describing the IC's on the panel short out and no longer work causing that section of the screen not to function. Only fix then is replace panel
Apr 26, 2008 | Philips 42PF9630A 42 in. Plasma Television
DELL 42 inch Plasma TV
I have a 42" LG LCD TV and just experienced this today. Watching cable, then the screen went to black, but audio continued. I pressed the guide button on my remote and pic came on with my guide menu. But then went to black again 10sec later and has remained that way for nearly an hour. Tried switching off both cable box and TV, disconnecting and reconnecting cables, but no luck. Finally unplugged mains, waited a minute, then turned back on. Everything seems normal now after the reboot. Phew.
Jan 17, 2008 | Sony KV-36XBR450 36" TV
Picture is not centered on monitor leaving a 2 1/2" black border on Philips LCD
Nov 13, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips Magnavox 27MS343S 27" TV Logo
60 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
