Question about Pioneer SD-533HD5 53" Rear Projection HDTV
Fuse keeps blowing
Our television suddenly stopped the other day. I replaced the fuse and it keeps blowing when you attempt to turn the set on. Is it worth trying to fix or time to dump it? I'd like to attempt to fix it myself, I'm fairly familiar with it - I replaced the IC's about 6 months ago. I've asked around for names of those who repair, but even a friend who works at an electronics store said there's no one around here who messes with them anymore. Any suggestions?
    New Friend:
  • 40 Answers
It might be worth fixing but you will have to call a tech out to give you and estimate. When the fuse keeps blowing that means it is drawing to much current so it could be the power supply and that might not be that expensive. You best option is contacting pioneer and asking them where the closest authorized service center is.
Posted on Jun 13, 2007
PA Amplifier blows fuses
The fuse is blowing due to an overload. It's often and very likely caused by a transistor or ic that has gone short. The main culprits are the power transistors of the amp or whatever is on the big heat sink. Transistors will show the fault when you connect an ohmmeter to the terminals. It will be just like you have touched the test prods together! I don't think in your case it will be in the power supply. It's often caused by speaker cables that touch together.
Mar 18, 2014 | Radio Shack Audio Players & Recorders
Blowing fuse on tv
hi there's dead short in the power supply somewhere could be a number of components usually diodes or transistors cause this fault
hope it helps
regards
shaun
Jan 04, 2014 | Magnavox 32MF301B/F7 32 in. LCD TV
Signal light fuse keeps blowing
the fuse stopped the fire. that is what fuses do.
so, you have a dead short on the blinkers.
remove each lamp 1 at a time.
yes, lamps can short. (twisted too hard)
remove them.
still blow the blinker fuse.?
yes, then the wires are shorted.
and guess what, top reasons are.
1: trailer wiring, look behind each lap assembly, BINGO?
2: hacking or collision, yes, look 1 more time. ,yes behind the lamp assembles, look carefully for DAMAGE.
Aug 05, 2013 | Suzuki Jimny Cars & Trucks
My HD rear projection television keeps blowing a fuse. Everything was working well last night then it blew the fuse I replaced it and it blew again.
On these sets if you replace a fuse either you have a short OR the fuse is a generic one------replacement fuses from say Radio Shack will even if correct amperage and voltage blow for no reason-----most of the fuses in these sets are actually thermal or slow blow types.
With the set unplugged take a meter and check both sides of the fuse to ground in the set. If the fuse that is blowing at once is the one connected to the power cord it is likely incorrect fuse or generic junk fuse was used to replace it.
Dec 03, 2011 | Pioneer PRO-520HD 53" Rear Projection...
ATTn SD Tech: my 65" Mitsubishi keeps blowing the
1,2 means no error found. To confirm turn set off and unplug and and turn back on, when it fails try the self check again.
Where did you buy the replacement fuses? Radio Shack?
Some of these fuses are special and the poor ones which are generic will pop for no reason sometimes; examine original fuse and holder for correct amperage and type of fuse used.
sd tech
Sep 09, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Black screen no video no audio suddenly now
This set is a 50" plasma. first check the AC power fuse on the filter board then: if it is bad: check the power supply by marking and, removing all the cables; (so you can put them back in the correct spot) except the filter board to power supply cable; that connects to the Power supply board. Then: replace the blown AC fuse and, re-power: If the power supply blows the fuse: again, the power supply is bad and, must be replaced or, repaired. If the fuse does not blow: turn off the set then: on again, reconnecting and, disconnecting each board cable in turn, untill the fuse blows again this cable leads to the bad board; replace or, repair the board that blows the AC fuse every time the bad board is connected, irregardless of which other cable to the power supply may be connected also; or, not.
Jun 05, 2010 | Toshiba 50HP66 50 in. Plasma Television
RCA 52" TV stopped working
It could be the problem or just a symptom of the problem. If the fuse is replaced and blows, then it's something else. Hopefully it's just the fuse. Good luck!
Mar 07, 2010 | Televison & Video
Fuse keeps popping - 20A ENG CONT 1
Before replacing fuses try disconnecting neg battery lead first. If still blows look loose wire under motor
Dec 14, 2017 | 2000 Nissan Maxima
Fuse F3701 is blow-up after few munites turns on. If replace a fuse F3701 again, it work, but the set turns of any time, check the set: Fuse F3701 is blow again?
Look at the power board " the one with the fuse" for capacitors that look puffed at the top or leaking at the bottom. If these are leaky the voltage drop will cause the current to rise and pop the fuse. After a time the caps will get bad enough that the set will stop working and may cause more problems.
Apr 16, 2008 | Sharp Aquos LC-20B2U 20 in. LCD Television
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
