Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Can't get Domino keyless entry pad to work
I have a domino keyless entry pad that was working fine (7 years old), then was getting finicky for a couple of weeks, and now just stopped working tonight. The keypad was lighting up but I went ahead and replaced the batteries anyway. I follow the simple steps to program in a new code but when I switched the button back to operate (from program) it does not trigger the door to open or close. I noticed that sometimes when I push a button it does not light up unless push harder or multiple times.
I should add that the garage door works fine from the button inside the garage or from our vehicles. Do I need to replace the pad? Thanks for any help you can offer.
    Champion:
  • 244 Answers
Call Domino. Sounds like button on pad worn out. Confirm by trying new code with ALL FOUR numbers different. If it works, you can just change you code. If you have patience, find the bad button , ie: If code were 6529, try 6666 and see if it works. If not, 6 is 6. If yes, try 5555. You get the idea.
Posted on Jan 14, 2009
Rpm up down
its normal for rpm to be up when engine is cold,then drop after engine is warm.If to low it could be you throttle posistion sensor giving you the fits
Nov 11, 2013 | Domino Engineering Garage keyless entry...
How many dominoes are in the longest domino line?
I found a video that has a domino line with 4,400 dominoes!!!
check it out here: http://www.youtube.com/watch?v=vDy2xWpZWVc
Feb 20, 2013 | Games
The keyless entry pad on my 2007 Lincoln MKX just quite working all of a sudden. All but one of the buttons illuminates when pressed. The auto unlock button on my key works fine. Any ideas? Thanks!
This should still be covered on your 4/50 warranty. It osunds like a bad keypad. Dealer can pull fault codes with scanner. Do you have ESP cintract also for more years and miles coverage?
  • The keyless entry keypad illumination is inoperative
  • Circuitry
  • Keyless entry keypad
  • SJB
Aug 03, 2011 | 2007 Lincoln MKZ
I have a chamberlain garge door opener and I bought a genie intellicode outside remote access and can't get them to work together.
They will not work together. You need to get the keyless entry for your chamberlain garage door opener. Or got a wired system gd-1 from Domino
Oct 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Lotus mail client
clear.gif To configure the Lotus Notes client
  1. Click Start, point to All Programs, point to Lotus Applications, and then click Lotus Notes. Because this is the first time you have run Lotus Notes, the Lotus Notes Client Configuration Wizard starts. Click Next.
  2. On the Welcome page, click Next.
  3. When prompted, type in the name you set up for the user ID for Exchange Connector for Lotus Notes and enter the name of the user's home/mail Domino server. Select I want to connect to a Domino server. Click Next.
  4. On the How Do You Want to Connect to a Domino Server page, select Set up a connection to a local area network (LAN), and then click Next.
  5. On the Domino Server Network Information page, in the Domino server name text box, type the name of the Lotus Domino server that will act as a bridgehead between Exchange Server 2003 and Lotus Domino. In the Please provide specific network information to help locate this server dialog box, select TCP/IP. In the Server address field, type the hostname or IP address for the Domino server listed above, and then click Next. This server should be the one that you configured earlier.
  6. When asked if you want the User ID file copied to your data directory, click Yes.
  7. Type in the password for the user ID file.
  8. If prompted to set up Instant Messaging, clear the Setup instant messaging check box, and then click Next.
  9. On the Additional Services page, click Next.
  10. You will receive a message that indicates that Notes setup is complete. Click OK.
  11. Verify that the selected location is set to Office (should be displayed in the lower-right corner of the Notes client). If not, select the name displayed there and then choose the Office location.
  12. Exit Lotus Notes.
Mar 28, 2009 | Intel Motherboard
Outside garage door key pad will not function in very cold weathe
Yes, that is an issue.  My suggestion is to replace the outside keyless with a wired keyless (Domino GD-1).  This will get your batteries inside so they can stay warm.
Dec 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Programming my keyless entry
Yes, you purchased the wrong wireless. You must get a Genie keyless and there are two types of Genie keyless (GWKP & GWK-BL) depending on which Genie operator you have. You might think about a wired keyless entry (Domino GD-1). Then if you change your operator you don't have to change your keyless.
Nov 09, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Keyless entry pad for garage door opener
THE FREQUENCY OF THE UNITS ARE PROBABLY NOT COMPATABLE THEY CHANGED ABOUT 2 YEARS AGO.
SORRY - I THINK YOU NEED A NEW KEYPAD TO GO WITH THE NEW OPENER.
Oct 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Hotsync Outlook with domino connector?
It's probably looking for names.nsf on your pc. Try c:\lotus\notes\data\names.nsf or search for it. The fact that it can sync email without error tells me that it's NOT looking for your id file (name.id). There's a slight chance that it's looking for your notes.ini file (c:\lotus\notes\notes.ini) on your pc.
Sep 11, 2005 | Palm Treo 650 Handheld
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
408 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
