Question about SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue
320 GB simpletech external hardrive won't turn on.
I connected it to my PC. I had important files on it and I need to access it, however, it won't power up. There is absolutely no sign that its turning on. I need expert advise. Thanks a lot!!!
  • marty_bass Jan 31, 2009
    I can hear the drive spin up. After a few seconds it appears to be powered down, but the blue power LED is still on. Computer never sees the drive. Tried SimpleTech online support; no response. Called and gave information. Was tolded I would receive an RMA. Still waiting after 1 week. I'll never by from this company again. At least support for WD and Seagate was always good.
  • RosnSC Feb 02, 2009
    Mine was working just fine, but now it won't power on. I have even tried using different electrical outlets, as well as different usb jacks on my computer, and nothing happens.
I have the same simpletech hard drive and the same problem. Since I doubted it was under warranty, I took the case off.
I'm not a tech so I don't know the specific names of the parts of the hard drive. Anyway, there are two circuit boards. I jiggled the smaller one (which is the one that is directly hooked to the usb.) I think it must have been loose because the hard drive appeared on my laptop, and I was able to access my files.
I won't recommend others to do what I did, because I'm not a tech. But it worked for me.
Posted on Feb 12, 2009
  • ge205 Feb 12, 2009
    I forgot to mention that the two circuit boards are hooked up together, and I believe the two boards were not tighted sufficiently.
I have a Simple Tech (simple Drive) 320GB external hard drive.the light comes on But my computer won`t recognize it. The light comes on but that`s it.
Try connecting the drive to a different computer, to see if your computer is the problem.
If necessary, open the external case, and separate the disk-drive from the USB-to-disk-drive adapter.
Connect the disk-drive as a "slave" disk-drive in some computer, to see if the disk-drive itself still can be accessed.
If not, and you have "important" data on the disk-drive, search the Internet for a professional "Data Recovery Service" -- you ship your disk-drive to them, pay them a lot of money, and they repair the disk-drive, just long-enough to copy your files to a brand-new disk-drive.
Jun 12, 2010 | SimpleTech 320GB SimpleDrive External by...
My simpletech 500 GB model no. 96300-41001-133, has just stopped working. My pc can't detect it, it just turns on and the hardrive starts stuttering almost like a bad engine. I don't know what do with...
Hello there...
Looks like your HDD is having mechanical problem, this could happen due to a shock (dropped or bumped maybe?) which can cause your HDD I/O head loose from its track.
My advice is start backup you important data when you can access you HDD and prepare a HDD replacement.
hope that helps... :D
Apr 14, 2010 | SimpleTech SimpleDrive Pininfarina 500GB...
I have a SimpleTech 320 GB external hard drive. It suddenly stopped appearing in My Computer. When I turn it on, it makes a repetitive sound that seems like a warning of some kind...what is it? It sounds...
Hello and welcome to the TSF. If the external drive has provisions for external power you'll need to plug that in, usb ports cannot power a 320 drive. If the drive has 2 usb plugs (one for additional power) you'll need them both plugged in, and I would suggest that the laptop should also be running off of external power rather than battery. If you disconnect the usb drive or any other usb device without first stopping the device then sometimes the usb ports will fail to recognize the device when it is plugged back in, a simple reboot should do the trick. You can also check in the device manager for any yellow exclamation marks on your usb host conrtoller and see if the driver for it is in need of an update.
Any drivers you need should be on simpletech's website, though normally you should not need any for a usb hdd. If the power cord/a/c adaptor is faulty or the hdd is loose in the enclosure(thus not making good contact) then you should pester simpletech to either replace the cord, a/c adaptor,or unit, and see if there are instructions on how to take apart the enclosure and reseat the drive/connections.
__________________
Nov 07, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Simple tech drive
Using this program http://www.ridgecrop.demon.co.uk/dow...at32format.zip
Its worked perfectly on my 300GB usb drive, my PS3 can see it just fine
Oh and it works on vista as thats what i did it on..
Aug 01, 2009 | SimpleTech 320GB SimpleDrive External by...
Simpletech 320 gb
It has to do with the way computers count. Computers count in binary where we count in decimal.
Hard drive makers list there drives capacities in the decimal format, where windows lists it in it's binary format.
Wikipedia has a good explanation.
Also, the drive may have some preinstalled software on it that could be taking up a bit of space (it's usually not much).
May 15, 2008 | SimpleTech 320GB SimpleDrive External by...
SimpleTech 320 gb. Code 10 Problem
i doubt you can do anything about it. Code 10 is a hardware failure, so you will have to return it and get your warrenty.
Apr 28, 2008 | SimpleTech 320GB SimpleDrive External by...
Simpletech 320 GB
my advice to you is open it and unplug the one touch button.
Jan 11, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue Logo
171 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
