Question about Jenn-Air JES9750BAS Stainless Steel Electric Kitchen Range
Need to know where vent is on model jes9750bas jenn air stove
Need installation instructions
  • 8,197 Answers
Most of my controls on the touchpad work and a few have stopped workin. More options, clean, set up and vent do not work. Why?
I have the exact same problem. Don't know if it is the keypad or electronic control board. I have mine apart and am trying to diagnosis the keyboard
Feb 05, 2014 | Jenn-Air JES9750BAS Stainless Steel...
I have a GE XL44 that I inherited in my new house. For some reason that I cannot figure out, the previous homeowner cut a circular hole in the floor below the stove and ran a vent line (looks like a six...
It is possible that a down draft venting stove such as a Jenn-Air could have been previously installed and now there is this stove that doesn't need this vent system.
Dec 02, 2012 | GE Kitchen Ranges
The Grill side on my electric cooktop doesnt seem heat up enough
I had the same problem with the 45" Jenn Air downdraft cook top. The installation of the ductwork from the stove to the outside of the house was not properly installed. The stove is appr 18' from an outside wall and the flow of air was hampered by
too great a bend in the ductwork at the point below the stove on the underside of the house and the pipe going to the outside wall. I believe that was corrected with more curve in the vent work, making for a smoother flow of air. Make sense?
Jan 07, 2010 | Jenn-Air JED8230 Electric Cooktop
Does anyone know where i can get an instruction on how to replace the touchpad on a Jenn Air JGS8850BDS gas range/stove? hhkk_kh@yahoo.com
I just replaced the panel overlay on my stove and that did fix the problem (of the 3,6,9 buttons not working). I found the part for under $110 on line and replaced it myself.
Nov 05, 2009 | Jenn-Air JGS8850BDS Stainless steel Gas...
We have new house and have cold air coming from Jenn-air vent. What can be done to stop this? We had a Jenn-air in our previous home and did not have this trouble
Most stove vents have a diverter plate which prevents air from coming in. When the fan is turned on, this diverter is opened by the air flow and allows the air to flow through. It sounds like this plate is either stuck or was not installed when the ventilation duct was installed.
Oct 16, 2009 | Jenn-Air JED8430 Electric Cooktop
How can a Jenn-Air down draft stove be vented out the roof ?
Yes , its much more labor intense but it can be done by venting it up through the wall then through the attic over to the side vents. Make sure to get flexable duct to pull up through the wall.
Phil
Apr 10, 2009 | Jenn-Air JDS9860A Dual Fuel (Electric and...
Hello-I am being given a Jenn-Air electric range soon. My current electric stove just has the vent pipe coming up under a back element. Will I need to vent the Jenn-air to the outside? I have an...
Yes the ductless fan will work for you. I have that setup here at my house. Just make sure that you have a charcoal filter installed in the microwave where the air comes out on top. If it is already vent less the filter is probably already there.
Good Luck and Please Rate FixYa!
Mar 03, 2009 | Jenn-Air SVE47100 Slide-In Electric...
I have a Jenn-air electric stove model S125, which is about 20 yrs old. Lately, the ventilation system quits after about 25 minutes. I usually turn it on manually, but it goes on automatically during...
The answer your provided by email only confirmed what I suspected -- that the vent system was probably overheating and would cut out at a certain point.
Thank you for fast reply. I may have to get a pro to confirm this, as I'm an old lady with NO skills for taking stove apart and installing new vent motor.
Dec 29, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air Downdraft ducting roof Rack w/flapper
go to www.luxurymetals.com
there are many good high quality vents on the site
Oct 08, 2008 | Jenn-Air HV363 Kitchen Hood
Installation of down-draft exhaust duct for Jenn-Aire cook top
We're buying a JES9900BAF for an island and found ducting instructions in the installation guide. Go to jennair.com and find the page for your range model. Then click on the "Specs/Literature" tab (it's about 2/3 down the page). The installation guide is a PDF document.
Nov 07, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn-Air JES9750BAS Stainless Steel Electric Kitchen Range Logo
170 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
