Question about Lexmark P4350 All-In-One InkJet Printer
Can't send a fax.
I have internet thru a satellite instead of direct dial, how do I get a fax to go thru? I have the Lexmark P4350 printer. I get the fax info and forms up but it just keeps coming back as failed and retrying. I am not very computer savy so need help with this. Thanks.
  • 80 Answers
You need to have a phone line not just internet connection to send a fax. Unless you have an account with a fax to email company. So you need to hook your fax machine up to your already exsisting phone line, get a seperate phone number for fax purposes or serch the internet for a fax via email company.
Posted on Jan 14, 2009
SOURCE:
How to connect lexmark p4350 to laptop with radio link
The Lexmark P4350 printer is not capable of wireless connection. Try to use a wireless print server instead for wireless network connection.
Jul 06, 2011 | Lexmark P4350 All-In-One InkJet Printer
HOW TO SET UP MY FAX MACHINE ON MY LEXMARK X 3500-4500 SERIAL# 08339128730 2007/08 MY E-MAIL ADDRESSIS [email protected] CAN NOT FIND INSTRUCTIONS IN MY MANUAL PLEASE HELP WILLIAM
There is no Fax built in to the Lexmark X3500-X4500 printer. You can use the Lexmark Imaging Studio software to scan documents and send them with fax.
See page 68 of the 3500-4500 Series User's Guide.
1 Load an original document facedown on the scanner glass.
2 From the desktop, double-click the Lexmark Imaging Studio icon.
3 From the left pane of the Welcome screen, click Fax.
4 Select the Document option.
5 Click Start.
Mar 01, 2010 | Lexmark P4350 All-In-One InkJet Printer
I need the imaging studio software for a Lexmark P4350 to be able to run the scanner but all the websites keep directing me to driver software,which I have and is working fine. Can you help? Bob
please you have nothing driver cd original but please you go the
buye the printer autho. dealer and take a same model printer's driver cd
and copy the instoll in pc driver cd thru
and save a driver cd
Sep 27, 2009 | Lexmark P4350 All-In-One InkJet Printer
Can the Lexmark x4270 send a fax to an email address?
no you have to scan and create file and attach to email
Jul 07, 2009 | Lexmark X4270 All-In-One InkJet Printer
I have a lexmark x4270. Having problem sending fax. Sending local number, it's OK, but sending a different area code, it uses the local area code then the first 7 number of that number. Because someone...
Hi zoaj,
More then likely you have the fax set up to USE A DIALING PREFIX.
Therefore it is automatically doing this, regardless of what you input.
Follow the proceedure below ( which comes directly from the users manual for your printer type ) to change this. Delete the " USE A DIALING PREFIX " information.
once that is done, it will no longer automatically add the prefix for you. :)
I have BOLDED the relevant information below that pertains to this.
Please take a moment to evaluate my solution. Your appropriate rating of my solution would be greatly appreciated.
Thank you,
Using the Fax Setup Utility Use this utility to adjust the fax send and receive settings. When you save these settings, they apply to every fax you send or receive. You can also use this utility to create and edit your speed dial list.
  • Click Start onestep.gif Programs onestep.gif Lexmark 4200 Series onestep.gif Fax Setup Utility.
  • From Lexmark All-In-One Center All-In-One Main Page, click Fax Setup Utility.
The following table describes the Fax Setup Utility tabs:
On this tab:
You can:
Send
  • Enter your name and fax number.
  • Select a maximum send speed and a print quality for outgoing faxes.
  • Choose whether to scan the entire document before dialing the number.
  • Choose whether to use error correction.
  • Select when to print a fax usage report.
  • Select when to print a fax activity report.
Receive
  • Choose whether you want to print a footer (date, time, and page number) on each page.
  • Automatically reduce an incoming fax to fit to the paper size loaded or print it on two sheets of paper.
  • Select whether you want to forward a fax or print it, and then forward it.
Connection/Dialing
  • Select the number of times you want the machine to redial and the time between those attempts if the fax cannot be sent on the first try.
  • Select the phone line format you want to use (Pulse, Touch-tone, Behind a PBX).
  • Enter a dialing prefix.
  • Choose how (manually, if fax tones are detected, or after a certain amount of rings) you want to answer incoming calls.
  • Select a distinctive ring.
Speed Dial
Add to, create, or edit the speed dial list.
Group Speed Dial
Create a group number and name, and then add phone numbers to the group.
Oct 11, 2008 | Lexmark Office Equipment & Supplies
Lexmark 5400 incoming fax job wont print
from the Lexmark website:
This issue occurs when the user sends a fax using the flatbed scanner. After the first page is scanned, a message is displayed asking if another page needs to be scanned. The user options are YES or NO.
  • If the user chooses YES or NO and the fax starts to dial, they can safely press CANCEL without inducing the problem.
  • If the user presses the CANCEL button instead of answering the question, all future received faxes will go to memory instead of printing out. NOTE: There is no direct means of recovering a lost fax, but unplugging the machine and reseating the power supply will restore normal operation. An error report will be printed and provide information about the lost fax, which may allow the user to contact the sender and request that the fax be sent again.
Jan 28, 2008 | HP PSC 2210 All-In-One InkJet Printer
X4270 lexmark printer hook up
I have a lexmark X4270, I'm having a problem with the fax machine, the display keeps displaying "clear paper Jam", however there is no paper jam. I'm also not being able to recieve or send any faxes. I'm low on ink, would this prevent sending faxes? Any suggestions?
Nov 06, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark P4350 All-In-One InkJet Printer Logo
89 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
