Question about Kenmore 63672 Convection/Microwave Oven
Flash and Bang on Closing Door
On closing door to lay-up my Panasonic NN-A554W microwave combi oven for the day, there came a flash from inside the oven cavity at the area of the light bulb. This came together with a loud bang. No cooking programmed at the time as that day's cooking had completed 20 minutes previously. The touch-key panel still functions, ie can set clock, set cooking time & power etc but oven does not function nor the turntable turn. Have established that the interior bulb is blown (removed bulb and see broken filament)but don't see any other signs of the flash/bang source. Any suggestions where I need to check; I haven't replaced the bulb yet.
I suspect that the 22uf capacitor on the front panel needs replacing. I was using mine on covection only when i heard a sizzle/arcing sound then the unit died. The bulb had never worked on my microwave but on stripping the unit down I found the bulb had gone and the track on the front panel was burnt out (as described in #2) I repaired this switched on again, another flash and another bit of circuit strip was burnt away! I then noticed that the 22uF capacitor (C25) was hot to touch, but this is as far as I've got! The CPU? also looks like it's overheated!
Posted on Sep 15, 2007
The bulb blows a small part of the track on the pcb on the front panel by a small relay --- repair this and replace the bulb.
Posted on Jun 25, 2007
  • Kenmore Master
  • 9,156 Answers
Sounds like a bad door switch or door switch mount, but it also may be a problem on the control circuit board. The light bulb was probably an effect, not a cause. Sometimes the filaments of a blown bulb can short and blow a fuse, but not this time. The fuse is obviously not blown, since you have stated that you still have power to the control panel. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk Since this is a UK model, you will have to find support, service, and possibly parts links here: http://www.panasonic.co.uk/customer-Support/index.asp
Posted on Jun 15, 2007
  • 1,476 Answers
Since you know that the bulb is blown that needs replaced. I would go ahead and replace the bulb and see if it works. I doubt that it will. If not unplug the unit and remove the exterior case. Locate the secondary fuse and replace it with the same size and rating. Plug in and try but be prepared as it may do the same thing again. I am not sure what you mean by 'lay up' your unit. If it was not running (heating) it should not be the magnatron. Sounds like the bulb blew taking out the fuse which would cause the other problems you described following the flash. Good luck.
Posted on Jun 13, 2007
Panasonic inverter microwave nn-sd688s, stops and resets but then will work again after, seems to do this just by opening and closing door. What could be the problem?
I'd check the door switches to make sure they are being reliably activated when the door is closed.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Apr 08, 2016 | Panasonic NN-SD688 Microwave Oven...
NN-CT552 combi. What caused two burn marks On top of the door and on the frame?
The inside of a microwave oven has a special paint on it. If the paint becomes damaged, the microwaves strike the bare metal and arc. This leaves a burn mark. It will also ruin the magnetron inside the oven.
Jan 23, 2016 | Panasonic Microwave Ovens
Panasonic NN-T888S will not cook. the power goes on but the try does not spin and nothing heats up
At this time we recommend you use the below link to locate an authorized service center.
www.panasonic.com/repair Welcome to Panasonic Online Repair
Mar 27, 2014 | Panasonic NN-T888S Convection/Microwave...
I desparatly need instruction for the NN-A554W inverter slimline combi PLEASE can you help
Apparently that's a UK model.
You can visit Panasonic.net, select your country, then follow the support links to find the manual download area.
If yours in not there, look for spares or service centers to order one.
Mar 05, 2009 | Panasonic NN-A811A Convection/Microwave...
Cracked door on Panasonic S753 combi microwave oven
Hi I have a Panasonic combi oven in between the glass door is misting up should I be worried
Jan 07, 2009 | Panasonic NN-S753 Microwave Oven
Broken door catch, possible spring, Panasonic Slimline Combi microwave oven NN-A554W.
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have critical safety & disassembly info at our site, linked here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
The best place to order parts is Tritronics. You can also call them at 866-779-5835.
Nov 26, 2008 | Microwave Ovens
Kenmore 63672 Convection/Microwave Oven Logo
268 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
