Question about Porter Cable 4 5 Gallons 150PSI Job Boss Oil Lube Mobile Air Compressor ? C3551
Wont pressure up
When it gets to about 50 psi it starts leaking air inside the hopusing somewhere
  • ian stalker May 11, 2010
    could you remove top housing for inspction and tell me from where its leeking thanks
    ian
  • 59 Answers
Check drain plug on bottom of tank, check hose connections on top of tank.
Lugnut61
Posted on Feb 11, 2009
Dewalt Emglo 55168 motor starts to slow down as pressure builds to about 30 PSI. It really starts to labor. Any thoughts as to what could be causing the motor to strain and slow?
Most likely in tank check valve is leaking or belt is slipping. Belt tension easy to check, should not deflect with thumb pressure. Check valve should not let air escape out of tank. Easy to check. Run compressor till pressure builds to around 50 psi. Then unplug machine from power outlet. Listen for air leaking out of tank. In bad cases, air will actually leak out of intake filter. Replace check valve as needed. Good luck
Oct 26, 2016 | Dewalt Air Tools & Compressors
My 5 year old compressor runs continuously and only reaches 40 psi
The pressure hose is not leaking on the connections between tank and cilinder the pressure unloader underside on the pressure switch with little blue or black little hose is closed (not blowing air out ) if the compressor is running? and is the check valve on the tank not dirty inside ?? if the pressure unloader or connections are definitely not leaking.
A little piece shard of the membrane plate(s) thats insite the head of the pressure cilinder is broken and is inserted in the black rubber of the check valve .
More possibilitys the pressure switch itself. the insite diaphragm membran has a problem replace always the whole pressure switch if its defekt.
Oct 14, 2015 | Psi Air Tools & Compressors
Charge air pro model ir330e20 builds pressure to only 60 psi and will not stop running
Cbillgreene:
Your compressor is leaking air somewhere between the compressor head and the tank. With the compressor running, feel carefully around the ends of the tube that leads from the compressor head to the air tank. You will probably feel some air leaking around one end or the other. If so... remove the tube and find out which packing has failed.
Mar 09, 2013 | Craftsman Air Tools & Compressors
My Craftsman 33 gallons air compressor can only get up to 50 pis. When i first got it the psi go up to 150. I just bought a new pressure switch and it still the same. The motor run none stop and pressure...
hi,
one thing that would be worth checking is the pressure release valve which is usually located on the bottom of the unit. This valve is suppose to be used each time the unit is turned off. For obvious safety reasons you should release the pressure from the tank each time you are done using it. If this valve is leaking or was left open then you will not be able to achieve the desired full pressure. Just checking if this is tight may be your solution! Hope this helps!
Aug 29, 2011 | Craftsman 33 gal Air Compressor 6 hp...
I HAVE A PIECE OF EQUIPMENT THAT RUNS AT 75 PSI. I NEED TO BUY A COMPRESSOR THAT WILL HAVE A DUTY CYCLE OF 50%. HOW CAN I SELECT WHAT SIZE COMPRESSOR I NEED?
That is an extremely high pressure. I would firstly check to make sure that THAT is what you need, then MOST compressors have a regulator where you can adjust the pressure required.
It is not so much the pressure you need as the STORAGE of air that you need for a pressure that high. MOST tanks are around the 20 or so litre. To utilise a tool requiring the pressure of 75PSI I suspect you would need a tank of somewhere around the 2-300 litre size or maybe even bigger. But first just make sure that you DO need the 75PSI you mentioned.
Feb 10, 2010 | Air Tools & Compressors
I have a model FP209501 Air Compressor 2 Gallon,
2 gallons is small to begin with u need to buy an in line pressure adjuster/regulator their a few bucks and can be attached to the paint gun or line and will keep the pressure at ur adjustment the regulator on the tank sets the tank pressure at 50 so when u us it will let it drop down to about 45 than start up to build the pressure up to 50 than shuts off than repeats it self the inline keeps pressure steady even if tanks are at 200 psi
Jan 18, 2010 | Campbell Hausfeld 04 Gallon Twin Stack...
My PRO-SOURCE air compressor will not go over 50 psi
Your compressor has got a 'ring' problem. The rings on the pistons that compress air are leaking air by them and need to be replaced. Unless it's the 'pressure release' leaking. When it gets to 40 PSI or so, unplug it and listen for a leak. If no leak then it's the rings. inside on the piston. If you adjust the pressure switch all the way low, it might shut off near where it builds pressure to and you could at least use it some.
Sep 26, 2009 | Air Tools & Compressors
COMPRESSOR PUMPS UP TO 40-50 psi KEEPS RUNNING.
Most likely the pump is leaking somewhere, if the new hose is not leaking. Hoses don't just burst without showing signs or wear and tear, i.e. cracking and splitting. The pump was probably having problems, and this caused the hose to burst. Look for signs of leakage, and if you can't find them, the pump is shot.
May 27, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
International air compessor mod frv 30650 orzc2015 wont hold pressure after 50psi
hi you say it wont hold pressure aftwer 50 psi /do you mean it wont make more than 50 psi
take air cleaner off get a piece of plastic pipe that will fit in your ear /braided fuel pipe is ok ,run the comp up ,put one end of pipe in inlet manifold /other end in your ear ,if you can hear escaping air valve is shot do the same with outlet valve if air escape is mimimum rings and piston are shot hope this helps silk090
May 02, 2009 | Air Tools & Compressors
Wont pressure up
Most likely your portercable piston ring/seal broke. Its not hard to fix if you are mechanically inclined. See portercable site for rebuild kit.
Jan 14, 2009 | Porter Cable 4 5 Gallons 150PSI Job Boss...
Porter Cable 4 5 Gallons 150PSI Job Boss Oil Lube Mobile Air Compressor ? C3551 Logo
170 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
Jay Finke
Jay Finke
JOHN LAPIER
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
