Question about Zanussi 32 in. DE6755 Dishwasher
Dishwasher Zanussi dishwasher, seems to be ok making right noises but it is not filling up with water does not seem to be blocked in any way.Any advice thank you.
  • margaret blakely Jun 19, 2007
    sorry have not replied have not tried it yet will let you know but thanks for advise.
I took the small clear plastic tube off of the back of the pump, blew into it, replaced it, reataached the hose and everything is now OK.
Posted on Nov 18, 2008
I had the same problem, so I tried both the above solutions by Guest and toneavenger - my dishwasher now works fine, and I've saved myself a fortune in call-out fees and maintenance costs.
Absolutely bang on - cheers !!!
Posted on Nov 08, 2008
I have just encountered same problem ,,,i pulled dishwasher out placed it on its side ,,switched water off and took water in pipe off . simply replaced pipe and turned water back on AND presto!!!! And i ,m a woman hahahaha
Posted on Oct 04, 2007
  • 236 Answers
In some cases it is the water metering tank on the left hand side that gets bunged up and needs cleaning, next is the water feeding pipes. if everything is clean and the water valve supply is ok then it will need a special mod kit to be fitted, which will need to be fitted by a pro. tony.
Posted on Jun 16, 2007
My amana softsound III Model DWA63AL doesn't seem to get dishes clean. I have cleaned filters and everthing seems to operate ok. Water temp good. any advice?
Many people are having trouble with poor performance due to recent EPA changes required in dish washing detergent.
If it makes as much water splashing noise as it used to but it still leaves residue and undissolved food behind...then it's probably the detergent. That's what does the work.
Mar 08, 2011 | Amana DWA63A Dishwasher
Beko DWD5410 - noise
The strange noises are of of your hose water. I think your water system is not alright or unit called ciop is damaged.
Mar 27, 2010 | Beko 24 in. D3421F Free-standing...
Dishwasher wan't fill with water
The water valve may look fine but the solenoid may not be opening to allow water in. You said that everything else works fine except no water supply to the dishwasher. This sounds like a bad soleniod valve. Check for continuity on the valve with an ohms meter after you start it. Be careful.
Jul 05, 2009 | GE 24 in. Profile PDW7800 Built-in...
Doesnt clean dishes, seems to be no water coming into machine
There should be about 2 inches of water in the bottom of the DW.  If it is filling but not washing the pump may be bad.  That might explain the loud noise (motor bearing).  I assume that the detergent cover is opening but no water is being sprayed to dissolve it.
May 31, 2009 | Dishwashers
Dishwasher doesn't spray water after filling?
could be a blocked pump or capacitor fault,check if pump armature will move(centre rotating part)you may be able to view end of pump with lamp,there may also be a slot for a screwdriver to move armature,you will feel if there is something stuck,hope this helps
May 27, 2009 | Whirlpool DUL300 XTL Built-in Dishwasher
Cycle starts but water doesn't fill past heating elements.
I think that the problem is the water inlet valve if the machine is not filling at all.
If the machine is not filling to the correct level, it may be the float switch.
Apr 27, 2009 | Zanussi 24 in. DE6544 Built-in Dishwasher
Problem draining became problem with filling
Hi I would look at the water valve. Located left front . Remove the front panel , the bottom panel. check the water valve
Dec 23, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwasher was making whirliing noise during wash, now no wash, only fill and drain
there is a #10 torx screw holding that cover not drill it out. after you take it off you can tell if the chopper is careful for broken glass.
Oct 17, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Very poor cleaning all of a sudden
suspect blockage in the actual spray arms - take them out and clean under the tap. a check is to open the door when in operation and see if the spray arms are rotating. they are made to rotate only by the force of water thro angled jets at the end of the arms
Mar 26, 2007 | Kenmore 24 in. 16263 Dishwasher
Zanussi 32 in. DE6755 Dishwasher Logo
322 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
