Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
No picture i just dropped my phillips magnavox. It still "turns on" or i can hear it "click" but there is no picture or sounds. the green light is flashing.
    Sergeant:
    Champion:
  • 346 Answers
If it is dropped you most likely would have a cracked ciruit board. you would need a qualified tv repairman to check tv
Posted on Jan 15, 2009
Phillips Magnavox 9p6034c 60 in. rear projection t.v.
are you sure!? or maybe you set at the pip viewer! go to settings!
Oct 01, 2007 | Philips Magnavox 9P6034C 60" Rear...
My Magnavox TV give sound but no picture. When I turn it on the light in the bottom right hand screen goes green, then flashes to yellow and goes back to green. The screen does not change it is constantly...
You need to replace your backlight inverter.
Check that all voltages are coming from the power supply as they should. The power supply will be stamped with the correct amounts, and you just read with the multimeter to confirm.
After those check out ok, you will need to replace the inverter to "light" your screen again.
You can hear sound because the tv is ON, but the inverter isn't lighting the screen!
Hope this helps, please rate!
May 11, 2011 | Televison & Video
We have an older Phillips Magnavox tv. The tv will turn on & we will see the picture for a short time but then the screen turns grey. We still have sound, just no picture. Also, the green power light...
Hello, the grey screen could be due to a missing 220Volt source which feeds the color (RBG cathodes)inside the CRT(picture tube). When this happens the beam current inside the CRT goes high in a matter of second, thus triggering the beam current protection circuit(blinking green light)shutting down the TV. Repairing the secondary voltage source is necessary to get the TV working normal, a good technician should be able to repair it for between 80 to 100 dollars parts included, except a picture tube, which could be also the cause of the problem(K-A shorts).
Nov 06, 2010 | Philips Magnavox 27MS343S 27" TV
Magnavox plasma television will not turn on, makes
Relays clicking noise you hear.....change caps..you might see visible signs of CAPs being bad....swolen,,, top ready to explode etc.
May 19, 2010 | SNK Magnavox 42MF231D 42 in. Plasma TV
60" Projection Screen Phillips Magnavox won't turn on
Check the site www.TvRepairKits.com - they put together a kit to fix this problem.
Nov 30, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Nov 17, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Phillips 60PP9202/17 F No picture No sound
Does the power light still work when you have the above problem? If so check the site www.tvrepairkits.com. They should have a repair kit for this model.
Sep 28, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips Magnavox
Sounds like your Convertion bord pops. Tv Technical Prop, Take for service.
May 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
Black screen no sound
What is the model or chassel number it be a few thing H.O.T Resistor Caps etc..most likely horizontal output transistor.
Nov 12, 2007 | Televison & Video
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
146 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
