Question about HP LaserJet 1020 Printer
NEEDING TO PUT THE COLOR DRUM BACK INTO THE PRINTER. TRYING TO PUT THE COLOR DRUMS BACK INTO THE PRINTER
  • 55 Answers
To prevent damage to the print cartridge, minimize its exposure to direct light. Cover theprint cartridge with a sheet of paper.
1.Open the print cartridge door, and remove the old print cartridge. See the recyclinginformation inside the print cartridge box.
CAUTION
To prevent damage to the print cartridge, hold the print cartridge at each end.
2.Remove the new print cartridge from the packaging, and gently rock the print cartridgefrom front to back to distribute the toner evenly inside the cartridge.
3.Pull the tab until all the tape is removed from the print cartridge. Put the tab in the printcartridge box to return for recycling.
4.Insert the new print cartridge in the printer, making sure that the print cartridge is inposition. Close the print cartridge door.
CAUTION
If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water.
Hot water sets toner into the fabric
You can see the pictures of it at: http://www.scribd.com/doc/4212097/hp-laserjet-1020-users-guide-manual
Posted on Jan 14, 2009
Ricoh mp c3000 colored copies are double print
Could be drum units there are 4 drums or fuser assy. since you said color only I said drum unit try scanning a single color see which one does it . Will need to call a copier company or go online and buy a whole photoconductor . You will need to know how to initialize unit before you put it in.
Jan 14, 2014 | Ricoh Aficio 1018 Printer
Since i install a new drum, i have smudges on my copies how do i fix
    Sir/Madam
    If you have Brother Printer print quality problems, Then I suggest You clean the Your Brother printer drum unit as follows:
    Small Spots on the printed pages:
    If your printed document has any small white or colored spots, follow the steps below.
    1.Open the manual feed slot cover.
    2. Using both hands, slide the manual feed slot paper guides to the width of the paper that you are going to use.
    3.Using both hands, put one blank sheet of paper in the manual feed slot until the front edge of the paper touches the paper feed roller. Wait until the machine automatically feeds the paper. When you feel the machine pull in the paper, let go.
    Note
    • Make sure that the paper is straight and in the correct position on the manual feed slot. If it is not, the paper may not be fed properly, resulting in a skewed printout or a paper jam.
    • Do not put more than one piece of paper in the manual feed slot at any one time, as it may cause a jam.
    • Do not put paper in the manual feed slot before the printer is in the Ready state. An error may occur and the printer will stop printing.
    4.Make sure that the printer is in the Ready state. Press + or - to choose "Color Correction". Press OK.
    5.Press + or - to choose "Drum Cleaning".
    6.Press Go. The printer will pull in the piece of paper and start cleaning the drum unit.
    7.When the printer has finished cleaning, "Completed" appears on the LCD.
    Press Cancel so that the printer returns to the Ready state.
    8.Repeat steps 3 to 7 two more times using a new blank sheet of paper each time. Upon completion, please discard the used paper. If the print problem still remains, please go to the Step 9.
    Large spots on the printed pages:
    Hint If your printed page has colored spots at 94mm (3.7 in) intervals, please follow the step below.
    1. 9.Turn off the printer power switch.
    10. Fully open the top cover by lifting up on the handle (1).
    11. See the print sample to identify the color causing the problem. The color of the spots is the color of the drum you should clean. For example, if the spots are cyan, you should clean the drum for cyan. Take out the drum unit and toner cartridge assembly of the color causing the problem.
    Caution
    • We recommend that you place the drum unit and toner cartridge assembly on a clean, flat surface with a sheet of disposable paper or cloth underneath it in case you accidentally spill or scatter toner.
    • To prevent damage to the printer from static electricity, DO NOT touch the electrodes shown in the illustration.
    12.Push down the green-labeled lock lever (1) and take the toner cartridge out of the drum unit.
    Caution
    1. Handle the toner cartridge carefully. If toner scatters on your hands or clothes, wipe or wash it off with cold water at once.
13.Put the print sample in front of the drum unit, and find the exact position of the poor print.
14.Turn the drum unit gear by hand while looking at the surface of the OPC drum (1).
15.When you have found the mark on the drum that matches the print sample, wipe the surface of the OPC drum with a dry cotton swab until the dust or glue on the surface comes off.
DO NOT clean the surface of the photosensitive drum with a sharp object.
Note Make sure that you put in the toner cartridge properly or it may separate from the drum unit.
17.Slide each drum unit and toner cartridge assembly into the printer. Make sure that you match the toner cartridge color to the same color label on the printer.
C- Cyan, M- magenta, Y- Yellow, K- Black
18.Close the top cover of the printer.
19.Turn the printer power switch back on.
If your question was not answered, please check...
Clean the drum unit Brother
Or
If You still need Brother Printer Help I suggest You follow Us On for :
Brother Printer Support
Nov 07, 2012 | Brother Dr420 Black Drum Unit Cartridge
Risograph 3770 Drum problem
Seems the 'synchronisation' between paper feed and drum ist lost. Maybe you have heard a ripple sound? This means the toothed belt has jumped one or more teeth.Remove back cover loose paper feed clutch to readjust the belt accordingly ...
Sep 03, 2012 | Riso RP 3700
Printer telling me to replace drum. I replaced all the colors and still not working
you need to reset the counters so the printer knows there is a new drum.
to do so try this:
Press + or - to choose "Machine Info.".
Press OK to proceed to the next menu level, and then press + or - to choose "Reset Parts Life". Press OK, and then press + to choose "Drum Unit".
Press OK, and then press + or - to choose the color that you replaced.
Press OK two times.
Sep 18, 2011 | Brother HL3070CW Compact Digital Color...
We just replaced the imaging drum on our HP 2840. Now when we print in color, we get the image we printed, plus a lighter version of the same image about 2.25 inches lower on the page, every 2.25 inches. ...
A repetitive defect at that spacing points to the transfer roller. This is the roller in the bottom of the drum/cartridge cavity. Most likely you will need to aquire a Q3948-67920 transfer roller kit.
Mar 16, 2011 | Office Equipment & Supplies
Xerox Textronix Phaser 2135 My cyan color is not printing on location with other colors. It was ok before i replaced my magenta & yellow image drums. I removed transfer belt and cleaned and...
You will need to run a color calibration on the machine so that it can adjust itself. You may have to do it up to 3 times before the alignment is correct. Your user manual should tell you how to do this. I tried to check the Xerox website but their manual downloads are off line right now.
Mar 11, 2011 | Xerox Phaser 2135N Laser Printer
I have a HL4040CDN it said the Cyan was out and we replaced it with a new one and it says the same thing. Checked and found no problem.
SIR/MADAM
If you have print quality problems, clean the drum unit as follows:
1.Turn off the printer power switch. Press the front cover release button and then open the front cover.
2.Hold the green handle of the drum unit. Lift the drum unit up and then pull it out until it stops.
3.Release the gray lock lever (1) that is on the left side of the printer. Pull the drum unit completely out of the printer using the green handles on the drum unit.
  • We recommend that you place the drum unit on a clean, flat surface with a piece of disposable paper underneath it in case you accidentally spill or scatter toner.
  • Handle the toner cartridge carefully. If toner scatters on your hands or clothes, wipe or wash it off with cold water at once.
  • Hold the handles of the drum unit when you carry it. DO NOT hold the sides of the drum unit.
4.Hold the handle of the toner cartridge and pull it out of the drum unit. Repeat this for all the toner cartridges.
5.Turn the drum unit over by holding the handle. Make sure that the four drum unit gears are on the left side and the drum unit gear "1" is located furthest away from you. The numbers can be found on the drum unit gear.
6.See the print sample to identify the color causing the problem. The color of the spots is the color of the drum you should clean. For example, if the spots are cyan, you should clean the drum for cyan. Put the print sample in front of the drum, and find the exact position of the poor print.
7.Turn the drum unit gear toward you by hand while looking at the surface of the drum (1).
8.When you have found the mark on the drum that matches the print sample, hold the middle of a cotton swab and wipe the surface of the drum gently until the dust or paper powder on the surface comes off.
Caution DO NOT clean the surface of the photosensitive drum with a sharp object.
9.Turn the drum unit gear toward you by hand to return it to the home position. The home position of each drum can be identified by matching the number on the drum unit gear to the same number on the left side of the drum unit.
10.Make sure that the number on each of the four drum unit gears matches the corresponding number on the side of the drum unit.
11.Using the green handles turn the drum unit back over.
12.Hold the handle of the toner cartridge and slide the toner cartridge into the drum unit. Make sure that you match the toner cartridge color to the same color label on the drum unit, and make sure that you fold down the toner cartridge handle (1) once the toner cartridge is in place. Repeat this for all the toner cartridges.
13.Put the drum unit back in the printer as follows.
  1. Make sure that the gray lock lever (1) is in the up position and put the drum unit in the printer. Push down the gray lock lever (1).
When you put the drum unit in the printer, match the green guides (1) of the drum unit handle to the green arrows (2) on both sides of the machine.
2.Push the drum unit in until it stops.
14.Close the front cover.
If your question was not answered, Please Visit Below URL For Brother Printer Issue:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002200/000056/faq002256_001.html?reg=us&c=us&lang=en&prod=hl4040cn_all
OR
In Case You Still Need Online Assistance For Online On:
1.
7.
9.
10.
13. 18702e13-4079-4a6c-b6e8-bf7ca3a1724e.gif 39941d87-a31f-42a9-8cc5-c22f21528c55.gif
Jan 28, 2011 | Brother HL4040CDN Duplex Unit
We have recently bought a second hand OKI C5200 Colour Laser Printer and even though the black and white print seems to be great the clour is coming out with coloured streaks, what would you recommend?
One or more of the drums may be defective. Swap the black with another color and print a document. If that color printed the charectors ok, then continue the test with the other drums each taking a turn in the Black drum position until you find the bad drum.
Oct 08, 2009 | OKI C5200n Laser Printer
I have a riso RP3100ui. I am looking to buy a used drum. Currently i use only black ink. I see used drums on ebay and alike but they are colored drums. Can I put a black in cartride in a rp3100 drum and...
No.. A color drum is a color drum. You can change any color drum and re-program it to be a different color but you can't use a black drum for anything else. The RP is a sophisticated machinge and even the card inside the black drum is different. I think it would give you an error at some point.. Besides the fact you'd go through about a half a tube of ink before you got the new color.. I've converted color drums as you say.. even after 5000 sheets of paper I still have the old color on the sides and stuff. My local service shop changed one of my drums to a different color for $175.. I thought it was a good deal after doing it myself once. Helluva mess. You want to use a color drum as black.. Might work..maybe.. but I've never tried it.. If there's a problem with your black drum... buy a color drum and strip it for parts (except the printed circuit board) and get your black drum working.
Jun 25, 2009 | Riso Office Equipment & Supplies
HP color laser 2550L prints only in yellow
Hi Mmgrafde,
Press the Go and Rotate Carousel buttons simultaneously. This will calibrate the printer. See if this works.
Otherwise....Remove all cartridges and drum. Switch off printer. Close the lid. Switch on printer and wait until any churning stops. Insert the drum and close the lid. Wait until any churning stops. Put in one cartridge at a time, closing the lid and wait till it stops churning each time. With the last cartridge put in, it will churning longer (calibrating). Try to print from your computer.
It could also be that the toner could actually have run out for the other colors.
Rgds
S88
Jan 01, 2009 | HP Color LaserJet 2600n Printer
HP LaserJet 1020 Printer Logo
99 people viewed this question
Ben Johnson
