Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftsman GDO, Model 139.53600. moves 4inches up/ down
I had to replace the main drive gear and now the door will only move 3-4 inches and then reverses from either position. It is currently open inthe up position. I have adjusted the limit up and limit down switches to allow for plenty of movement. I have adjusted the Force up/dn. Neither worked.
  • 3 Answers
Find the increase travel adjustment screw and turn it clockwise 1/4 to 1/2 turn.
Posted on Jan 14, 2009
Craftsman 139.53600 I had to replace the main drive gear and now the door will only move 3-4 inches and then reverses from either position. I have adjusted the limit up and limit down switches to allow...
Make sure you put the black cup back on the end of the motor shaft and that it is pressed all the way on. Make sure the RPM sensor is plugged in. If neither of these are the issue, then you probably did not have the motor shaft pushed all the way back when you tightened the coupler after replacing the worm gear. Loosen that coupler up and from the front of the motor (opposite end in which the coupler is on) push the shaft back as far as it will go. Hold it there while you tighten the coupler back up and then try it.
Apr 04, 2011 | Sears Craftsman LiftMaster Chamberlain...
1/2 hp craftsman door opener moves about 12 inches then reverses back & thats all it will do. just replaced the main two plastic drive gears whenthis started
First try adjusting the force limits. They are up on the motor head. If this works do a 2x4 safety reversal test afterward. It also may be the rpm sensor. Sometimes this can go out with the gears. There is an led light on the motor head. If it is flashing 5 times in a row then it is this for sure. You can get replacement parts at searspartsdirect.com. Thanks BB
Sep 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
My 20 yr. old Craftsman 1/2HP chain drive GDO (139.18590) will click and hum for a second but the door doesn't move when I press a remote or wall console. The door moves freely manually and I checked the...
If your door is stuck in the open position the trolley is most likely jammed against the bolt just in front of the motor unit. You should be able to loosen the chain enough that it releases the pressure on the trolley and then close the door. While the door is closed, locate the 'up limit' control which is on the side of the motor unit. Turn this control 2 full turns in the opposite direction of the arrow printed on the cover and then tighten the chain.
Feb 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
My GDO makes a noise as if it's turning inside, but the chain is not moving. Is it fried?
The drive gear is stripped. The part number is 41A2817 and is available at any good door opener service company. It comes with instructions.
Jan 31, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman GDO model # 139.53990D does not open when I push the wall button the motor clicks but does not engage. I have been trying to adjust the travel limits and it now moves all the way back to the...
You need to remove the cover of the motor unit and check the drive gear. It sounds like it is stripped. Your explanation is a little confusing though. You say it moves all the way back to the cover protection bolt and then you say it won't open.
Jan 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Have replaced drive gear on Craftsman GDO. Everthing engages and chain moves but door only opens 3 inches are so. Have ajusted opening cointrol on side to max and only 3 inches. When I unlatch GD from...
Loosen the chain enough that you can remove it from the pulley on top of the motor unit. Now with the door closed run the motor until the pulley turns in the clockwise direction and stops. Put the chain back on the pulley and tighten. You may have to tweak the up and down limits now.
Nov 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Lift-Master GDO goes up, not down
If the door operates freely without any binding, while operating it manually then It would appear that the obstruction sensor mounted across the doors path is ether out of alignment, lens dirty,or malfunctioning
Feb 21, 2009 | liftmaster Chamberlain Garage Door Opener...
Garage door won't close.
After replacing the worm gear and main drive gear on my Craftsman 1/2 HP garage door opener I found that my door moved about 4 inches stopped and reversed the same distance. I checked all the settings and everything seems OK. What fixed the problem was I released the two allen set screws on the end of the motor shaft and pulled tha motor shaft toward me. When I replaced the black plastic cap that looks like a pill cap top on the end of the shaft this corrected the depth setting that cap rotated through the RPM sensor. I set the limit settings (up and down) on the side of the opener and reset the force pots marked (KC) to mid range.
the door now works. I hope this helps. I also checked and eliminated the door sensors by putting a box in the beem this inhibited any movemnet at all, so I knew it wasn't the door sensors as there was at least 4 incheds of movement prior to the box and nothing with the box.
Oct 27, 2008 | Sears Craftsman LiftMaster Chamberlain...
Craftsman GDO Will not close
readjust the sensor controls on the side of the unit
Dec 28, 2007 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
452 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
