Question about Porter Cable 4 5 Gallons 150PSI Job Boss Oil Lube Mobile Air Compressor ? C3551
Wont pressure up
It comes on but once it gets to about 50 psi it starts leaking air somewhere inside the housing. Then it wont gain anymore pressure
  • 52 Answers
Most likely your portercable piston ring/seal broke. Its not hard to fix if you are mechanically inclined. See portercable site for rebuild kit.
Posted on Jan 14, 2009
Dewalt Emglo 55168 motor starts to slow down as pressure builds to about 30 PSI. It really starts to labor. Any thoughts as to what could be causing the motor to strain and slow?
Most likely in tank check valve is leaking or belt is slipping. Belt tension easy to check, should not deflect with thumb pressure. Check valve should not let air escape out of tank. Easy to check. Run compressor till pressure builds to around 50 psi. Then unplug machine from power outlet. Listen for air leaking out of tank. In bad cases, air will actually leak out of intake filter. Replace check valve as needed. Good luck
Oct 26, 2016 | Dewalt Air Tools & Compressors
Pressure in pump is stuck at 11psi
Change it, If it worked once upon a time, now it does not, You can't fix it. They come preset 20/40,30/50 or 40/60 the first number is the on psi the second is off. Check your old one to see which you need, it is on the inside of cap. Make sure to check the air in bladder tank while the system is down. (2 psi less than start up pressure)
Mar 07, 2014 | Flotec TC2151 P2 Well Pump Pressure Switch
Compressor fills with air and shuts off. No problem there,however, once the pressure is obtained and shuts off there is a leaking noise coming from the inside of the motor housing. Pressure drops slowly...
This sounds like a problem with you check valve. This should seal after the air compressor shuts down but if there is a problem with the check valve then it will allow the air to escape back out from the take.
Here is a link to the parts breakdown:
http://shoppingcart.msservicecompany.com/msservice_net/product_files/C2002-WK/C2002-WK%20PD.pdf
You want to check part # 11 A19714.
Thanks
Oct 25, 2010 | Porter Cable C2002 150 Psi 6 Gal...
My PRO-SOURCE air compressor will not go over 50 psi
Your compressor has got a 'ring' problem. The rings on the pistons that compress air are leaking air by them and need to be replaced. Unless it's the 'pressure release' leaking. When it gets to 40 PSI or so, unplug it and listen for a leak. If no leak then it's the rings. inside on the piston. If you adjust the pressure switch all the way low, it might shut off near where it builds pressure to and you could at least use it some.
Sep 26, 2009 | Air Tools & Compressors
COMPRESSOR PUMPS UP TO 40-50 psi KEEPS RUNNING.
Most likely the pump is leaking somewhere, if the new hose is not leaking. Hoses don't just burst without showing signs or wear and tear, i.e. cracking and splitting. The pump was probably having problems, and this caused the hose to burst. Look for signs of leakage, and if you can't find them, the pump is shot.
May 27, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
International air compessor mod frv 30650 orzc2015 wont hold pressure after 50psi
hi you say it wont hold pressure aftwer 50 psi /do you mean it wont make more than 50 psi
take air cleaner off get a piece of plastic pipe that will fit in your ear /braided fuel pipe is ok ,run the comp up ,put one end of pipe in inlet manifold /other end in your ear ,if you can hear escaping air valve is shot do the same with outlet valve if air escape is mimimum rings and piston are shot hope this helps silk090
May 02, 2009 | Air Tools & Compressors
Air tank (underneath house) does not push water out of spigot in sinke or refridgerator.
You need to test the air pressure with the tank totally empty, remove the tube that is going into the tank and open the tank valve to release all water, if water is in tank and does not come out your bladder is finished and you will need a new tank, if you are able to get all the water out then you need to test PSI again and it needs to be between 7-10 psi, this way when the bladder fills up again with water that pressure will be the ideal 40-50 psi.
Fresh Water Systems | http://www.freshwatersystems.com | 1.877.335.3339
Apr 22, 2009 | Culligan Sales #SY-750S Under Sink Water...
Wont pressure up
Check drain plug on bottom of tank, check hose connections on top of tank.
Lugnut61
Jan 14, 2009 | Porter Cable 4 5 Gallons 150PSI Job Boss...
Porter Cable 4 5 Gallons 150PSI Job Boss Oil Lube Mobile Air Compressor ? C3551 Logo
270 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
