Question about Sharp 35VX-H2000 35 in. TV/VCR Combo
Television my son was playing with the remote, and did something thatcaused the tv to scan all 125 channels while this was going on you couldn't shut the tv off so I unplugged it to see if it would reset well now the tv won't even turn on
  • purkey Dec 30, 2007
    son was using universal remote to program the tv until nothing worked and i also unplugged tv now it wont come on like all the channel volume power buttons were shut off
Scanning the channels would not have done damage, the tv probably just sensed the unplugging of the power as a ''spike'' in the power line. Just let it sit unplugged for a while and then plug it back in, should turn back on again. also, if you are on cable or such, the scanning of the channels should actually be done, in ordr to see all available channels when the vcr is not in use, or if not, just set it to channel 3 or 4 to see it through the cable box. ps.. In the future, don't buy tv/vcr / dvd comos, the main reason why most peole buy those things is so the kids will leave the bigger tv set alone, problem with that is- kids will be kids, and sooner than later they will stick something the player's slot and screw the unit up- that leaves the tv by itself, which they will not want to see if the player is not working. so you are out of both and the kids are back taking the bigger tv away from you. best thing is always to buy separate units (vcr/dvd player combo's or separate units are usually cheaper to buy separately along with a dedicated tv than one of those all in one units. something goes wrong, just fix or buy a replacement for the system. and you get to keep your own tv.
Posted on Jun 12, 2007
Dont remember the code for the remote to my television
Hello
Try with these codes. These codes are of universal remote control with Apex Digital.
015 226 037
May 10, 2011 | Apex Digital AT2702 27" TV
Help. I got a used TruTech t200d for my nine year old. we were able to hook up and play on playstation 2, but are unable to get the tv to pick up the comcast channels. we do not have the trutech remote...
U able to go into the tv Menu?Yes,goto SETUP changes Pick CABLE and scan for channels for the Comcast CABLE channels.Or Try website like Remotes.com to buy an original tv remote.
Mar 04, 2011 | TruTech T2000D TV
Original remote lost. have universal remote. cannot program TV
On the right hand side of this television there are panel buttons. It appears that your son in law knocked the tv out of the correct input. Press the input button in order to cycle through the 5 inputs. Typically pressing the input button on the side panel of a television and pressing it again and again and again will make it change inputs. Universally the buttons on the tv panel function as follows: Channel up moves the cursor up. Channel down moves the cursor down. Volume + moves the cursor right. Volume - moves the cursor left.
Hope this helps
Apr 28, 2010 | JVC LT-42E478 42 in. LCD Television
I have a toshiba 36 inch television, magnabox dvd player and cable box hooked up. I can't get the television to channel 4 and I don't have the manual to get the remote for it to work. We use the remote for...
Oh yes clear on what your saying, Channel 4 needs to have signal to it during the scan!! So i hope this VCR or whatever you hooking up to it is set for channel 4 and its on and playing so a signal is marched threw it when your autoscanning. Without a remote this is a priceless fail i would recommend www.remotes.com get the remote for your TV and you should be able to navagate the menu fine. You also can put all you stuff on inputs to advoid the tuner all togeather.
Thanks we understadn what your saying and would like to help you in this manner but without a remote that works its will be hard to explain over email but please scan the channels when the thing is playing so it can detect a clear signal.
please do help us out by pressing the accept button for our efforts today!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jan 12, 2010 | Toshiba 36A40 36" TV
Input channel
sadsoldinf33 -
You keep pressing the TV/VIDEO button to switch between input modes.
Here is your manual in PDF: http://www.tacp.toshiba.com/tacpassets-images/models/27a34/docs/27a34_om_e.pdf
(See page 24 of the manual).
Thanks,
videoman7
Aug 07, 2009 | Toshiba 27A34 27" TV
Channel button on tv and remote control dosent work
The channel buttons on the tv and remote only navigate through the channels programed into the tv. You will need to go into set up and scan for channels or manually add channels you wish to receive.
clarkco
Mar 07, 2009 | Vizio GV42L 42 in. LCD Television
On and off
That hapened to me once and the solution that worked for me was unpluging the TV for about 5 minutes and pluging it back in, you may just need a new remote though.
Jul 28, 2008 | Philips 55PP9352 55" Projection Television
Set up for cable
You might be able to restore the factory settings by pressing "play" and "FF" simultaneously and hoding them down until the set shuts off (about 5 seconds). Then when you turn it back on it will lead you through the setup routine, which includes auto channel select.
Plan B would be to buy a universal remote.
Jun 26, 2008 | Quasar VV-2002 20 in. TV/VCR Combo
No sound on JVC AV-48P575 48 inch rear projection TV
Try going into the menu and find something called, "center channel input." If it is on, the sound will not work. Turn it off, and the sound should be restored.
Mar 23, 2008 | JVC AV-48P575 48" Rear Projection...
Televison & Video Logo
76 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
