Question about LG RU-44SZ61D 44" TV
ACCESS TO BULB
HOW DO YOU GET ACCESS TO THE BULB ON A L/G RU44SZ61D?
THRU THE BACK OR FRONT?
Looking at the television, on the lower right hand side is the ventilation opening. Remove the screws and then remove the cover. Inside the opening is the light bulb holding bracket that has a handle on it. Disconect the power wires (2) going to the bulb, remove the 3 screws holding the metal cover over the bulb and pull it out of opening. Then remove the screws holding the light bulb in place. Very simple and easy to replace.
Posted on Feb 23, 2009
I have a rear projection Toshiba model 62hm95. I have a rear projection Toshiba model 62hm95. I have a rear projection Toshiba model 62h
There is no bulb to replace on a rear projection set. It uses 3 separate picture tunes 1 red 1 Blu and 1 green coupled to magnification lenses that focus onto the mirror which the directs the image thru the screen. Access is usually by removing the trim ring and screen from the front. Access from the back only gains access to the circuit boards. Be very careful as each tube has its own high voltage transformer which can have from 50000 to 150000 volts.
Oct 07, 2016 | Toshiba 62HM95 62" DLP HDTV
How to change fuel lines
saws use a flow thru carburetor design , fuel is drawn out of tank and excess unused fuel is returned to tank thru other line , the clear primer bulb starts this "flow thru " process and engine vacuum (running ) continues it
when replacing lines many folks forget what line went thru what hole (change them one at a time ) this requires a little detective work to figure out what hose thru what hole goes , with a little fuel in tank tilt saw front to back , see what hose always gets the end covered up with liquid level , this line always goes to farthest hole in tank back and that hose goes to fitting nearest the primer bulb ,, due to process of elimination there's only one other possible place for the other line
Apr 29, 2014 | Poulan Garden
How to replace burned out light bulb
You need to remove the top cover to access the bulb. That is the only way on most microwaves.
Dec 02, 2011 | Emerson MW8107WA Microwave Oven
Headlight BULB, Driver Side, Can I go thru the fender well to change it out? Or do I have to drop the bumper on driver side?
remove wheel,unfasten front half of inner fender liner,pull liner back and you will have access to change bulb.
Feb 06, 2011 | 2006 Nissan Maxima
Brake Lights
You go thru that access to remove the whole assembly to get to the bulb.
May 15, 2010 | 2003 Volkswagen Beetle TDI
How do you change the brake light on a 2001 altima? The one in the rear window
There is a round plastic clip on the verticle carpet cover which must first be removed to access the back of the tail light assembly. Squeeze the back side of the clip and pull on the front of the clip until it snaps out. There are then two 5/16 nuts which must be removed. These are hidden by plastic wiring brackets which must be removed from the nut shaft. The light assembly can then be removed - note that there are two allignment posts attached to the assembly which slide thru slots on the out-side of the assembly. Carefully pull or pry backward to remove the assembly from the body of the car. Here you may access the back of the affected bulb. Simply turn to the left and remove/replace the bulb.
Oct 13, 2009 | 2001 Nissan Altima
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
Signal light bulb change/who and where
  1. From under front wheelhouse, remove access cover behind park and turn signal lamp
  2. Through access hole in wheelhouse, rotate park and turn signal socket counterclockwise one quarter turn.
    1. Pull socket from back of lamp.
    2. Pull bulb from socket. INSTALLATION
      1. Align key on bulb base to groove in socket and insert bulb into socket.
      2. Through access hole in wheelhouse, insert socket into back of lamp.
      3. Rotate park and turn signal socket clockwise one quarter turn.
      4. Install access cover and verify lamp operation.
Hope this helps with your prob
Mar 27, 2009 | 1998 Plymouth Voyager
How to change the bulb in a 2001 dodge ram 2500 brake light
IS IT A FRONT OR BACK BULB/FRONT LIFT THE HOOD AND TURN OUT THE BULB HOLDER/REAR UNSCREW THE TAIL LIGHT ASSEMBLY.
Jan 17, 2009 | 2001 Dodge Ram 2500 Truck
3rd Brake Light Access
Look in the owners manual...it should have access instructions for this bulb. Or, try calling (or stop by) a dealer. the "service consultant" or service manager should be able to quickly tell you how to access the bulb.
Jan 06, 2009 | 1995 Buick Riviera
LG RU-44SZ61D 44" TV Logo
198 people viewed this question
Computer Repairing
Computer Repairing
