Question about Tappan TGF320 Gas Kitchen Range
Oven controls oven was preheated and it is now reading F2 or F3 on display window. Cannot get oven to stay on...Please help. I have a Tappan gas range 30 series
  • 318 Answers
Those failure codes usually mean the oven sensor is out of range or has an open circuit.
you can replace the sensor for about 50-75 bucks and that will allow the oven to heat properly again.
you wont need to do any reseting or clearing of the code, just fix the problem and that code will go away.
Posted on Jan 15, 2009
F3 and f2 codes on Tappan stove model 30-3991-00-03
1. Test harness/connections P4 (EOC) and P11 (Surface Element Control Board). 2. If harness checks correct, failure can be caused by faulty UIB, Surface Element Control Board, or EOC. Check harness and connectors from the EOC to Mini Oven Control Board. Check for 15VDC to Mini Oven Control (red and gray wires). If harness and voltage are good replace Mini Oven Control. If fault returns replace EOC.
Aug 24, 2012 | Tappan TGF320 Gas Kitchen Range
Tappan stove model # mef352bfwa and serial # vf72904759 . When using oven F3 shows up on display and oven shuts off.
Hello & Welcome to FixYa
F3 error code indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 18, 2011 | Tappan Kitchen Range
Tappan gas range model 30-3991-23/03 - when the oven is heating, an F3 code comes on, followed by an F2 code. The oven turns of and I can't heat it again until it has cooled. Can I repair it myself? ...
F3 error means open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you want to do it yourself and wan to be sure before replacing the sensor then you can test it with a voltmeter between 1080-1120ohms....if it reads more then or less then this then it needs replacement however, if the reading is around between 1080-1120ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 15, 2011 | Tappan TGF320 Gas Kitchen Range
Oven goes out ,display flashes --F3-
Hi jstpchy1953,
F3 code error means open oven temperature sensor (RTD). To fix this error, Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope this helps.
Thank you for using FixYa.
Oct 24, 2010 | Tappan TGF320 Gas Kitchen Range
Turn on the oven to preheat and it stays cold
There are usually only 2 things to check on a tappan. The thermostat or the igniter. The Temp control is pretty sturdy on these, so the order of failure will be, igniter first, then thermostat.
Mar 23, 2010 | Tappan TGFS_63 Gas Kitchen Range
Oven will not turn on
Hi mcifaretto,
F3 code error indicates a bad oven temperature sensor (RTD). To fix this error, Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope this helps.
Oct 08, 2009 | Tappan TGF320 Gas Kitchen Range
F6 f8 and f12 error reading on stove
F0 & F1 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5, 6, 7 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F8 Lock switches Check switches and replace if necessary
Oct 27, 2008 | Tappan TGF320 Gas Kitchen Range
Unlock my Tappan Gas Over Door?
Hi wewada,
Hope this helps.
Aug 03, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan Millenia Range
Hi ChrisNess,
F3 code error indicates a bad oven temperature sensor (RTD). To fix this error, Check sensor harness and harness connection between oven sensor and oven control. If wiring is ok, replace the oven temperature sensor (RTD)
Hope this helps.
Jun 24, 2008 | Tappan TGF320 Gas Kitchen Range
F1 and F2
Here are the codes for Tappan ranges:
TAPPAN
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5, 6, 7 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F8 Lock switches Check switches and replace if necessary
Nov 06, 2007 | Tappan TGF363 Gas Kitchen Range
Tappan TGF320 Gas Kitchen Range Logo
260 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
