Question about Desa International 240 Deg. White Twin 150 Watt Halogen Motion Sensing Security Light
My unit stays on 24/7, on bright, it's a heath/zenith dual bright
Motion sensor light control. I think I need to replace the light control unit. Do you folks have the control units or can you direct mr to some body who do?
Thanks dave
  • dtvic Jan 15, 2009
    The unit was installed on 5/25/03 and I have tryed the override and turning the power off for 2, 3, 6 minutes, all day all with no help.
    Champion:
  • 244 Answers
How old is unit. did it enter manual override? Turn off power for 2 minutes and turn back on. any better.
Posted on Jan 15, 2009
  • marty metzger Jan 15, 2009
    contact manufacturer. some warranty for 5 years, some 10. need new head. replace whole thing.
Lights flash on and off
Very common issue with motion sensing lights. You can either replace the light sensor which is available at most hardware stores or you can disable the motion sensing feature and just have an on-off light. To disable the sensor, (turn off the power!) unscrew and remove the light sensor (it is the reposition-able box under the light.) It depends on the particular light, but you usually just match up the wire coming into the light from the house and the wire from the bulbs and connect them with a wire-nut.
Jan 07, 2014 | Heath Zenith SL-5318-WH Dual Brite Motion...
The LED flashes, but the lights won't come on. Do I need to install a light shield. The sensor is mounted in a well shaded area 10 to 12 feet above ground. There are landscape lights beneath the sensor are...
There are settings on the sensor itself. Should be a dusk to dawn setting that will keep it off during those times and then function at night. as far as not working I would first suggest setting the sensitivity. Disrupting to power could have reset this.
Oct 15, 2013 | Heath Zenith Heath/Zenith SL-5411-WH Heath...
Lights flash on/off non-stop, until reset, then does it again. model SL-5408 GR-B
Have you reset the controls on the sensor itself. Suggest you reinstate factory settings and start over.
Hope this helps.
Aug 31, 2013 | Heath Zenith SL-5318-WH Dual Brite Motion...
Need the manuel for setting heath zenith lamp module model no BC-465
i have a question about heath zenith motion sensor light.
i put up two new Heath Zenith Motion Sensor Light Control the i buy from home depot tie into switch leg. When i put in on test it work fine stay on for a few second them off, but when i set up on automatic Time-1min.\ Dual Brite-off \ Lamp Mode-Normal light go off and them come back on for the rest of the nigh long and go off morning time. Any body have this problem?
Jul 06, 2012 | Heath Zenith Secure Home Motion Activated...
Cannot get light to go on and then off at programmed time. Stays on. At cottage with no neighbours or ambient light. Installed professionally, not by myself. Frustrated many efforts before contacting...
Light stays on all the time: Turn power to light off. Wait 10 seconds. Turn power back on.
Typical option on motion lights: Quick power flick -- light stays on. Slow power flick -- light goes into motion sensing mode.
Hopefully the professional installer gave you a switch.
Jun 01, 2011 | Heath Zenith SL-5318-WH Dual Brite Motion...
Need to wire motion sensor to light, have three wire(red, black & white), need to know how to hookup wires? my model no. is :-heath zenith sl-5318-bz-a
The black wire goes with the black house supply wire, and the red wire goes with the black wire from the lighting fixture. The white wires all connect together.
Feb 22, 2010 | Heath Zenith SL5316WHB Replacement...
I have a sensor that stays on all night when the
Your motion detector is based on infrared or heat sensing technology. Moving air or wind will make your unit more sensitive to false alarming. Here are a few things for you to check: 1) make sure your unit is sealed. Any holes or openings in the unit's casing will affect operation. 2) you may need to readjust the unit's sensitivity. There may be an adjustment pod or jumper inside the detector to reduce sensitivity. 3) make sure the unit is mounted securely. If the wind causes the detector to move, even slightly, this could be the cause of your problem.
Jan 19, 2010 | Heath Zenith 270 Degree Replacement Motion...
Desa International 240 Deg. White Twin 150 Watt Halogen Motion Sensing Security Light Logo
1,237 people viewed this question
Top Desa International Home Security Experts
Eric Kalman
Eric Kalman
Level 1 Expert
Mike
jasbo
jasbo
Are you a Desa International Home Security Expert? Answer questions, earn points and help others
