Question about Brother MFC 420CN All-In-One InkJet Printer
When running a test print on my mfc 420cn it will not print yello
Can not print out yellow on test sheet
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
How to clean printer head for brother mfc j265w
Hi .. i have a similar problem ... i juste replaced the Black cartridge ... and when i run a "test print" or an 'alignment print" ... the whole black ink block doesn't appear at all .. only the Magenta, CYan & Yellow are ok. HELP ! ;)
Apr 19, 2012 | Brother MFC 420CN All-In-One InkJet...
Error 41 brother all in one :Performed Print Quality Check Sheet $ times. The test sheets became closer and closer to being 100% correct, then error 41 pops up
Machine error 41 is "defective print head".Try to turn off the printer and wait 10 min.Then turn on, if the error continue showing your printer need service.
Oct 13, 2009 | Brother MFC 420CN All-In-One InkJet...
'1) Lost' Black print 2) Can no longer scan more than one page
Lost Print solved by repeated cleaning. No solution to the single feed problem yet.
Jun 22, 2009 | Brother MFC-5440CN All-In-One InkJet...
Changed all 4 cartridges, yellow, red, grey not printing. Only blue & black print
Sounds like most of the color lines (the "cables" between print head and cartridges) either have clogged ink in them, or air bubbles. Try the cleaning process found by pressing Ink Management and then Menu/Set twice. After the test print sheet is printed, answer the question(s) in the display and print up to five test prints by answering the questions.
It should solve the problem, but if it doesn't, you should perform a heavier duty purge found in the service mode.
Jun 02, 2009 | Brother MFC 420CN All-In-One InkJet...
Error code A7 on brother mfc-420cn
Hi there
(A7 One-line feeding timeout error. )
Brother Error Codes RAM clear (most models)
Quickly press function * 2 8 6 4
Display should read maintenance
Press 0 1 for a full ram clear, or 9 1 to retain user data
Display should read reinit for a few moments then redisplay maintenance
Press 9 9 to exit the maintenance mode
Other maintenance mode switches:
01 ram clear (see 91 below)
02 scanner initialize (feed a white sheet, then a black sheet)
05 white level
09 print test
10 modify soft switches
11 print configuration list
16 panel test
19 CML test
20 signal test
21 tonal test
23 filter RX
54 scan edge
55 scanner area
66 test print memo
75 display drum life (if enabled on laser models)
76 reset drum life counter (laser models)
91 parameter initialize (user programming remains intact)
95 protection
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 05, 2009 | Brother MFC 420CN All-In-One InkJet...
When i run a test pattern on my mfc 420 it will not print the yel
Clean the yellow printer head with the self cleaning function. Try printing yellow from a computer, etc. Check ink level, make sure it is not telling you low ink.
Jan 12, 2009 | Brother MFC 420CN All-In-One InkJet...
Can not get yellow to prent out on the test sheet
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came withthe printer. When the software program asks you to connect theprinter to the USB port, do so and it should again work properly.
Jan 11, 2009 | Brother MFC 420CN All-In-One InkJet...
MFC-420CN does not print black
My yellow cartridge was doing the same thing as your black. So I took the cartridge out, and took a flashlight to see how it works. There is like a little straw on the right hand side which goes up into the printer cartridge, this I assume is to measure the ink. I took a needle and cleaned that 'straw' thoroughly. Reseated the ink, ran cleaning and test print, and then the printer found the yellow ink! You could give that a try. It might work for you too. (I have never used any ink but Brother ink in the printer, btw.)
Apr 20, 2008 | Brother MFC 420CN All-In-One InkJet...
Double prints or Text shadow printing by MFC 420CN
yes. you have to run the alignment feature. press ink - set - arrow-down til alignment. After alignment test print read the paper and choose the right setting by nr.
Apr 09, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother mfc 420 cn
if you have an error 41 the machine wont print any more due to a short circuit in the print head.
plz check error message.
anyway, if you have received error 41 you need a new printhead or better (because its cheaper) a new mfc.
sorry!
Feb 13, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
35 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
