Question about Brother HL-2170W Laser Printer
I can't print anything
Hi, my name is Gilberto. I have a Mac and I can't print because when I try the printer says ''your printer is currently offline'' and I don't understand why because I have it connected with a USB cable.
    Problem Solver:
  • 5 Answers
Do the install with the network cable, DELETE the printer but not the contol files, do a manual install. The Brother software is screwy. Read the tech manual.
http://www.brother-usa.com/ModelDocuments/Consumer/Network%20Users%20Manual/NUM_HL_2170W_EN_1292.PDF
Posted on Jan 21, 2009
Canon MG6460 won't print on Mac
new too mac osx software having trouble setting up my canon pixma mg6460 software? any help much appreciated
Nov 24, 2013 | Canon Office Equipment & Supplies
Filter failed
Go to "IP" in the add printer section. It is a "globe" at the top of the page. In address put the address of your printer there and name the printer at the bottom. Worked for me.
Aug 27, 2012 | Oki Electric Industry Oki C9650hdn 512mb...
How to add hp 2025 printer on mac laptop via wireless network?
Hi. There are two steps. First the printer must be connected to the wireless network - see the installation instructions that came with the printer. The mac is not involved in this part. Until you get it done you will not be able to do anything else.
Second. make sure you have the most up-to-date drivers for your printer installed on the Mac (this applies to any printer - not just your HP). Once the drivers are installed, go to System preferences and select "Print & Fax". and hen click on the + sign to add a new printer.
Wait a moment or tweo and the printer's name should pop up. Click it's name then wait for the drivers to be identified - this can take several minutes so be patient. As it's an HP you will probably get a bonjour connection but a word of warning, I have had more trpouble getting Macs and HP ptinters to work reliably over WiFi than any other make.
Apr 06, 2012 | Apple MacBook Mac Notebook
Printer has worked fine for years with my pc's. Still prints the test page fine but wont' print since I switched to mac. Installed the print only file from hp website a couple times. Actually it does...
It sounds like the driver provided by the manufacturer may have a glitch in it. I would recommend sharing the printer to the MAC:
Add the Shared Printer to Your Mac Launch System Preferences by clicking its icon in the Dock.
Click the ‘Print & Fax’ icon in the System Preferences window.
The Print & Fax window will display a list of currently configured printers and faxes that your Mac can use.
Click the plus (+) sign, located just below the list of installed printers.
The printer browser window will appear.
Click the ‘Windows’ toolbar icon.
Click the workgroup name in the first column of the three-pane printer browser window.
Click the computer name of the Windows machine that has the shared printer connected to it.
You may be asked to enter a user name and password for the computer you selected in the step above.
Select the printer you configured for sharing from the list of printers in the third column of the three-pane window.
From the Print Using dropdown menu, select the driver that the printer needs. The Generic PostScript Printer driver will work for almost all PostScript printers, but if you have a specific driver for the printer, click ‘Select a driver to use’ in the dropdown menu, and select the driver.
Click the ‘Add’ button.
Use the Default Printer dropdown menu to set the printer you want to use most often. The Print & Fax preferences pane tends to set the most recently added printer as the default, but you can easily change that by selecting a different printer.
Oct 03, 2009 | HP LaserJet 2550n Printer
Have just bought a Pogo printer. It printed once via Bluetooth but doesn't print via Bluetooth now. Removed battery for an hour- still not printing via Bluetooth.Can you help please?
If you are printing from a PC/Mac via Bluetooth, It won't accept anything other than Jpg's and also if the file name is too long (or if the file has multiple .'s in the name as I just found out)
Sep 24, 2009 | Polaroid PoGo Digital Photo Printer
"printer is currently off-line. offline" use a mac
check the usb cable of printer try to reconnect it and make sure you use usb port in your printer properties
May 24, 2009 | HP LaserJet 1300 Printer
IMac connection to lanier ld122
Does this printer have the PS option installed? If not you will be unable to print even if you clear up the network issue.
As far as network goes is it currently connected and working with other PCs?
Mac printing is easily setup by typing the IP address of equip in the queue box upon setup. I believe the default queue name is "print" all lower case. If IP in unable to work properly make sure lanier has appletalk turned on and setup printer using appletalk.
Again if the machine doesn't have Postscript option you won't be able to print anything.
Hope this helps,
TankMurdock
Apr 23, 2009 | Office Equipment & Supplies
Mac will not add printer
Hi, try to reset the print system as the apple article below:
SummaryWith Mac OS X 10.4, 10.5 or later, Printer Setup Utility includes a Reset Printing System feature, a troubleshooting function that you might want to use after you try all other printing troubleshooting stepsImportant: This feature should only be used as a "last resort" for troubleshooting a printing issue.
Products AffectedMac OS Printing/Fax (any version)
What does Reset Printing System do?
  • Deletes all printer queues and jobs.
  • Resets all printer settings to their default by deleting configuration files.
  • Performs a permissions check on the /tmp directory.
Any devices that previously appeared in your Printer List and Fax List will need to be added again after resetting the printing system.
Resetting the printing system in Mac OS X 10.5.x
  1. To use the Reset Printing System feature in Mac OS X 10.5.x, follow these steps:
  2. Choose System Preferences from the Apple menu.
  3. Choose Print & Fax from the View menu.
  4. Control-click on list of printers on the left side of the window, then choose "Reset printing system" from the contextual menu. If you don't see a list of printers, Control-click on the text "Click + to add a printer or fax" and select "Reset printing system..."
    As an alternative, if you currently have one or more printers listed, you can Option-click the "-" (Remove printer) button.
Resetting the printing system in Mac OS X 10.4.xTo use the Reset Printing System feature in Mac OS X 10.4.x, follow these steps:
  1. In the Finder, choose Utilities from the Go menu.
  2. Open Printer Setup Utility.
  3. From the Printer Setup Utility menu, choose Reset Printing System.
  4. Click Reset.
Additional InformationTip: If Printer Setup Utility won't open at all (possibly due to your printing issue), you can try to access the Reset Printing System feature directly by holding down the Option key while opening Printer Setup Utility.
Mar 14, 2009 | Apple Computers & Internet
HELP! woln't print
Unload the software. Delete the driver. Carefully read the manual Select the Mac version software on the CD
Mar 22, 2007 | Canon Pixma MP500 All-In-One InkJet...
Brother HL-2170W Laser Printer Logo
168 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
