Question about Radio Communications
Repair bear cat 101 police scanner
I have a 101 bear cat scanner it works but it dont work as good as it should, the u h f band works but is scratchy and has a hum in it when some one talks. and the signial is week on a close dispatch. the v h f works good and clear. can any one work on the u h f part of the bear cat 101 and make it work better ; thanks Norm
  • 120 Answers
First of all check the antenna connection, it could be dirty which causes more impedance at the higher frequencies than at the lower ones (uhf is higher than vhf), also hum could come from a power supply that can't produce enough current, does it get worse when you turn the volume up high? if so and you use a wall adapter, you might need one that has the same polarity and voltage but a higher current output, such as 400ma compared to 250 ma. If the power comes from a standard ac cord without the transformer (cube) at the wall outlet, then the internal supply might need a new capacitor in the filter circuit.
Posted on Jan 15, 2009
It depends on your location. Try this link
You will also need to know if your state and city switched to digital.
If not then it should work fine, but if they did you will need a new scanner because you have an analog scanner. There is a big push to switch over to digital radios in police, firefighter, military because it's more secure to use.
Oct 16, 2015 | Uniden Bearcat Model Bc142xl 10 Channel...
Radio shack iscan trunking scanner, pro-107
I no longer provide support for any scanners. As a Police Dispatcher I was working when two police officers were ambushed and killed because a person listening to a scanner told the suspects the police were coming. They should be outlawed.
Dec 19, 2011 | Radio Shack Radio Communications
What is ment be reflashing a police scanner
  • When police, public safety, etc re-band then some scanners may not pick up the frequencies and you need to update the firmware (when available) to keep your scanners ability to monitor certain frequencies, pairs of frequencies, splinter channels etc.
  • Hope this helps.
Regards, Tony
Oct 17, 2011 | Radio Shack Pro-96 Scanner
My pro96 hand held police scanner cuts out or breaks up when police are talking in differant locations of the city, at my house and surronding area it breaks up, at work 4 miles away it is great, i can...
Hi Bill, my name is John. Try checking your antenna for bad connections, also turn your SQUELCH to where you just barely here static, then slowly rotate it until it is clear. ...hope this was helpful
Sep 01, 2010 | Radio Shack Pro-96 Scanner
I bought A scanner in victorville and the guy who sold it to me said that it work the thing is that I can not hear anything when police or other people are talking What do I have to do to fix my problem It...
Make sure you have selected the correct frequency range and radio band.
The bands are usually Police/Fire/Air Traffic/Marine/and Short Wave. Depending on your geographic location, you may or may not pick up transmissions.
Also try using the auto-scan feature to seacrh for chat, and adjust the squelch setting so you don''t choke out too much squawk chatter.
Jan 13, 2010 | Office Equipment & Supplies
Motorola k7gt9500 police channel in manassas virginia?
Your Motorola radios operate in the FRS/GMRS band, which is at 462 MHz. Police, fire, EMS services, etc. operate in the 150 or 800 MHz bands. Your radios cannot receive public service transmissions, and they cannot be modified to do so. Monitoring public service transmissions will require a scanner.
For a comprehensive database of active frequencies and services in your area, visit:
For a good listing of available scanners, visit:
Jan 02, 2010 | Radio Communications
We have a police digital scanner havent been able to receive the police frequency wonder if they have been changed? i dont want to have to pay for this service just need new frequency numbers if they have...
Your community's public service radio frequencies may have been rebanded. Rebanding was the result of services throughout the nation being moved in the 800Mhz band.
Complete rebanding details of this can be found here:
The Pro-2096 scanner can be reprogrammed to receive your old services in the new band with software that is run on your computer and connected to the scanner. It is available for a small fee ($30). More information on this can be found below:
Many scanners are not capable of upgrading, and were reduced to "paper weights". Consider yourself lucky that a $30 upgrade will restore the full functionality of the radio. A great deal of information on your scanner can be found here:
I hope this helps!
Sep 29, 2009 | Radio Shack Pro-2096 Base Scanner
Need free codes for a base police scanner
hello there
please try these links they have worked for me
  1. Scanner Frequencies & Codes Free Trunked Fleet ID's for your area (Works with Scancat) Military Base Operations Frequencies ... Get a scanner frequency list by email for your county, - Cached
  2. Portland Police Scanner | Portland, Oregon Crime & Emergency Dispatcher ... ... use of a Trunk Tracking Scanner and entering the Talkgroup codes listed in the next section. ... your Business Listing for free. Obits / Death Notices - 64k - Cached
  3. Scanner Feeds ... Feeds Police Codes Police 11 Codes General Codes General Acronyms ... They are free. ... Big Bear, California Police Scanner (web-based) Los Angeles Police - Cached
Sep 15, 2009 | Uniden Radio Communications
Dont no how 2 get police chanel or others thank u
try to scan frequency range bet 140 - 160 mhz in VHF range and 300 - 400 in UHF range for police frequencies..... ;-)
May 24, 2009 | Uniden BC92XLT Handheld Scanner
Bear Cat 145xl entering local police frequency
your scanner probably does not have enough number space. your scanner can not take more than 7 numbers. the same as mine.
Nov 13, 2008 | Uniden BC72XLT Handheld Scanner
Radio Communications Logo
146 people viewed this question
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
