Question about GE JTP15 Electric Single Oven
JTP15 GE Oven - vibration noise
My oven has begun making a vibration noise when the fan comes on. How do I check the fan or change it so it stops the vibration?
  • Anonymous Feb 10, 2009
    Our fan vibrates as well--can't see how to fix it. The oven is 9 years old. Otherwise works fine.
We have a double ge wall oven. The vent fans had become really loud. I checked the price for new fans...$275 each! Plus service of $200. If your oven is not too old, go to GE service purchase a 1 year service contract for $93.00. Wait one one month till it takes effect. Call them and request service and the entire replacement is free.
Posted on Mar 04, 2009
De dietrich range cooker very noisy when oven on?
Have you checked the exhaust fans within the oven? These can make a lot of noise if something has come lose. They should be located at the top of your oven or on the back. I would check that.
Good luck
Dec 05, 2013 | De Dietrich Ovens
How do you replace and oven sensor in a JTP15 wall oven?Getting F3 error code and ordered the part today but it doesnt come with instructions.
You will need to shut off the power and remove it from the wall. Remove screw holding sensor from inside oven. Then pull rear panels off to access rear of machine, be sure to tie a string to the old sensor wires so that when you pull them through you can tie the new wires to that string to make it easier to pull them back through. Plug new sensor wires in, put oven back together and re-install.
Please rate my solution if it was helpful.
Thanks, Repairman45.
Dec 02, 2010 | GE JTP15 Electric Single Oven
My Candy TC21 oven makes a vibrating noise when on, why is that?
There are only 2 moving parts in your oven when it is running - the fan and the fan motor. If a bearing is worn or the fan blade is damaged, this can cause vibration. However, the actual noise could be could be coming from some other part of the oven which is insecurely fixed, e.g a panel, internal shelf, the oven/grill element - pretty much anything!
Basically, the fan/motor causes the vibration and a loose part causes the noise.
Hope this helps.
Regards,
BElectric
Nov 14, 2010 | Ovens
Our JTP15 beeps and displays F7 is there a reset for it?
Yes, you will need to press the stop/cancel button, this will clear the error code and the display.
Nov 14, 2009 | GE JTP15 Electric Single Oven
Ge oven JTP15 beeping and flashine F7 error
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Jun 17, 2009 | GE JTP15 Electric Single Oven
Bake element stopped working on GE JTP15 oven
Mine did the same thing twice. There is a high temp safety switch on the back of the cabinet. Every time my wife runs the self clean cycle, the switch goes out. If you remove the oven from the wall, you'll see it. It should be normally closed if you check continuity.
Jun 04, 2009 | GE JTP15 Electric Single Oven
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
Ge wall oven will not heat up on bake,boil or clean cycle
GE JKP86BF3BB COMBO MICRO/ELECT OVEN
NO HEAT ON BROIL OR BAKE ELEMENTS
CKD WIRING FROM PANEL OK
CKD TERMINALS AT ELEMENT HAVE 120V ON EACH ELMT
FAN COMES ON
THE ON INDICATOR SHOWS WHEN TMP &START PUSHED
MICROWAVE WORKS FINE
I ORDERED A NEW BAKE ELEMENT TO TRY-NOT HERE YET
STUMPED
Mar 16, 2009 | GE JTP15 Electric Single Oven
GE JTP15 Electric Single Oven Logo
1,085 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
