Question about Frigidaire FRT21P5A Top Freezer Refrigerator
Moved fridge now it does not cool bottom or top
Did not tip fridge moved easily from one house to another
is there a reset?
  • Anonymous Jan 14, 2009
    all wires connected
  • Anonymous May 14, 2009
    Fridge plugged out for about 3 months or so. When it was plugged back in, the light on the inside works but there is no sound whatsoever, no cooling either.
    President:
  • Frigidaire Master
  • 2,651 Answers
No reset bur perhaps a wire has gotten knocke doff, check bvehind the lower acees panel behind refrif for a wire off,
Posted on Jan 14, 2009
Bottom fridge has stopped working. Top freezer is okay. Fridge light is working and thermostat is making operating noise, just no coolness.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 26, 2011 | Avanti FF510 (5.1 cu. ft.) Top Freezer...
Top freezer workin, bottom part of fridge not cooling at all
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 30, 2010 | Kenmore 64802 Top Freezer Refrigerator
The top is not cooling
heatman101
Apr 01, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
Fride not cooling
heatman101
Aug 04, 2009 | Amana ARB9059CS Bottom Freezer...
Fridge only cool
I have a couple of solutions. One is a solution you may be able to do, and one is for the pros.
Pull the Frigidaire away from the wall. Unplug the refrigerator. Depends on the skills of the person involved, but this should not take more than 15 minutes, tops.
On the back at the bottom is a panel, made of a fibrous, paper like material. There are screws that go around it. These need to be removed. The AC power cord coming into the refrigerator, has a clamp with a screw, that holds the cord to the refrigerator. This needs to be removed, so the panel can come off. (May be two clamps)
Now take a flashlight, and look. Is this area dirty? Usually it is. Dust/dirt/spider webs, you name it. Doesn't matter how clean a housekeeper is, you can't get in this spot.
If it is dirty, this stuff needs to be removed. Time for a vacuum cleaner, and a wand tip.
Also, be sure this panel is present. I've seen some removed by accidental breakage, when moving the refrigerator from house to house. If it isn't there, the refrigerator compressor cannot cool off enough.
The refrigerator, also needs to stay at least 1 inch away from the wall, of those exposed tubes on the back.
If this doesn't do it, then you have a slow leak, and your refrigerant is leaking out. You need to have a pro find this leak, fix it, and recharge the refrigerant.
Apr 28, 2009 | Frigidaire FRT21H8 Top Freezer...
GE Side By Side top portion of fridge and freezer not cooling
heatman101
Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
Compressor constantly on too hot to touch
hi have you cleaned the matrix best done by blowing with air but a soft brush can work,make sure that all the cooling vanes are clear
hope this helps ian
Jul 21, 2008 | LG LRTN22324 Top Freezer Refrigerator
Fridge not cooling
Make sure coils underneath or backside are clean of dirt. Make sure compressor is humming when running. You can tell by moving fridge out and it will be at the back side of the opening on the bottom side of fridge. It will be about the size of a soccer ball. If it has a little of vibration and might be alittle warm to touch. Also open door and make light comes on inside. In newer homes these days they are using ground fault interceptors. Even tho this one is not plugged into one that has the resetable breaker check other walls for one that does have the little red and black push buttons. They sometimes wire some into one ground fault, when that pops, it shuts power to the others. Our house is that way, I have to go to our bathroom and reset it to make the ones in the kitchen work.
Nov 30, 2007 | KitchenAid Superba Architect KSCS25INSS...
Frigidaire FRT21P5A Top Freezer Refrigerator Logo
238 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
