Question about General Electric GE 29520 Switch/Fuse Cord For Elusion Lighting, LED Interior or Exterior Au
Interior light switch not working
Its a ford focus lx 2003, the interior light just does not work, when i open the door or put the switch on it does not want to work. av tried all the fuses behind the glove compartment, changed the bulb, checked to see if any of the wires were loose but no luck plz HELP!
  • bob white 51 Feb 08, 2009
    My mechanic doesn't have a solution either.
  • 36 Answers
Check for power at the bulb socket with a test light, making sure your test light has a good ground, then touching the probe to the power terminal of the bulb socket, having the door open or the switch on. if power is there then check to make sure you have a ground at the socket by hooking the test lite to power then touching to the ground terminal of the bulb socket. you must have both ground and power to make a bulb light.
Posted on Feb 13, 2009
Where do I find my interior light delay relay on my car
No relay fitted . works on doors witches and switch on cab light , cab light has a off on position.
Mar 18, 2015 | 2003 Ford Focus
Ford Focus CL 2003, Door open light keeps flashing, indicators either trip out or go double speed when door open light on.
At the door jam,check the condition of the pin switch. The switch may be cover with a boot.
Compare the condition of this pin switch to the working side.
Clean the general area and re-test.
Jan 19, 2014 | Ford Cars & Trucks
2003 ford windstar interior lights stay on when key is taken out of ignition but work properly when key is left in after turning off. What would cause this?
there is a dimmer switch to dim the dash lights. when you turn it all the way over it turns the interior lights on it is the same switch as your headlights.
Nov 26, 2013 | 2003 Ford Windstar
2003 ford explorer driver side door lock keeps opening and closing. interior lights stay on while driving
Interior Lights - Check door ajar switch, its possible that go to bad.
Door Lock - Check ground connections and test switch.
Rare but possible, re-synchonized security module.
Sep 30, 2011 | 2003 Ford Explorer
How does child lock work on ford focus
generally on the rear end of the door, visible only when open, there is a mechanical switch which will disable the interior door latch. means it can't be opened from the inside. If you are going swimming with the car, disable it so you can escape from the back seat.
Oct 04, 2010 | 2003 Ford Focus
Interior lights won't go out. I closed all the doors and moved the switches
Make sure that the thumb wheel switch is not turned all the way up. If this is ok then take some WD40 and spray a liberal amount into the door latches and open and close the doors firmly a few times to see if this unsticks the door ajar switches.
May 24, 2009 | 1996 Ford Thunderbird LX
Door lights not turning on when the door is opened
Windstars have problems with door switches. The last owner likely clipped the wires to the defective switches because the lights would not go off.
Feb 27, 2009 | 1999 Ford Windstar
2003 ford Focus - Intermediate clicking noise
you have a defective courtesy light switch that is causing the relay to open and close, that is the clicking u hear, this flashes the courtesy/interior lights on and off.
Jan 29, 2009 | 2003 Ford Focus
General Electric GE 29520 Switch/Fuse Cord For Elusion Lighting, LED Interior or Exterior Au Logo
323 people viewed this question
Top General Electric Electrical Supplies Experts
Craig Butler
Craig Butler
ken skalski
David Harrelson
David Harrelson
Are you a General Electric Electrical Supply Expert? Answer questions, earn points and help others
