Question about Sunbeam 5891 Bread Maker
Sunbeam breadmaker Stopping a cycle once started
I made an error in programming my new breadmaker, and decided to stop the process. I diconnected the power and removed the mix, but do not know how to stop the cycle and get the machine back to where I can reprogram it... Do I have to let it run through the full cycle ( even without a product in the machine?) It is currently on a three hour cycle.
Or should I do a mix and see how things turn out!!
This is a brand new machine, not yet used except for an experimental quick bread.
thank you for advice
  • 19,396 Answers
Hold down the start button for ten seconds.
Here is company website.
Here is online manual.
For more info, call call 1 800-667-8623
Posted on Jan 14, 2009
    Genius:
  • 1,269 Answers
Its up to you if you wanna do the mix again. But its ok, You can let it run the cycle without the mix.
  • 55 Answers
If you make a mistake or wish to start over, press and hold
down the “Start/Stop” button until you hear a beep. The display will
show the original setting and cycle time. The Delay Timer is canceled
and you can start again.
This is from the manual found at: http://www.sunbeam.com/Manuals/MANUALS/005891-000-000_43_4357793.PDF
How to use machine sunbeam oster bread making machine model 4811
go google and type in--operators manual for sunbeam bread maker model 4811-- and if there is a manual available in pdf version down load it
just be aware that with these machines there is a period in the program where after the needing process, it stops for a period to allow the dough to rise before it goes to the cook process
most machines work on the same principle so if you can not find a sunbeam manual see what else is available and check it out
Feb 21, 2016 | Sunbeam Oster 1.5 To 1 Lb Bread Maker...
Sunbeam bake house compact, baking component broken, can this be repaired
Which program are you choosing? Basic, whole wheat, french, dough etc. Knowing that may help me answer your question.
Jan 09, 2013 | Sunbeam Bakehouse Compact Breadmaker...
Sunbeam 5891 Breadmaker stops for several seconds
It is normal. It allows the dough to fall back on the mixer blade. Often these reverse and that also gives the motor time to come to complete stop before reversing.
Aug 21, 2009 | Sunbeam 5891 Bread Maker
Reset sunbeam breadmaker
Press the start/stop button for 15 seconds.
Hank
Aug 20, 2009 | Sunbeam 5891 Bread Maker
My Sunbeam breadmaker runs all cycles but doesnt mix.Breadpan is
Bread Machine Replacement Parts If you are having problems with your bread machine you may be able to fix it with replacement parts. That is if it is the paddles or the pan you are having problems with. If it is something within the bread machine that is not working properly then you probably won’t have a lot of luck finding these bread machine replacement parts.
Keep in mind the price of the bread machine replacement parts as well. If they are very expensive you will be better off just buying a new bread machine. But, if your bread machine was really expensive and is still in good shape and the replacement parts aren’t that much, then the replacement parts might be a better option for you.
Most bread machines work well for years without the need for replacement parts and many machines have warranties as well. But, if you are having problems then you will need to decide if replacement parts or a new machine are the right option for you. If you need replacement parts then call the manufacturer of your bread machine.
Apr 05, 2009 | Sunbeam 5891 Bread Maker
Bread is overly dry and coarse textured
You're doing everything great with your ingredients. Listen to your machine or watch it. Stop it before the bread is in the rise cycle and restart it after the kneading cycle.Try running the knead cycle two times, then the rest of the baking cycle. If the bread is still too hard try using the kneading cycle three times. This process is trial and error, but I firmly believe this will solve your problem as it did mine.
Dec 10, 2008 | Sunbeam 5891 Bread Maker
Sunbeam 5891 Bread Maker Logo
Top Sunbeam Kitchen Appliances - Others Experts
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
