Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
High Electrical bill - Appears to be heatpump problem.
Tenant complains that electrical bill jumped 3 times as much as month before, even thou noone was . 2 level Townhouse - All Electric property- Central Heat and Air system. Has heatpump with zoned programmable thermostats (2 thermos, 1 up, 1 down). The tenant state they turned the upstairs thermostat off, and had the lower floor thermostat to 71 degrees. They say that the outside unit runs constantly, the only way to get it to stop is to turn off the downstairs thermostat. The townhouse was built in 2003, but the outside unit was replaced in 2008.
Could this be because they turned off the upstairs thermostat? Should I try to replace the downstairs thermostat?
  • 1 more comment
  • ballardr Jan 14, 2009
    I will be visiting the property tomorrow evening. Will check. Thanks for the suggestion.
  • ballardr Jan 28, 2009
    Thanks for your replies.
    I checked out the system myself. It had been serviced last year.
    They system appears to be working ok.
    But: The heating unit in the attic had some duct work where the tape was not sealed properly. A lot of heated air was escaping into the attic. I sealed with aluminum duct tape.
    Also a few of the windows needed weather stipping (and a few were not locked so the cold air was getting in.
    I think the main problem is that the tenant had the upstairs thermostat off, with the downstairs on.
    And Georgia Power went way up on rates!
  • dwkcool May 11, 2010
    first see if the unit is blowing air up stairs with the upstairs t-stat off if so turn it back on and turn down as low as you can get it , some zone systems require the stats stay on for it to operate correctly
    New Friend:
  • 70 Answers
Sound like there are running on emergency heat which is elrctric.Have the system checked out buy a local heating and cooling company. Have they checked the filter and changed them.
Posted on Jan 20, 2009
Have a Coleman air-condition no power in or outside I had the large capacitor replaced about 3 months ago because compressor failed to run.All breakers have been checked any ideas?
C'mon, get real!!!!!!!!!!!! If you have no power in or outside how can the breakers be any good? Pay your utility bill?
Outlet in wall good? Power cord ok? On/off switch checked?Thermostat?
Aug 18, 2017 | Coleman Heating & Cooling
I would like to complain about a company unreal electrical who installed my prepaid meter and not informing me as a owner that the meter is actually for a tenant.
do you feel better after complaining? this isnt the place to complain. we answer peoples questions when and if we get enough information to answer correctly. good day
May 23, 2017 | The Computers & Internet
I have a complain on the electricity usage because every month we pay more than what we used and we don't receive any bill of payment any more. you can contact me on 0715284471
In Uk they don't send out paper itemised bills now you have to get them on line maybe your network provider does the same?
Apr 11, 2016 | Cell Phones
Have a 2004 CRV hesitates or jumps on excelleration code 2647 is what it reads. I have already changed the oil pressure switch but it is still doing the same thing. Any help would be appreciated.
P2647 VTEC oil pressure switch circuit high. The letter P stands for power train.When a code P2647 comes in the shop VTEC oil pressure switch usually fixes the problem. In front of the vehicle on the right hand side there is a VTEC solenoid valve one one the intake.Right next to it is the VTEC oil pressure switch . Both have grey connections. If you complain about rough idle then yes service solenoid (they do plug up from low end oil or lack of oil maintance).The code is circuit.that means that battery voltage has to be present. When the code P2647 appears VTC is disabled and valve timing is fixed at a fully ****** position.This is where you say you feel like its running out of gas is from.Switch is you just replaced it, a electrical diag has to be performed.From switch to PCM
Feb 29, 2012 | 2004 Honda CR-V
Stove causing a very high electric bill
Hello...There are several factors to consider....It's normal for the meter to speed up when you use the oven because the heating elements are high current devices...Several questions come to mind like do you use your over normally on a daily weekly basis??...Do you live in a house or apartment??..What about you heating system..did you use space heaters? or use the over to heat the house? what about Christmas lights and other decorations that use electricity...Were these all current charges?If all this checks out...I suggest you post a complaint or inquiry with your electric company...Let me know the outcome...I hope this was helpful.....PEACE...
Jan 24, 2012 | Stoves Ovens
I want to reduce my bail of electric every month
To reduce your electricity bill please do the following:
1. Make sure that you use only and only those lights you want at a time.
2. Use low rating electrical gadgets like bulbs - 18 to 20 watts(energy savers), kettle/cookers/hot plates - 500 to 1500watts, flat irons - 800 to 1000watts, etc
3.When you are boiling on a cooker, when some food boils - you can turn the rating lower using the knob. Don't keep the knob high all through boiling.
If this solution is helpful, please rate me accordingly. thanks
Aug 12, 2011 | Computers & Internet
I puchased 5 year old home back in July and up until the last few months my electric bill has been any where from 800kwh to 1500kwh. It jumped in December to 3880 and 4500 in January. My home is 2400sq,...
You will need to have a HVAC tech to check your Heat Pump..... It is not working or not heating properly....And you are heating the house with the electric heat strips which will make your electric bill double The electric heat strips are there as back up if the heat pump is not working or keeping up with the heating demand.
Feb 12, 2011 | Heating & Cooling
What does energy saver do ?
Hello there
Energy saver alows you to minimize the amount of energy used to run the appliance efficently thru different settings on the appliance
To use the Energy Saver option:
  • Press the control to On to save energy when the environment is less humid.
  • Press the control to Off when the environment is warm and more humid, or if moisture is noticed on the hinged seal.
  • I hope that this has been very helpful for you
  • Best regards michael
Nov 06, 2009 | Roper RS25AEXLQ Side by Side Refrigerator
I am a manager of a 40 yr old townhouse complex in Langley B.C. I have a tenant that is a nightmare, to say the least, this tenant is asking that the suit be totally rewired to meet the electrical code of...
I'm not sure of the laws in B.C,as they seem to change from province to province and from year to year.
However I do know that my in-laws recently had to redo their wiring (60 year old home).
The biggest problem they had with the old wiring was that you could only run a few light bulbs/one appliance at a time,as there wasn't enough power.
My MIL kept complaining that she was getting shocks from the stove as well.Seems that there were some grounding issues.
Your best bet is to try They should have the answers you are seeking.
I would also consult with an electrician as they should know the laws there.
Perhaps run a quick test or two/check for faulty wiring, to pacify the tenants.
Check with your insurance company as well to see if the building meets their specifications.
Good luck with your tenant.
Sep 21, 2009 | Model Power N Scale Building [1513]
Heating & Cooling Logo
221 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
