Question about Bose Lifestyle 18 System
Connect my remote of my bose lifestyle 18 to my samsung 46a 650
I got a new Samsung 46A 650 HDTV and I have the Bose Lifestyles 18 surround sound system I can't get the remote for the Bose to work turning the tv on and off.
  • Anonymous Feb 05, 2009
    I am having the same problem with a Samsung 650 and a Lifestyle 30 remote. I am able to control the Samsung Bluray with the Bose remote
  • 18 Answers
Hi, have you tried going to the system settings menu adn program your 3rd party products htrough there? You may try varied IR code settings for your electronics from there and one of those codes should work atleast for your system. There may be some codes you will get to use but does not have all the funcitons so you need to be patient to try them all.
As per the Blue-Ray DVD, the remote code might still not be embedded on the IR controller chip that is installed in your Lifesytle (after you have tried all the codes and still none works). Bose does release regular firmware updates via their user mailer (if you have registered your product online) or you may passby any of the Bose service center and request them to provide you with the update disc specific to your system version (look underneath the DVD player and the bass module they should indicate AV-- and PS-- models).
Glad to be of service...
Posted on Apr 08, 2009
Bose Life style 12 problems with new samsung tv
Hi Candy,
On the back of your satellite box you will see a pair of Audio Out RCA jacks. One will be red, one will be white.
Simply run an RCA cable pair to the 'AUX' jacks on the rear of the BOSE.
That's it!!
Let me know if I can help you further. I will be here if you need more help, info or have a follow up comment or question.
In Case You Still Having Brother Printer Problem Then Follow Us for On: Support Services
Jan 24, 2014 | Bose Lifestyle V20 System - black Theater...
My HDTV does not have RCA audio out option to connect to my Bose Lifestyle 12 surround system. Can I connect the Directv box directly to the lifestyle12 system to get surround for the TV? I would do...
Just make sure that you are using compatible connectors and that your signals are compatible. Ie. analog out to analog audio input, digital audio to digital audio input.
Sep 21, 2017 | Bose Lifestyle 12 System
Not good surround sound Is the bose lifestyle 5 support 5.1 surround sound?
The Bose Lifestyle 5 is not a 5.1 surround sound system. It is a 2.1 sound system, meaning it is stereo with a subwoofer/bass unit. Having two speakers that can be angled in different directions, the Bose Lifestyle 5 employs Bose direct/reflecting technology,providing greater audio presence. Still, it is definitely not a surround sound system.
Jan 24, 2010 | Bose LifeStyle 5 Series-III CD Shelf...
Can a remote for a Bose Lifestyles 18 system control a Bose Lifestyles 5 system?
Yes you should be able to. The house code needs to be the same etc (adjusted by the dip switches under the battery cover) Google for the pdf instructions on how to set them.
Nov 06, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Connect lifestyle 48 to plasma and dvr
You need to buy a Bose VS 2, video enhancer. Your cable/sattelite, vcr and aux connect to the VS 2 and the VS2 connects one HDMI cable to the TV. The VS2 then upconverts DVDs played on the lifestyle through the VS2/HDMI.
Sep 10, 2009 | Bose Lifestyle 48 System
Bose Remote not linking to Samsung HDTV
I got my bose remote to work when I did a system update on the remote. Turn the TV on. Select the TV video input that connects the system. On the control console, press and hold setup until the system information screen displays. line 5 will display the currently installed console software version. on the remote press any button. Line 10 will display the currently installed remote software version. Do a bose system update. On the control console press setup. on the remote control, press the down arrow until update is highlighted and press ok. make sure yes is highlighed and press ok. on the control console plug a clean usb drive into the usb port.when prompted, remove the usb drive and connect it to a computer. open the drive and double click on the download_launcher file, which should bring you to an update page on bose.com. Once complete, put it back in the control console. When the update is complete remove the usb.
Feb 22, 2009 | Bose RC-28S stereo expansion kit - White...
Running my Blu Ray DVD thru the Bose Lifestyle 18
hi there,
1-connect the blu-ray to your tv via hdmi cable and this will run picture.
2-connect the blu-ray via digital optical cable to the optical input on the bose system. then using your bose menu, (system menu)set your auxillary sound output to digital optical.
when watching dvd thru bluray player select aux on the bose and you're away.
good luck
Jan 31, 2009 | Bose Lifestyle 18 System
System Info from Bose not displayed on Samsung TV
Unplug the power cord and plug it rght back in, I had this same problem and was troubleshooting forever.
Jul 19, 2008 | Bose Lifestyle V20 System - black Theater...
Lifestyle 12 speaks - new HDTV
mount to wall, brackets available to purcahse on loads of on line sites. and from bose direct cost 5 dolurs to 50 dollars eack depending how fancy you want to be.
would recomment also distancing the left right satellites as you will be amazed how much improvement in sound is gained from a well defined centre channel.
also if you want to be really smart. its really not necessary to see the centre satelliet and it could simply sit of the stand behind the tv. with no problem. plus you could use the tv audio input to make the tv as a centre channel. you would be surprised how well that works. make sure you disable the tvs steroe function or your surround sound will not sound too surround....
finally if you have lifestyle series II make sure you conect the 5.1 input to the bass box to your tv. and get rid of the bose cd player , put it out of sight, and loose the remote. will work even better than it did before !
Jan 02, 2008 | Bose Lifestyle 12 System
Bose Lifestyle 18 System Logo
980 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
