Question about LG DLE2512W Electric Dryer
LG dryer works except it does not heat?
The dryer works it just doesn't heat and dry clothes
  • 3 more comments
  • Anonymous Jan 16, 2009
    the dryer works but no heat to dry cloths.
    please help, if any one had the same problem that I had
  • Jim Mickle
    Jim Mickle Jan 31, 2009
    I have the same problem, the dryer runs fine but does not heat. Unfortunatly, when we purchased it a year ago we put it into storage until the kitchen was finished (a year ago) and just now realize that it doesn't work!
  • mkd_programm Feb 16, 2009
    It works fine except doesn't heat. cloths still wet.
  • Anonymous Feb 20, 2009
    my dryer gets some heat but takes 2-3 cylcles before it dries anything
  • Anonymous Mar 14, 2009
    Seems to get some heat but takes an exceptionally long time to dry. Sometimes does better on time-dry than on sensor-dry.
I had the same problem before and all that needed to be done was to tighten the 220 plug to the dryer. Try doing that before anything else.
Unplug first!!
Posted on Mar 01, 2009
  • 66 Answers
SOURCE: Dryer not heating Enough
Ceck the vent hose and vent. Make sure these are clear of obstruction. This is tipical of poor venting. The dryer can`t remove the moist air to dry the clothes properly.
Posted on Nov 14, 2008
Washer_tech
  • 164 Answers
SOURCE: Tumble Dryer not drying clothes
the problem could be several different things. first remove the front panel and see if the globar glows. if it doesn't check it for cracks and replace if needed. if it glows, replace your gas coils, they are usually the problem
Posted on Nov 01, 2007
  • 686 Answers
SOURCE: Dryer is working but not heating up or drying clothes
bad heat element
Posted on Feb 20, 2009
  • 142 Answers
SOURCE: LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Posted on Sep 28, 2009
burdfrenzy
  • 348 Answers
SOURCE: Dryer heats up but doesn't dry clothes...
Sounds like you have a heating element out. Sears website can help you.
Posted on Oct 15, 2009
LG DLG2251W won't heat up
Your post is from 2008 but I am having the same problems with this dryer, same model. This is an LG problem, for crying out loud LG ---- GET IT FIXED. No more LG dryers for me. My $300 Kenmore works like a charm.
The first LG dryer they sent me I thought was a lemon. They came out and replaced the motherboard on the brand new dryer. They came out again and couldn't figure out why it wouldn't dry my clothes, and the second time they gave me another brand new dryer. Same problem with this one and all brand new perfectly clear ducts. Really?????
Google "lg dryer spins but no heat" on youtube - he explains how to get to the sensor and reset it, but still trying to figure out where to find it on my model. I can't believe I have to go through all of this with a $1000 machine!! Never ever again. Avoid LG dryers at all costs. It takes me HOURS to dry a load of laundry. Wanna throw a dry piece of clothing in the dryer for a few minutes to get the wrinkles out? hahaha think again. The heat will never come on even with the manual (non sensor) setting.
Again = AVOID LG DRYERS AT ALL COSTS. It's not worth the headache.
Nov 25, 2012 | LG DLG2251W 27" Front Load 7.1 Cu. Ft. Gas...
My LG front loading dryer doesn't dry well
Check the exhaust vent when running and be sure there is a good flow of air. You may have to clean the exhaust pipes all the way through. Dryers require a good flow of air for proper operation.
Jan 10, 2012 | LG Dryers
Clothes not drying
Clothes not drying? Thats it? Does the dryer turn on at all? Does it tumble the clothes but doesn't get warm? If it turns on and tumbles but takes a long time to dry, then your heating element is not working. There is a thermal fuse right before the heating element that will open up if the vent becomes clogged and its gets too hot. The thermal fuse is not resettable and will have to be replaced. If the thermal fuse is o.k. then your heating element could be burned out. These two items almost require an electrical meter to read continuity to check them. Make sure the dryer is unplugged before checking these items.
Dec 21, 2011 | Zanussi TC7114W Electric Dryer
Hello, my dryer doesn't dry the clothes. What seems to be the problem and how can I check it on my own? Is it the heather, the thermostat or something else? The machine works fine except that its not...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 11, 2011 | Dryers
My dryer doesnt heat. I checked the voltage, and ran through all the diagnostic tests to try to get an error code. Everything works fine when in the test mode. Figuring that all was well i went back to...
heatman101;'
Jul 17, 2011 | Kenmore 84072 Electric Dryer
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
Dryer does not heat up/ dry clothes
sound like heater or stat call them out.
Sep 28, 2009 | LG DLE7177 Dryer
Sep 28, 2009 | Dryers
LG dryer (model DLE3733W) takes forever to dry the clothes.
check your vent hose for a clog. If dryer dont vent clothes wont dry.
Aug 25, 2009 | LG DLE3733 Electric Dryer
Nov 14, 2008 | Hoover HDC6 Electric Dryer
LG DLE2512W Electric Dryer Logo
213 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a LG Dryer Expert? Answer questions, earn points and help others
