Question about Sharp R-1514 Microwave Oven
Interior Microwave doesnt come on..Burned out?
How do I access the interior Microwave light?
Sharp #1514 carousel
Its easy to replace the bulb. 1. Remove the front top grille (just above the door - it has 3 screws only); one in the left, center, right. 2. Once the grille is removed, their will be one screw on the right hand side that hold the screen panel. Remove the 1 screw and the screen panel will be able to slide out. 3. Look inside, in the mid point of the cavity towards the left, there will be a socket (typically white), unlock it counter clockwise, and the bulb will be exposed.
The bulb is nothing special, once removed, you can go to Home Depot or Lowes and find it.
Work your way backwards to put everything together.
Labor time: 10 min.
Posted on Sep 01, 2012
  • 25 Answers
If it doesn't have a door you have to remove the cover. Its likely a special microwave bulb and the socket will have to be replaced with the bulb. the bulb is built onto the socket.
Posted on Jan 14, 2009
What light bulbs are for a Sharp R-1502 carousel microwave?
Hi,I would try (www.espares.co.uk),you can put the model in and it should give you the right lamp for your microwave,all the best.
Feb 05, 2018 | GE Microwave Ovens
HOW DO i CHANGE THE BULB IN MY SHARP R-651ZM MICROWAVE OVEN
Changing the light bulb on your Sharp carousel microwave will allow you to have needed light inside the oven. Microwaves are not designed for consumers to change the light bulb due to manufacturer liability, but it can be done. Following the proper steps will ensure a successful installation. Step 1 Unplug the Sharp carousel microwave from the electrical outlet.
Step 2 Locate the screws around the outer cover of the Sharp carousel microwave and unscrew all the screws.
Step 3 Lift off the covering.
Step 4 Locate the bulb and unscrew. Screw in your new bulb.
Step 5 Replace the cover and screw back tightly. Once done, test your new bulb.
Oct 10, 2017 | Sharp Microwave Ovens
Burned my turntable support
You can order Sharp microwave parts from Encompass here or you can call them toll-free at 866-779-5835.
May 13, 2010 | Microwave Ovens
R-8350, No power to touchpad, but interior light works
The touchpad has its own fuse which has probably blown due to a surge perhaps related to the turning on of the fridge. Removing the cover from a microwave is potentially lethal due to the large capacitor to drive the magnetron. However, this is usually well away from the front panel. If you do venture in you should first unplug the unit and when the outer cover is removed, discharge the large capacitor with well insulated pliers -= otherwise keep well away from it. The fuse you are interested in is on the pc board behind the touchpad. Replace it with exactly the same fuse (usually a slow blow fuse).
Sep 22, 2009 | Microwave Ovens
I have a sharp microwave oven R 1514. there are 4 buttons on the front and one is broken, will not pop back out. I bought new springs and need help with the installation
It looks like you need to remove the unit from the wall, remove the outer cabinet sheet metal, then remove about 6 screws from the backside of the control panel.
You should be able to tell as you get in there what needs to be removed.
But it doesn't look like you can access to replace without taking the outer cabinet off.
Jan 24, 2009 | Sharp R-1514 Microwave Oven
Sharp microwave R-1514
The control / display unit is Sharp part # CPWBFB076MRU0. Retails for $76.99 plus shipping.
You can order from Martin Microwave Inc. - toll free 1-877-894-0035
You can check the website (www.martinmicrowave.com), but they don't have the boards available online.
Oct 20, 2008 | Microwave Ovens
Melted carousel in microwave / bad smell
For the smell, do a Google search for "smell microwave" or "odor microwave" for many great tips.
If you need a new turntable support, you can order Sharp parts from Tritronics at http://www.wehaveparts.com
It's part # FROLPB017MRK0
Nov 03, 2007 | Microwave Ovens
Sharp R-1514 Microwave Oven Logo
231 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
