Question about Garmin Forerunner 305 GPS Receiver
Garmin forerunner 305 keeps turning off
I have been using my garmin for quite sometime. For some reason it turns off one or two times during my hour walk. It is driving me crazy. It is not a battery is low problem so I just can't figure it out. I walk almost the same route everyday but I don't think it is turning off necessarily in the same exact place. Please help.
  • 1 more comment
  • ezdozt Jan 28, 2009
    As I attempt to strap my watch on when I go running my watch turns off. Almost every time now. It is very frustrating. Can I fix on my own?
  • akosprime Feb 02, 2009
    Same thing with me. It will turn off all on its own randomly whether inside or outside, but I can almost guarantee a turn off by choosing the up arrow button after choosing the mode button.
  • jcarlisle Mar 26, 2009
    I have the same problem with my garmin turning off while placing it on my wrist. I took the suggestion to remove the cover and bend the contacts up. However, now I cannot get the top to stay on securily. It appears that there is a sealant that holds it on, it doesn't clip on, any suggestions?
The problem is that the connectors inside the garmin are not consistently touching. You need to open the unit and bend the little prongs on the screen side out a bit so that they touch the connectors on the other side of the unit when closed. I did this with my unit and it touch car of this.
Posted on Jan 25, 2009
1.Open up the unit by carefully inserting a blade and twisting it on the lower left or lower right of the watch along the seam.
2.Bend the connectors (inside the watch) upwards as to increase conductivity between two parts of the watch.
3.Apply silicon along the seam as to glue the two parts back together.
Posted on May 07, 2010
Same issue. The problem was that the cover was loose. Used marine silicon sealant and no problem. What a terrible design
Posted on Sep 12, 2010
Why does it quit randomly during cycle?
If you cleared the drain pump trap of obstructions, and the pump still runs fine(without rattling from a loose or damaged impeller) then most likely you have fixed the problem. The washer will not spin if it can't drain--and if the water is draining too slowly, it will time out and give an error code for "slow drain". For any items such as bras, underwear, socks, baby socks, stockings, pantyhose, etc, use a netted clothing bag with a zipper to prevent those types of things from getting pulled in-between the basket and tub and then making it to the drain pump trap. These things are notorious for clogging pumps on front load and top load HE washers!!
Aug 02, 2015 | GE Washing Machines
IS THERE A PROBLEM WITH THE BATTERY
Battery life according to Garmin is about four hours with the rechargeable Lithium battery. During the use, it last anywhere from three hours and fifteen minutes to three and half hours.It does happened that sometimes the batter die and won't let the GPS to function properly.
Sep 05, 2010 | Garmin nuvi 255W GPS Receiver
Scanner code 327, EVP/EPT voltage iow
fuel pump relay switch which will cause fuel pump to also become week had same problem for three yrs. My husband, every mecanic in country thought i was crazy, cuz never did it and i mean never when I took it to shop, was so flustrating, untill finally one day my husband was with me when it done it. I said finally damn car tryed make me think I was crazy, i said believe me now, said yeah, **** He drove it all time to but never in those three yrs did it ever do it to him, me on the other hand everytime i drove it just about, so i think he thought i was crazy or just wanted a different car and im like no just want mine fixed so i didnt have to take it for a walk everyday instead i would like to driving it cuz everytime i left the house in those three yrs i was usually walking back, or hitching a ride, my car walked me very often lol, That was 5 yrs ago have never had a problem with the car since, still driving it today.
Apr 06, 2009 | 1993 Ford Tempo
IBM Thinkpad R31
It looks like hardware problem.
Nov 08, 2008 | IBM ThinkPad R40 2722 Notebook
Unit shut down
I have run into the same problem and it may be related to the WAAS (Wide Area Augmentation System) feature. Try disabling this feature (under MAIN MENU / Setup). I used this receiver overseas (Asia and Europe) last year for 35 days straight with no problems. During this time WAAS was disabled as none of these satellites are visible overseas. The problem occurred intermittently prior to the overseas trip, and has reoccurred after returning. I was running into the same problem this past weekend and noticed the screen blanking out (with the vertical line) shortly after differential corrections were applied to the GPS signals. I disabled the WAAS and let the receiver run for over an hour. The problem did not return. Hope this helps.
Sep 25, 2008 | Garmin GPSMAP 76 GPS Receiver
Garmin 205w nuvi cannot unlock maps
Ok so I decided I was going to return this thing tomorrow after hours of frustration, so I decided to get crazy with it and then figured out something that seems to have worked (will probably still exchange it for a Magellan or something other than Garmin though).
It's gonna sound crazy, but I opened up the Garmin drive on my computer (Mac, so not sure how this works on PC), and deleted everything I could see (not hidden files). EVERYTHING.
I then went ran Disk Utility and reformated the "Hard Drive" (on PC I would guess your able to do the same somehow). It still ran after that, but obviously could not find maps (since I just wiped every trace of a map away).
Next step, I ran Garmin Map Manager and transfered map for my state (AZ) (I have the latest map update saved on my computer, so I'm guessing Manager used that). Unplugged from comp, powered up, and voila! I will need to download my voices and vehicles again, but hey at least it's working again.
Aug 30, 2008 | GPS
Garmin gps 60 scx the games
This is a little funny.
The reason the arrow doesn't move within the game is because *you* are not moving. You have to go outside and start walking around to make the arrow pointer move. These are GPS games and they are best played outside in a large area where you are free to walk around in most directions (like a football field). Start the game in the center of the field.
The Maze game is quite fun, and you'll get some good exercise. Move over Wii Fit! ;-)
Jun 30, 2008 | Garmin GPSMAP 60CSx GPS Receiver
Garmin Forerunner 305 GPS Receiver Logo
3,406 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
