Question about Philips Magnavox DVD/VCR Dual Player
Cable connection part broke off in back
The part that connects the cable broke off. I was given a rate of $80-$140.00 to repair. The last repair person said to use a vcr as the tuner and the cable would work. (R/Y/W) are located in the front. The cable does work for 10 seconds, and then vcr cuts off.
    Novelist:
  • 140 Answers
Are you talking about the part that connects the cable from the wall to the tv? I do not really understand which part on tv or vcr. It is true you can use the vcr as the tuner. You still have to connect the cable from the wall to the input cable jack on back of vcr. Then you hookup the R/W/Y rca plug- in cable from the back vcr output jacks (which are also color coded) to the tv's jacks. If you only have two jacks on the tv they will probably red and black. It doesn't really matter. Go from your video output on the vcr to the video input of tv, then use one of the audio outputs on vcr and go to the audio input on tv. It should work like that.
Posted on Jan 14, 2009
Cable connection broke off bake of unit
if i was u id take to expert as i have had same problem once found cable was incased inside box very had to open so took to repair shop didnt cost alot
Nov 27, 2012 | Panasonic TH-42PX60U Television
Cable input broke off, can this be soldered back on or does it need to be replaced?
dont try ro solder this because if theres any joint left lose , corbon may get accumalated there cuasin damage to ur TV.Go for a replacement , it is'nt that costly
Jan 09, 2010 | GE 31GT740 31" TV
How do I replace the cable connection?
You have two choices--either have the tuner removed and repaired--a new coax fitting installed OR:
If you have Cable, Direct TV, SAT, etc--you can route the signal into one of the audio and video inputs on the back of the set and bypass the tuner connection totally.
You can even use a old VCR---it does not have to be able to play tapes--just hook it to one of the Video and audio inputs and use it or a box to change channels
Repairing the tuner or replacing it may be very expensive--going into one of the inputs could only cost you the need to rent a box if you have cable etc.
If you have questions let me know--I am here to help people.
If this information helps you--rate this solution--I do this here for free.
SD TECH
Nov 02, 2009 | RCA D52W19 52" Rear Projection Television
Can't shift into gear
If the clutch lever is very easy to pull back (no tension) your cable is broke, if not you need to adjust the clutch. You might want to check at your local library to find a repair manual for your bike. It will show you what you need to know, replacing cable or adjusting clutch.
May 20, 2009 | 1986 Yamaha FJ 1100
Cable connection in rear of TV broke off.
This problem will have to be taken or shipped in to a service center for repair or replacement of the cable connector on the main board. The telephone number for Insignia customer support is 1-877-467-4289. and the website is www.insignia-products.com. You can also call the Best Buy customer support telephone number. 1-888-237-8289. Give them you make and model number of television and the problem you had with the broken cable connection.They will be able to tell you how you can get service for your television. I hope this information helps you with your problem.
May 02, 2009 | Insignia IS-LCDTV32 32 in. Television
Cable connecter broke off?
It would probably cost more to have someone fix it than just replace it.If you or someone you know can use a solder iron you might get lucky and resolder conections, but most times its too hard to get at the circuit board to affect repairs and the connector usually gets mangled so bad it won't fit right anymore. Or you can try to avoid using this connection and use a different input. But you would need either a cable/satellite box or vcr (with the same kind of connection that broke on TV) and change the input used on the tv to the new connection such as 3 wire AV connection (with the yellow,red and white wires)
Apr 26, 2009 | Sharp 25H-M60 TV
yep if you can desolder the tuner with solder braid then put new tuner in resolder it thats it
bc
Feb 02, 2009 | RCA F32650 32" TV
Cable to connect laptop to TV
I am investigation the last advice given to me by FixYa. This may take a few days.
I will report back.
Thank you.
Feb 12, 2008 | Computers & Internet
it can be repaired.otherwise replace tuner
Nov 25, 2007 | Sanyo DS25390 TV
Philips Magnavox DVD/VCR Dual Player Logo
82 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
