Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
Replaced Motorguide Trolling motor switch ... same problem
Transom mount MotorGuide 12v runs slow on 1st and 2nd forward selected speeds, 0 3rd and 4th speeds and runs High at 5th speed selected. Both reverse speeds work properly. Replaced original switch with factory replacement, Runs the same. During changing switches, moved one wire at a time, so I wouldn't mix up connectors to posts. Can't find wiring diagram online to verify if I rewired new switch wrong...but this didn't fix the problem... ??? Can You help
Joel
  • 1 more comment
  • mrtrout444 Jan 31, 2009
    Did you replace the speed selector switch or the control switch?
  • Anonymous Apr 19, 2009
    I just bought a used boat. Motorguide Pro Series 46 trolling motor came with it. Speed 1,2, and 3 don't work..where did you find the replacement switches? I can't locate any info on this motor.
    Thanks..Bill
  • agsbill Apr 19, 2009
    Thanks..Bill
    ( I am now a member..not a guest:)
    Problem Solver:
Trolling motor runs on it's own when plugged in,speed adjuster won't control speed and 3 position switch doesn't perform either..please help. motorguide 74lb thrust.
Posted on Sep 16, 2011
Had the same problem with mine lost 3 and 4 speeds eventually lost all speed except 5. Took lower unit apart and cleaned brushes and armature little tricky getting back together you have to get the brushes back up over the armature. for unit to go back together. Once together had all the speeds working again.
Posted on Jan 11, 2011
    Problem Solver:
  • 7 Answers
I have a old 37 lb thrust stealth strong for where i go fishing the mount broke but i had it fix now i'm trying to hook it back up i forgot where the wires go HELP i need a diagram for it plz
Posted on Apr 09, 2010
Motorguide trolling motor
The first thing to check,(After making SURE the electricity is disconnected to the trolling-motor) remove the propeller and see if the shear-pin (Usually made of brass) in in place and not sheared/broken.
If it is, your local marine shop should be able to provide a new one. I always carry spares. If the pin is OK, the windings may have an electrical fault that would require a factory-repair.
Sep 05, 2014 | MotorGuide Transom Mount Great White...
They invite you to call them if you have questions... http://www.motorguide.com/about/contact but be sure to have your serial number ready.
Jul 16, 2014 | MotorGuide Boating
My trolling motor stopped working suddenly. It is a 96 motorguide 56. It is completely charged. What else do I check. I check 5 fuses by the battery as well.
First you need to check to see if power is getting to the motor. If power is not getting to the motor, then check the battery. If you are getting power to the motor, then troubleshoot starting with checking to see if power is getting to the foot pedal. From there check the switches, and make sure they all have power. If they do, then most likely it is the brushes which could be worn on the powerhead itself.
Jun 02, 2011 | MotorGuide FW40 FB 42" 12V FLXMT Trolling...
Is there any way to modify in order to get more power/thrust out of a mk 30lb other than stock? or can you take a moto guide 80 lb., bow mount foot control, shaft and motor and combine it with transom...
Hey Chris,, you are starting a project (or wanting to) that is going to be problematic... It will be easier to go buy a new trolling motor with the money you are going to spend attempting this conversion... the newer trolling motors are so much more efficient...
Trolling Motors Fishing Motors Electric Boat Motors MotorGuide Trolling...
https://www.minnkotamotors.com/
Jul 15, 2017 | Minn Kota Endura 30 Freshwater Transom...
I have a motorguide trolling motor and the front
With the top off take the six screws out and lift the cable and gear out. Next put your foot pedal at mid position. Then make sure the motor is pointed forward and reinstall the slider gear and the six screws. Last put the top on and make sure the arrow indicator is pointing forward and thats it.
Mar 09, 2010 | MotorGuide Standard Motor Replacement...
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
6,021 people viewed this question
Top MotorGuide Electrical Supplies Experts
Craig Butler
Craig Butler
Ian Summerfield
Ian Summerfield
Mike
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
