I came home yesterday and noticed my wine refridgerator had a code in place of the temperature readout. The code was E3 and as I played with it also E4 came up. The temp on the lower portion read 75 degrees, and wasn't cooling. I pulled it out and didn't see any issues. Didn't see any reset button, unplugged it overnight, and had the same error this morning when i replugged it in. Any thoughts or advice?
yualfred .... if you would describe how to get to the part , and , what it looks like , you would have a great solution .
Same Problem
Apr 13, 2009
-   Sadly this is ridiculous . . but I just opened the fridge for a bottle of wine and everything is warm. . the bottom has error E4. -   Guest
Feb 03, 2009
-   E4....Same as the above. My question is why can't we get an answer from the compay??????????? Talking to ech other is not solving the issue, is it?-   Guest
Jan 17, 2009
-   Same thing, E4 Code. bought a new temp sensor as the customer service rep said (20 minutes on hold) - $22 to my door - removed old one, put in new one, and vola - Nothing, still E4.....I tried swapping temp sensors too and nothing changes, so I guess its the Board or something. -   JCBJr
Nov 26, 2008
-   I have the same problem-   Guest
Sep 17, 2008
-   I have the same problem: E4 on the lower chamber. The fans and lights work. The compressor only works when I bypass the electronic board. -   freddywright
Is the compressor running? I don't know this unit, but know that if you are too warm that is the first thing to check. In reading about another unit that had a different problem, it was mentioned that there is a ciruit board. If it has relays on it then these are the most likely culprit. They are either not making contact or staying in contact too long... sometimes just tapping each relay usually a black plastic component will cause it to work intermittently..Not sure if you can get these but call the company help line at 1-800-263-2629.
Upper Fan replacement - I have removed all screws holding the back plate in place. I cannot remove...
(More)
Upper Fan replacement - I have removed all screws holding the back plate in place. I cannot remove it to replace the fan since the large section holding the electronics is in the way. Am I missing something in order to get access to the upper fan????
