How to record ditigally on old comb tv/vhs
I have a digital converter box hooked up to my 1996 combo TV/VHS. I can't figure out how to tape my programs since the digital stations are 12.1, 15.1 etc and it seems to only record on the standard channel 12, 15 etc.
is there some way to fix this problem as i don't want to purchase a new tv.
Thank you for your help
Michelle Yates
    Sergeant:
  • 227 Answers
If you have the box hooked up to your 1996 combo turn or tune on channel 3 if the converter box is selected to channel 3 you should get all your digital reception from the box to your tv/vcr. Select what you want to watch or tape on the box, what you see on your tv will record to your vcr when you select record.
Posted on Jan 15, 2009
TV/VCR Recording of TV Programs Using a Digital Converter Box
Hi Rick
I think you are painting yourself into a corner. So to Speak.
Why buy a SetTop Box to convert to an old VHS Tape when you can buy a Digital Recorder for probably the same price.
The modern way to Record video is to use a Hard Disk Drive Recorder rather than a VCR. They have a built in tuner and can record 2 stations at once and have a built in Electronic Program Guide. The EPG info is transmitted with the Digital TV transmission from the broadcaster.
I bought one 2 weeks ago for an old 85yo friend so he could record late night stuff and play back later. He still uses the VCR but only for old VHS Tape playback. It was a TEAC HDR9650TS Digital Video Recorder and I picked it up new for Aus$188.
Here are the unit features
  1. Main Features:
    DVB-T Twin Digital Turners
    DVR Recording: Record three channels while watching a 4th from same network Smart Series Record feature to record a whole series at a touch of a button
    2.5" Sata Hard disk: 500GB
    Time Shift Function (Pause live TV)
    HDMI Digital Output
    Digital Audio Output
    CVBS/YPbPr/SPDIF connectors
    Supports TV formats 4:3 and 16:9
    Electronic Program Guide (EPG) up to 7 days in advance
    EPG searching and auto download
    Recorded program edit
    Parental Control
    Copy files from internal HDD to external HDD
    Built-in WiFi
    Network Playback
    USB 2.0 Interface
Now
This was my original reply until I saw the light.
So, Hopefully one of these will answer your queerie.
A digital TV picks up the new Digital Transmission and stores it in memory, then supplies the high definition to the input of your TV.
With a STB, once the digital broadcast signal is captured by the Set Top Box tuner, it is stored in memory and then it is converted to Video Format and comes out of the back connectors as a standard video & audio signal on the Red & White (Audio) & Yellow (Video) as a composite signal that can also be attached to an older VCR tape recorder.
If the STB output connectors have a Red White & Yellow RCA plugs then it is all ready to be picked up by an older TV or VCR.
Most set top boxes also have HDMI Output for high definition video & sound in the one cable, which attaches directly to the back of your TV (assuming it doesn't already have a tuner (STB) already built in).
HDMI is the state of the art cabling for modern devices. But probably not on the old VCR.
It will either use Component, Composite or SVideo cables. Match one of these cable standards up with your VCR.
Cheers.... Trevor
Was this Helpful
.......Then give me a tick of approval
Aug 18, 2014 | Panasonic PV-V4022 VHS VCR
Problems with Philips vhs recorder/dvd player
You only need coaxial cable to pick up TV stations broadcast via an aerial. If your TV has sockets to connect via HDMI or SCART, then any players can be connected via them. So if the adapter box picks up TV signals, you connect the main aerial cable to that and it should have a coaxial out socket, that should be connected to the aerial in of your TV. If you are recording to an analogue video from the adapter box, then that will need to be connected via a scart socket or other connection.
Nov 24, 2017 | Philips Dvd Player Vhs Video Tape Player...
Are you truly free? If so, then answer the
Hello. Your digital TV is all set up to recieve the digital signal that is now the standard signal coming into your home. The old analog signal is history. If you still want to use your VHS/DVD recorder you will have to get a signal conversion box, at your local walmart or radio shack. This will take the new digital signal and convert it so your old analog VHS/DVD can process it properly. Joe
please rate my answer as very helpful....and free. thanks. Joe
Apr 26, 2010 | GoVideo Go Video DVD/VCR Combo
Have digital TV have 3 yr old sony VHS VCR DVD player combo
A DTV converter box will take digital broadcast signals from the antenna and convert them to a format compatible with the VCR. You will be able to record programs received through the DTV box on your VCR if you could record analog over-the-air programs before the digital changeover. You can use either the RF output or the component output from the DTV box to input to the VCR.
Jun 30, 2009 | Quasar VHQ400 VHS VCR
Tv/digital converter box & vcr-dvd hook-up
I have a vhs and dvd player all in one
I have a converter box hooked up to my tv and vcr , dvd player combined
I can play my movies on the tv. ok.
you have to have your tv and vcr set on channel 3. if that is what your main tv is set up with. Or 4 if you have your tv set up with that.
Mine plays ok. My settings are for channel 3
My suggestion would be to check your hook ups. maybe they are not hooked up correctly
I had to go to www.google.com and did searches to help with hook up.
I can also record station I am watching with vcr on vsh tapes. I do not have a dvd recorder.
I found out that you have to have 2 converter boxes hooked to one tv., in order to record on on station while watching another. I have not tried that, as I don't have 2 converter boxes for one tv. I found that by doing google search also. Good Luck
Dec 04, 2008 | Televison & Video
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
I want to convert a DVD to a VCR tape.
Do you want copy dvd movie on VHS tape?
Use DVD/ VHS Combo Player like shown in below picture...
Oct 27, 2008 | Televison & Video
Record to vhs with converter box
I need to leave my TV on channel 3 and set the converter to the channel I want to record. When programming for future recording, it's always from channel 3, not the channel I want the converter displaying.
Jul 17, 2008 | Samsung CXN2085TP 20 in. TV/VCR/DVD Combo
Dvd recorder
Following the instructions on hooking up the cables gave me fits. I finally just put the instructions away and winged it. Got it that way. Bypass your Ilo tuner. Hook the Comcast Cable (outs) up to the A/V input 1 of your ILO. Hook your tv combo A/V outputs, to the ILO A/V inputs. Select the Source and choose the cable source for cable and the combo source to tape from your VHS/dvd combo. Its a pain but you have to select Source everytime you turn the Ilo back on. You could hook your Cable to the ILO but would have to turn on ILO everytime to watch tv. Two remotes is a chore but you have to use tv remote for the volume anyway so it doesn't matter. Hope this helps.
Mar 30, 2008 | iLO DVDR05 DVD Recorder
HELP! I can't figure out how to Connect my Sylvania DVD/VCR Combo to my older TV
Even if you do get it connected you cannot copy from vhs to dvd as you have bought a vcr recorder with dvd player, not a dvd recorder. You can only record to the vcr tape from a dvd, in the players controls.
Feb 08, 2007 | Sylvania (SRDD495) DVD Player/VCR
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
