Question about Nintendo Wii Fit for Wii
Can't Get Started my Wii Fit because CD Can't Be Read
The Wii Balance Board says it needs a game CD on the console so it can be synchronized. Though, when I put the Wii Fit CD it can't be read and it blocks everything. The weird thing is that if I put any other disk (after having to turn off the console and then on again) it reads it very well...
Anyone knows what can I do?
Thanks a lot!
Be sure the disk is clean, and if that does not work, exchange it at the store it was purchased at for a new one. There have been many Wii games shipping with the wrong region CD.
Posted on Jan 14, 2009
How to configure gameon balance board with wii console
1. You need to put Balance Board compatible game disk in the console.
2. Select Disk Chanell and press Start
3. Remove SD Card slot cover on the console and the battery cover on the Balance Board
4. Press and hold for 2-5 sec the SYNC button on the Balance board. You will see a blinking light.
5. Press the Sync button on the Wii console and after a while you will get non-blinking light.
This will mean that your device is synchronized and you are able to use your Balance Board.
Good Luck!
Don't forget to close back the covers you've removed earlier.
May 23, 2012 | Nintendo Wii Fit - Balance Board + Game...
How to connect wii fit board to the wii
Important Note!
Do Not use "One-Time Mode" sync.
Syncing can be completed only if a compatible game disc is running in the console.The Wii Balance Board may need to be synced to each compatible game individually.Some games may require you to go into a specific screen to sync the Wii Balance Board.These sync settings will be saved even after the console is turned off.
1. Insert a Wii Balance Board compatible game disc in the Wii console.
2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game.3. Open the SD Card slot cover on the front of the Wii console.4. Remove the Battery Cover on the bottom of the Wii Balance Board.
5. Press and release the SYNC button on the Wii Balance Board. The Power LED on the board will start blinking.
6. Press and release the SYNC button on the console while the Power LED on the board is still blinking.
7. The Power LED will stop blinking and light steadily once the synchronization is complete.8. Replace the battery cover and return the board to the normal operating position.
Nov 16, 2011 | Nintendo Wii Fit for Wii
My wii fit was working perfectly fine when i purchased it, then about a month or so later the wi fit game didnt recognise the balance board, so when it said please turn the power button on and i did, it no...
When you power on the wii fit board, does the light flash continuously? If so, you will need to sync your board with your wii again. You can get instructions on how to do so here: http://www.nintendo.com/consumer/systems/wii/en_na/ts/balanceBoard.jsp
Mar 22, 2011 | Nintendo Wii Fit - Balance Board + Game...
How can i re connect the wii fit balance board to my wii ?
Synching can be completed only if a compatible game disc is running in the console. Compatible game discs (such as Wii Fit) will display the Wii Balance Board icon on their packaging.
The Wii Balance Board must be synced to each compatible game individually.
Follow these directions to sync the Wii Balance Board (so that it is recognized by the Wii console):
Insert a Wii Balance Board compatible game disc (such as Wii Fit) in the Wii console.
Mar 16, 2011 | Nintendo Wii Console
How do you sync the wii fit board and wii console
  • Put four AA batteries into the battery housing located on the underside of the Wii Balance Board.
  • Insert a Wii Balance Board compatible game into the Wii system.
  • Select the "Disc Channel" on the screen with the Wii remote, and choose "Start."
  • Open the SD card slot to reveal a sync button on the Wii system. This is located behind a cover under the power and eject buttons.
  • Turn the Wii Balance Board upside down.
  • Remove the battery cover under the balance board to reveal another sync button.
  • Pres the sync button on the balance board, then press the sync button on the Wii. Do not hold down the buttons. You know it is synchronized when the blue light on the Wii Balance Board stays steady
  • Place the board on a flat surface directly in front of the TV. Face the power button away from the TV.
  • Mar 03, 2011 | Nintendo Wii Console
    Bought 2nd hand wii fit, have just loaded disc and replaced batteries in board but power light not staying on board, flashes for about 30 seconds and then switches off. Does it need to be synchronised with...
      Hope this helps
      Try these steps!
    2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
    3. Open the small SD Card slot cover on the front of the Wii console.
    5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
    6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
    7. The blue light will stop blinking and stay on steady once the synchronization is complete.
    please leave a good rating and testimonial if you appreciate my help. THNX
    Mar 27, 2010 | Nintendo Wii Fit for Wii
    My wii fit board keeps telling me to step off and press (A) even though i am not stood on it
    iv got the same problem too, iv resync it and nothing, wiped the wii clean and started again and nothing (mine went down just b 4 xmas and 'santa' got my boy the wii fit plus and he ant been able 2 play it yep) PLEASE PLEASE PLEASE some1 help
    Jan 29, 2010 | Nintendo Wii Fit - Balance Board + Game...
    I have a wii fit and tried to sych it to my console. I think I held the sych button on the balance board too long and messed up the remotes. They won't work at all now. Please help! Thank You
    Ensure your batteries are fresh. Ensure that the Wii Fit (or other Balance Board game) is started up completely before pressing the power button. Try turning off your wii and unplugging from the power source for a few minutes. The plug back in and turn on. At the initial warning screen press and hold the sync button on the will console for about 4 seconds. You will have to re-sync your wii remotes. Next make sure the disc for the game you are going to use the balance board with is in the system and start the game. Then try to sync the balance board.
    Oct 18, 2009 | Nintendo Video Game Consoles & Games
    Canot use Wii fit balance board
    Ensure batteries are fresh. Ensure that Wii Fit (or other Balance Board game) is started up completely before pressing the power button.
    Jan 04, 2009 | Nintendo Wii Fit for Wii
    Wii fit
    are you able to get any of your controllers to connect? if not it could be a issue with your sensor bar. please provide a bit more info
    but try this first
    Synchronizing the Wii Balance Board with your Wii Console
    IMPORTANT: To operate correctly, the Wii Balance Board must be synchronized with the Wii console using Standard Mode Synchronization. Follow the steps below to synchronize the board to the console.
    • This procedure must be followed for each Wii Balance Board compatible Game Disc.
    • These synchronization settings will be saved even if the console is turned off.
    • This procedure can be completed only if a compatible Game Disc is running in the console.
    1. Press the EJECT Button on the front of the Wii console and remove any
      game disc if necessary. Insert a Wii Balance Board compatible Game Disc.
    2. Use the Wii Remote to select the Disc Channel on the Wii Menu screen and select START.
      NOTE: Close the SD Card slot cover when you are finished with the synchronization procedure.
      NOTE: Replace the Battery Cover when you are finished with the aynchronization procedure.
    5. Press the SYNCHRO Button (SYNC.) on the Wii Balance Board. The Power LED on the board will start blinking (for up to about 20 seconds).
    Press the SYNCHRO Button (SYNC.) on the console while the Power LED on the board is blinking.
    1. IMPORTANT: Do not press and hold the SYNCHRO Button on the Wii console down for more than 10 seconds. This will delete all of the Standard Mode synchronization information for all Wii Remotes that you use with that console.
    2. The Power LED will stop blinking and light steadily once the synchronization is
      complete. You are now ready to play the Wii Balance Board compatible Game Disc. Please refer to the instruction booklet for the Game Disc you are using for further information on gameplay.
    • Only one Wii Balance Board can be synchronized to a Wii console at a time. Up to a total of 10 Wii Remotes and accessories can be synchronized to a console at any time with the Standard Mode procedure. If additional synchronizations are made, the oldest existing ones will be overwritten.
    • The Wii Balance Board can only be synchronized to one console at a time using the Standard Mode procedure. If you change the console you are using the board with, you will have to repeat the synchronization procedure each time.
    • The Wii Balance Board uses the Player 4 (P4) connection. If a Wii Remote is actively using P4, that remote will be disconnected while the board is being used.
    Aug 01, 2008 | Nintendo Wii Console
    Nintendo Wii Fit for Wii Logo
    102 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Bee Santiago
    Raj Patel
    Julian Wainwright
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
