Question about Champion 2000+ Household Juice Extractor
Pulp plugs up exit shaft after one carrot
Pulp doesn't come out of shaft fast enough and even after one carrot, the pulp starts to come up the feeder piece making it hard to push down any further product. I have to stop after 7 or 8 carrots and clean out the pulp. The cutter blade is packed with pulp. Somewhere in the process the pulp is not coming out as it should be and just plugs up the shaft and feeder area. Any help appreciated. Michael
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
Use a quatered apple in between carrort.
Posted on Mar 01, 2009
Why is the pulp warm/hot? the screen is clean...
It is caused by friction as the cutter assembly squeezes the pulp out. The tighter the squeeze the more juice that is extracted. Be sure to oil the shaft with only olive or coconut oil as these oils will withstand the high temperature without getting gummy and making the cutter stick to the shaft..
Sep 04, 2014 | Champion Juicers
Motor burn out
to clarify- I was just starting out this morning, juicing some carrots and heard a pop (carrot chunk hitting the inside of the pulp cover) and the machine stalled.
Dec 16, 2013 | Breville Juicers
Pulp is building up, not ejecting properly
When juicing with the champion juicer take it slow. You need to hold down the tamper for three to five seconds in-between reloading the chute. Otherwise it will begin to back up through the chute and the juicer will begin to heat up. Happy juicing! LivingaHealthyandHappyLife.com
Mar 07, 2012 | Champion G5NG853S 540 Watts Juicer
I acquired the JEX328KE juicer at a garage sale but didnt get the manual. is it possible to get one for it or to look at it online?
I also acquired this Kenmore juicer just today at a thrift store. It is virtually the identical juicer as the Waring Pro JEX328 Juice Extractor (only w/o the KE, for Kenmore). The manual can be found at the following link:
http://www.waringproducts.com/ret/share/man/12_man.pdf
When juicing carrots, you'll want to keep your eye on the pulp being produced. You may need to empty the pulp collector after 8 to 10 large carrots before proceeding. It's easy to clean, as well as very simple to assemble and disassemble.
Enjoy!
Sep 15, 2011 | Kenmore JEX328S Juicer
My #6001 juicer ( old!!) will make a very loud sound even after only 3 carrots.. causing me to stop and clean out pulp.. even may shake more than usual... so am thinking it should need an overhaul??? I...
No overhaul. These juicers do not eject the pulp and are subject to vibration especially if you
install a new blade. I've had one for 21 years and get by using a worn blade which I sharpen
with an electric drill using a small bit.
Mar 03, 2011 | Acme 6001 Juice Extractor
Too much pulp in juice
You need a new slicer with a finer mesh.
Dec 29, 2009 | Waring JEX450 850 Watts Juicer
Shuts itself off when juicing
FIRST DUMP THE FILTERS, THEY DECREASE YIELD AND MAY CAUSE MORE VIBRATION.
IF JUICER SHUTS DOWN PUSH RESET BUTTON ON BOTTOM. THIS TYPE OF JUICER DOES
NOT EJECT PULP AND REQUIRES SOME TIME TO MASTER. FEED THE STUFF SLOW AND
STEADY. WANT A GOOD JUICE? TRY 1 APPLE, 2 CARROTS, 2 CELERY AND A HALF LEMON.
IF YOU ARE REALLY BRAVE YOU CAN FINISH OFF BY SLOWLY POURING 6 OR 8 OUNCERS
OF WATER RIGHT DOWN THE CHUTE. THIS NOT ONLY DILUTES BUT LEECHES MORE JUICE
OUT OF THE PULP. JUICE SHOULD BE DILUTED AND DRANK SLOWLY.
Feb 27, 2009 | Acme 5001 Supreme Juicerator Juice...
Acme juicer #6001, has a new blade, becomes unbalanced...
Hello, First, make sure the screw on clamp that holds the blade down is centering the blade correctly. Also make sure it tightens down firmly against the blade. Wiggle the blade to ensure it is mounted securely. If this doesn' fix it try your old blade again. If your old blade works you may have a bad, unbalance blade but I would suspect he screw on clamp knob may be somewhat worn and not securing the blade causing it to run "out of round" when a piece of vegetable pushes on it. If everything looks good with both blades and the blade securing knob it could be a worn bearing on the juicer. Try wiggling the motor shaft and see if there is any play in it. I have an ACME 6001 that is quite old so I wouldn't suspect the bearings are going. One other thing, does the bowl take 3 to 5 minutes to stop spinning when you shut off the motor? If it does then the shaft and bearing are probalby ok
Good luck with it...gary
Jan 05, 2009 | Acme 6001 Juice Extractor
Pulp galore!
are you exceeding the capacity of the juicer? you will get about 2 and 1/2 large glasses of juice before the pulp fills the spinning basket. Apple peels are very tough, apples and tomatoes need to be peeled before juicing. Use the filters, the juice comes out much clearer and the juicer is easier to clean up. I so a lot of carrots, carrots are super food.
Nov 21, 2008 | Acme 6001 Juice Extractor
Champion 2000+ Household Juice Extractor Logo
550 people viewed this question
Top Champion Juicers Experts
David Payne
David Payne
ray gallant
Are you a Champion Juicer Expert? Answer questions, earn points and help others
