Question about Epson Aculaser C1100 Printer
Printer self calibrating...
Hello!!!!.....the problem i have is that once the printer is switched on it starts self calibrating without stop (not letting any print job to take place)....i was planning to change the black toner cause it was near its end but apart from that i didn't get any error messages to worry me.....now i cannot even do that (change the toner) cause the printer is stuck at the calibrating stage without letting me through the menu regarding "cartridges' replacement"......any help will be much appreciated!!!!
  • Epson Master
  • 705 Answers
This is most likely caused by the toner being low. Change the cart manually with the machine turned off. Open the cart door (not cart d'or - no ice cream here!!) and you will see on the left side there is an interlock which you can push in using a screw driver or similar object. Once pushed in you can rotate the carousel to the relevant point to change the carts. Ensure the tram lines down the sides line up correctly and that you fully insert the cart before turning the carts to the open position. Once changed, power up the machine and I'm sure you should be back in business.
Posted on Aug 14, 2007
SOURCE:
Printer will not advance to tear after print
I can't give the exact solution for this printer, however, I use the Epson POS thermal printer and here was our solution. In Windows 7 go to Devices and Printers. Click on Printer Properties. Then see if you see a tab that says Document Settings. Under that setting click on Paper Source. You should now see several options; I have mine set on Document(Feed, No Cut). There are other options but we prefer to tear ours off. You can chose Document(Feed, Cut) and it should advance then cut the paper for you.
Jul 10, 2014 | Datamax E-Class E-4205A Direct Thermal...
My printer cannot detect the gap between the labels.one bar code is printed on 2 labels.
did you try to calibrate the printer yet? Procedure is the following:
- switch off printer
- switch on again WHILE pushing green button
- release button after first flashing of led
- printer starts calibration process
- after printer finished calibration press green button again once to feed another label and leave dump mode (important!)
- printer prints "out of dump"
Now try to print from your software again. I hope it helps!
Sep 03, 2011 | Zebra LP 2844 Thermal Printer
Have a Color Laserjet 3600n printer. It keeps on calibrating without stopping when I switch it on. why ? thank sin advance.
600 Hp Continuous Calibration 1 Votos
This is an answer to most of the problems of "continuous calibration" in the HP 3600.When the printer begins to constantly calibrate and falls in line so we have a problem, there are several causes for that problem and must be discarded from the simplest solution to the most complex.
Let's begin:
SOLUTION 1: The first thing to do is turn off the printer, and remove the cartridges, toner dirty or if the internal parts of the printer remove the excess, if there is dirt in the transfer belt clean.then close the front cover and turn on the printer without cartridges. then open the lid, place the magenta cartridge, and close the lid again, and so putting the four cartridges. If the problem persists try the next solution.
Solution 2: We must be alert to any strange noises in the printer, it is likely that one of the sticks is failing, if we are a strange noise came from, and replace the cartridge.
SOLUTION 3: There are times that it is software problem can be solved with a "COLD RESET" to do this we must turn the printer, and press the green button several times in the main menu until you see some options, navigate to the Down Arrow button until COLD RESET appears, press OK. the printer will restart and initialize. then restart and probably reached OK status.
SOLUTION 4: Sometimes by changes in temperature and environment where the printer is out of calibration sensor, to do a need to upgrade the firmware of the printer, usually ends the problem here. To download the firmware of the printer with the improvement due to "Countermeasure for multiple Successive Causing Environmental Sensor Calibrations." Is in the following link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=501044&swItem=lj-44336-1&prodNameId=501046&swEnvOID=54&swLang=8&taskId=135&mode=4&idx=0
SOLUTION 5: If any of these options serves, it is likely that the mirrors of laser printer are dirty, this requires us to print a sheet to observe defects in print (moved, blurred, misplaced shadows), if any of these defects appear we disassemble the printer for cleaning the laser ... in this link are instructions
http://ingenioysoluciones.wordpress.com/2010/04/12/limpiar-espejos-de-la-impresora-hp-3600n-para-corregir-impresion-defectuosa/
May 26, 2009 | HP LaserJet 3600n Printer
HP color laser 2550L prints only in yellow
Hi Mmgrafde,
Press the Go and Rotate Carousel buttons simultaneously. This will calibrate the printer. See if this works.
Otherwise....Remove all cartridges and drum. Switch off printer. Close the lid. Switch on printer and wait until any churning stops. Insert the drum and close the lid. Wait until any churning stops. Put in one cartridge at a time, closing the lid and wait till it stops churning each time. With the last cartridge put in, it will churning longer (calibrating). Try to print from your computer.
It could also be that the toner could actually have run out for the other colors.
Rgds
S88
Jan 01, 2009 | HP Color LaserJet 2600n Printer
Intermec PC4 label printer
Your printer is not sensing the gap between two labels.Please try calibrating the printer for the gap.
Switch ON the printer while holding FEED key down, on printer start feeding label realese the FEED Key.
Printer will stop feeding paper after printing SELF TEST, Once again press FEED key for 3 seconds. Printer will enter into normal Mode.
Check now.
Aug 14, 2008 | Intermec EasyCoder PC4 Label Printer
5300 printer
To calibrate the printer right click on the printer icon and open the status monitor once you open it there is 3 symbols on the top right of the box one looks like a hammer and wrench in an x configuration, next to that is an i for i for about and a ? for help. Click on the x which is Maintenance it will bring up a new box which has 2 options calibrate and printhead cleaning when you chose calibrate it will print a calibration sheet which you then need to put into the scanner portion and press the start button, these instructions will also come up on the screen when you go through the process.
Jun 14, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Error Message
Clean the paper sensor located at the centre of the mechanism .
Switch ON the printer While holding Feed key down, Printer will enter into self test mode, it will stop after printing self test label.
To take out priter from HEX DUMP mode press feed key for 3 seconds. now printer is in Normal working mode.
Try feeding labels, only one label should advance at a time.
This is the calibration procedure.
Feb 13, 2008 | Intermec EasyCoder PC4 Label Printer
NO CALIBRATION SHEET
Hello, you can print a calibration sheet from the front panel of the printer. Hit menu on the panel of the printer and scroll down to calibration printer and hit ok. Then hit ok on print calibration page and it should proceed to print a calibration page. After it is done printing, it will tell you to scan the calibration sheet.
Feb 10, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
1 inch of left margin left even on the self test
Try using the "manual" width calibration. With the printer on, press and hold the green button. It will flash once, then twice, e.g. the sequence:
after the 5th flash, let go of the button. The printer will begin drawing rectangles which get wider and wider. Press the green button once (don't hold it) to indicate "when" the width is appropriate. However, I found the width was best calibrated when I let the printer draw rectangles right until the edge (where it automatically stops).
Dec 27, 2007 | Zebra LP 2844 Thermal Printer
DOT MATRIX PRINTER PROBLEM
Hi, to perform a self-test on an Epson LX300 > start with the power switch off. Press LF/FF (middle switch), without releasing that button, power on the printer. If everything is ok it will print a sel-test page. To do a Hex Dump > start at power off, simultaneously press Font and the LF/FF buttons (left & middle buttons), then power on; to revert the printer to its factory default setting(s) > start in off position, press Font (left) button then power on. (Slightly different with an LX300+) Hope this works out for you. Cheers.
Apr 19, 2007 | Epson LX-300 Matrix Printer
Epson Aculaser C1100 Printer Logo
353 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
