Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Sony Projection TV KP-46WT500 Convergence Problem and Sparking
My Sony projection TV KP-46WT500 has a convergence problem.
After I install two new IC STK392-560 and changed one of my yellow Pico Fuse(5amp) on the G-Board, I plugged back all the plugs and turned the TV on and I saw sparks.I can still see the TV, but the convergence problem still continues. I turned off the TV and turned it back on and the sparks were on a different location. I need help. What is the problem with the sparks and the convergence?
Extra Info:
I bought my pico fuse on the internet and when I recieved it, it was green. Is there a difference between a Green and a Yellow Pico Fuse?
  • Sony Master
  • 3,459 Answers
You may want to get some help with this install...goto www.tvrepairkits.com and ask for some help
Posted on May 07, 2010
BLUE SCREEN My sony KP 46wt500 hdtv ready rear projection has
Ur tv have a problem known as convergence problems.Ur tv convergence board must have it 2 STK convergence ICS and some or all it resistors to be replaced to solved convergencce problems.The shop will cost u $300-350 for parts and labors.
Jun 06, 2010 | Sony KP-46WT500 46" Rear Projection...
I have Sony KP-46WT500 Projection TV. For some time it appears convergence went bad. I see multiple images, especially at edges and corners. As many as 3 images Red, Blue and Green. I am an Electronics...
It would be great to assist you in Sony convergence issue.
As you said, for some time TV shows bad convergence in picture that shows its matter of lose/ dry solder joints in D board, specially on convergence out ICs pins that need to be re-solder.
There are 2 big black ICs mounted on aluminum heat sink on D Board of TV, below image shows D Board location in TV.
Resolder pins of these 2 ICs and also check any other dry/ cold solder joints in circuit board. I do not think of IC replacement as problem occurs some time.
Let me know if you have additional question.
Thanks.
Dec 20, 2009 | Sony KP-46WT500 46" Rear Projection...
Sony kp 46wt500 has 3d screen what might the problem be?
If convergence out ICs got defective then TV shows that kind of picture.
Replace IC8001 and IC8002 on D Board, both big black ICs are mounted on aluminum heat sink and number STK392-560 would be written on it.
Required ICs are available in Part Store, click that link to see an image of IC and price info.
If you are not comfortable with soldering parts in circuit board, call local tv tech to replace it.
Thanks.
Nov 13, 2009 | Sony KP-46WT500 46" Rear Projection...
Kp-46wt500
the pico fuse are the two little yellow resistor looking things under the heat fins of the convergence chips
Jan 03, 2009 | Sony KP-46WT500 46" Rear Projection...
Sony KP-46WT500
you need to replace both convergence Ics number STK392-560 its a fairly easy repair that requires basic soldering skills. you can get replacement Ics with free instalation instructions with pictures at the following link,
http://servicemanuals.vstore.ca/
May 25, 2008 | Sony KP-46WT500 46" Rear Projection...
Power surge may have blown tv- Sony KP-46WT500- worth fixing?
Take a look at my post on Convergence IC replacement..Thank you GURU JAY
Feb 18, 2008 | Sony KP-46WT500 46" Rear Projection...
Color is messed up
sounds like bad convergance ic
http://www.techlore.com/forum/thread/18970/Sony-KP-46WT500-Convergence-Repair/
Dec 14, 2007 | Sony KP-46WT500 46" Rear Projection...
Picture curved and three pictures - one per color
convergance amp ic are bad.
can you confirm the make and model.
Nov 24, 2007 | Sony KP-46WT500 46" Rear Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
266 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
