Question about Whirlpool LAB2700ML Pedestal Drawer for Duet Washers & Dryers
How to remove pedistal from machines
How to remove pedistal from washing machine
  • mepampatters Apr 06, 2009
    have the same problem with washer walking, how do you remove pedistal?
  • 59 Answers
Lay the machine on its back. unbolt the base. 4 bolts. then set the duet back up. Its pretty easy to do but it takes two people to man handle the unit because it is so heavy. Please leave feedback if this helped.
David
Posted on May 26, 2009
My whirlpool duet gets to the spin cycle and gets to the super, fast speed and starts to shake Is there anything I can check before getting a repair person involved?
is it on a pedistal? pedistals tend to male it worse due to the raised center of gravity.
make sure the feet are adjusted correctly and is sits squarly on the ground. Is it new? did whoever installed it remove the bolts that are installed for transportation?
Feb 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I want to clean the pump filter on a Kitchenaid washing machine. Where is it located?
unplug washer remove screws under lower panel down by feet, above pedistal (if you have one) look for large hose coming out of bottom of tub there is a handle on the filter it unscrews, if you have it on a stand or pedistal put the drain hose in a pan on floor or even better if you have a wet vac you can **** out the water you wont get all of it so some a couple of towels handy would be good. put a little vasalene or greese on the o ring before put ing back together you can buy me a dounut with the change you find, enjoy
Dec 08, 2009 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
Whirlpool washer
ok unplug the washer remove the three screws across the bottom front of machine if you have a pedistal willbe between the pedistal and the machine. remove the access panell you will see the drain pump it has a threaded cap faceing the front remove this cap and clean out the lint trap attached clean out and debree in the pump housing you can see. reinstall cap, front cover, plug in and test.
Jan 20, 2009 | Whirlpool Washing Machines
I have a Whirlpool front load washer wfw8400tw02. I have had 2 service calls to checkout the out of balance condition. The first tech moved a drain hose inside the machine. The second one tried leveling...
being level is not quite as important as being solid on floor or on solid floor..if on a pedistal remove bottom drawer and be sure all mounting screws are tight ..with drawer adj all legs up until they are up tobottom of pedistal ck washer by trying to rock if movement detected adj FRONT feet only as much as needed to reduce motion ..same applies without pedistal if is a noise issue more than an unbalance issue suspect shocks supporting tub try removing bottom panel and being careful allow unit to run and try with one hand to isolate which shock..changed 1 friday
Dec 08, 2008 | Whirlpool Washing Machines
Attach pedastal to whirpool duet washing machine front loader
you will want to lay the duet unit on its back. remove the legs. put the base up to the bottom of the duet. you can use the legs as bolts and pass them thru the top of the base back into the bottom of the duet appliance, using them as bolts. I have had some people just get new bolts. this should fix you up. please rate this if it was any help.
Thanks,
David
Oct 11, 2008 | Whirlpool LAB2700ML Pedestal Drawer for...
How to remove the base suport or (pedestal base) from a whirpool front load washer.
remove drawer usually a screw at front end of each rail or release catch ..remove the 4 5/16 screws holding pedistal to bottom of washer if you still have the 4 feet after lifting machine off pedistal reinstall them ..run feet all the way in after machine is in position ckd to see if machine is solid on floor adj only the foot necessary to make machine solid tighten the lock nut in upper position on leg
Aug 26, 2008 | Whirlpool Washing Machines
We just installed a new whirlpool front loading duiet sport washer and dryer , It keeps going off balance it was installed by the store . we have had the service man out twice now , he is no help at all....
floor may not be as solid as you think.remove pedistal drawers make sure the screws holding pedistal to washer are tight 2 front and 2 back going into bottom of washer frame next adj legs so bottom of pedistal is as close to the floor as possible you may have to lossen the lock nuts to do this next try rocking the unit by hand and adj front legs as needed to stop motion and and give washer a solid feel retighten lock nuts up to bottom of pedistal
May 05, 2008 | Washing Machines
I want to mount my frontloading clothes washer on a pedistal, but it is too heavy to work with. I would like to remove the counter weigh so that I can lift it more easily.How do I remove the front cover...
NO NO NO dont remove the counter weights. get some help, you need to lay machine over and install the pedistal under machine first, then stand the machine up CAREFULLY lay machine over on back
Mar 18, 2008 | Washing Machines
Lg washing machine pedistals
You will have to have the washer lifted to screw the leg back into the bottom. As far as the shaking...try some vibration isolation pads. www.keshakeaway.com the best $30 i have ever spent.I have a front loader on a pedestal also..it vibrated the pictures of the wall in the next room. with the pads I hardly know its running.( and the drawer stays shut)
Nov 10, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
383 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
