Question about Kenmore 62622 Microwave Oven
Microwave KENMORE code error F6
Kenmore Microwave Model #665 61622100 I'm getting an error message F6. I had to plug off because does not stop
  • 25 Answers
F6 is a relay failure
Posted on Jan 14, 2009
  • NickNC100 Sep 03, 2011
    Just slap or whack the side of the microwave nearest the control panel -- works on both Kenmore and Whirlpool microwaves. That's what did the trick to fix mine. After the "whacking" is done, you may see a colon appear on the display. Just press the cancel button then reset the clock.
  • Geoff Smith
    Geoff Smith Dec 30, 2017
    It worked for me I was shocked that it was that easy of a fix. Thank you so much for sharing that info. May God bless you!
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
What does an F6 error code mean?
The F6 message is an error code that indicates the microwave relay has failed. This is an internal component that will require service.
May 10, 2015 | Kenmore 69682 Microwave Oven
ERROR CODE F6 SOUNDS LIKE IT RUNNING. UNPLUGGED IT AND PLUGGED IT IN AND WHEN I SHUT THE DOOR SAME OLE
Hello lyle,
The reason your microwave comes up with the error code f6 is simply because there is a shortened key, also know as a bad relay. I bet you have a kenmore microwave oven there.
It will act like it is about to start working, sometimes, the tray would roll inside the oven, but will not work.
You need to check wiring to relay 4903 for short circuit, then correct the short circuits you seen.
Hope this helped you.
All the best.
Elect_Comp
Dec 12, 2011 | Microwave Ovens
Getting an "F6" error on
HELLO.
An F6 error code typically indicates a controlpanel problem. Disconnect power and wait several minutes before plugging itback in. If the F6 error code comes back within a minute of restoring power,the control switch pulse return line is not connected properly. This willgenerally require professional repair.
Thanks.
Sep 21, 2011 | Kenmore Microwave Ovens
Error message
The F6 error code on your microwave oven is a relay failure.
Check wiring to relay 4903 for short circuits. If wiring is OK - replace the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 14, 2009 | Kenmore 61701 Microwave Oven
Error code d kenmore model 665.60654 microwave
The letter "d" is indicating the microwave is in a demo/learning feature.
To cancel the "demo" mode press and hold "Kitchen Timer" for 5 seconds. Two tones will sound and the small "d" will disappear from the display.
Jun 16, 2009 | Kenmore 60654 Microwave Oven
Kenmore microwave
i fixed by unplugging the microwave with the door open. I plugged it back in and the F6 was gone. I was then able to set the clock and turn the light on/off . When I closed the microwave door, the F6 came back on and the microwave was making a humming noise. I slapped the side of the microwave near the keypad, and the F6 cleared from the readout and the humming stopped. The microwave is working fine now. Don't know why, except maybe slap on the side reset a relay or something. Anyway, I will never by a Sears Kenmore appliance for the rest of my life. The door rattles when you open a close it (like a part inside the door is broken) and this is the second time a fault code has appeared during use. I had GE Profile appliances at my last house, which are more $$ initial cost, but who wants to screw around buying a new microwave every four or five years. I'll happily spend a couple hundred more for the peace of mind and knowing that it will work during Thanksgiving dinner with the family over.
Sep 09, 2008 | Microwave Ovens
Kenmore Microwave hood combo Model # 66569689992 F6 error code?
Dec 08, 2007 | Microwave Ovens
Error code F6
Please post back with your your full model number. It will be three digits, then a dot, then about eight more digits.
Once we have that, we can figure out who made it for Kenmore, then look up the F6 code.
Happy to help.
Dec 04, 2007 | Microwave Ovens
Microwave repair
my kenmore 665 69682992 2000 model was running fine until it stoped while i was defrosting and the display appeared f6 and continues to run, what should i do.
Mike hammoud
8465 berwyn 48127
dearborn heights Mi
313 2829272
Jul 04, 2007 | Kenmore 63792 Microwave Oven
Kenmore 62622 Microwave Oven Logo
1,269 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
