Question about Brother ML-100 Typewriter
Going back to original Line
How do you go back to a previous line after you have pressed the return key? Is it possible?
  • 183 Answers
You grab the platen knob and turn it back up manually
Posted on Jan 14, 2009
How do i change the business name, address and abn on the receipts for a Samsung ER-650
Turn key to "PGM"
Press "7"
From the
LOGO DESC. PROGRAM screen, press "0" to display the PREAMBLE screen:
Using the alpha numeric keyboard overlay, type the first line of the message.
Each line (6 allowed) can be up to 32 characters, although only the last 19 characters you have entered will display. If you make a mistake, press the "BACKSPACE" key to erase the previous character. After you have completed typing the first line, press "ENTER"
to accept the new line and advance to the second line, or press
to return to the LOGO DESC. PROGRAM screen without making any changes.
Thank You
Jan 29, 2015 | Samsung SAM4s ER-650 Cash Register
Returning to a previous typed line
That is a problem with this machine. The platen doesn't have a detent so there are no positive stops. The trick is to note where the typed line lines up with the line on the card holder. With a little practice you will be able to go back to a previous line fairly accurately. Use the idex or code+rev button to make the paper go up and down. Also it's a good idea to check for corrections before hitting the return button.
Apr 11, 2014 | Brother GX-6750 Typewriter
I can not get the PIP to go away and show a normal picture on the TV.
If you have the original remote, press the swap key (PIP location on remote) to return the original picture format. You may also have a cable line in the back of the TV for a second tuner. Check this, and make sure you have a single line for each RF input, including any RCA slide in/out jacks where they may not belong. I have seen this happen many times. You may have to remove all connections and replace carefully. Thanks for asking and show all hands of support!
Aug 13, 2011 | Sony KV-36XBR200 36" TV
I have a Bee3 label maker and I need to know how to change the font size.
1. Press "Style." Thescreen shows "lines." Press"Return." 2. Use arrow key toselect "1 Line" (or "2 lines" of text, etc.). Press "Return." 3. Use arrow key to select"1a," "1b", "1c," or "1d" (text). Press "Return." 4. The screensays "vertical." Arrow down to "END?" Press "Return." Then the screen shows "AREALabel." Press "Return." 5. Type your text. Preview and Print. Call 1-800-622-6312for a reference manual. We can answer any other questions you might have too!
Jan 18, 2011 | Office Equipment & Supplies
I accidentally changed the language on my monitor how do i change it back to original settings
If you need to change the OSD language for the monitor, press Menu (the rest of the buttons will light). Then press Main Menu and select Advanced (it is the second from the bottom) Press Choose and then Select. The line to change the language, go to the second line (from the top), use the Adjust button to scroll through the available languages. Press Back to return to a previous menu; press Menu Off to exit.
If the language change was in the OS of the computer, it will depend on OS. In Windows, the Control Panel is the starting place. Then Clock, Language, and Region. The Region and Language area will have a keyboard language and display language (if multiple languages are installed) tabs in Win7. (The older versions of Windows are similar.)
I hope this helps.
May 12, 2010 | Gateway FPD2275W LCD Monitor
Since internet explorer 7 has been installed on my computer with out my knowledge my tool bar menu can't be found. How do I get it back? No one seems to be able to retrieve it. Tect Support can...
To temporarily display the Menu bar, press <Alt>. Go to View (use your mouse or the right arrow key). Go down to one line to Toolbars and right at that arrow. Click on Menu and get that option check marked (or hit enter if you have been using the arrows). Return to the menu bar which should now be visible and repeat going to the Toolbars list, enable the Command Bar similar to how you did the previous toolbar. Finally repeat the above steps and go down the list a little father and Lock the Toolbars if that line is unchecked. (This eliminates the dotted line next to each toolbar that lets you remove toolbars on the fly from the left side of the window at each line.)
I hope this helps.
(IE 6,7, and 8 have very similar menu items for this but the exact titles might be different.)
Feb 20, 2010 | Dell Inspiron 530s Desktop Computer...
Echo Blower PB-403T will not start. I replaced the air filter, fuel filter and spark plug. The fuel line inside the gas tank had broken off at the top. I reconnected and it still will not start. Previously...
Should be two fuel lines coming from fuel tank grommet. One feeds the carb's primer plate and the other returns from the same. Open the fuel tank and observe while pressing the primer. If you see fuel pumped INTO the tank while pushing the primer and pulled FROM the tank when the primer is released, you're OK. If not, the lines are backward. Filtered line is on SUCTION side of primer bulb. Unfiltered line is on PRESSURE side of primer and is simply a return to the tank.
Next, concerning the coil: Air gap should be .010 inch at the magnet. Echo ignition coils are warrantied for life to the original purchaser, so don't tamper too much with it. Check gap and check fire with a spark tester. If no spark with switch in on position, take it to an AUTHORIZED SERVICING dealer, found here.
Hope this helps,
Oct 15, 2009 | Garden
Brother GX 8250: my problem is with the carriage.
Brother GX8250 typewriter; my problem is with the carriage. The return key returns the carriage to the original left-side position, but fails to advance to the next line.
Sep 08, 2009 | Brother Office Equipment & Supplies
Regional Code
1. Power on,
2. Press "Pause" ||
3. Enter "314159"
4. Press "0" (for region free)
5. Press "Enter"
... the 0 replaces the previous region number in the second line.
6. Press "Pause" ||
7. Power off.
With the unit in DVD mode and the drawer open, key in "0" four times. A two line menu appears with "Edit Region:_" and "Region Code:x". Key in the required region (presumably 0) and press enter. Power off
May 16, 2008 | Televison & Video
Brother ML-100 Typewriter Logo
37 people viewed this question
James Cagle
James Cagle
Jim Keysor
