Question about HP Compaq Presario SR2170NX (RK549AA#ABA) PC Desktop
Have a compaq presario sr2170nx....installed 1 gb memory but not showing up. swapped the memory sticks positions and restarted but still wont show up.
  • 1 more comment
  • dontaylor2 Apr 22, 2009
    I added 1GB of RAM (to the existing 1GB), and the BIOS only sees 1GB. I have tried swapping slots, and running only the new DIMM. The computer does see the new DIMM, but only if it's the only one installed. What's going on?
  • dvankampen Apr 26, 2009
    I have the same problem...just added a 2nd 1 Gbyte PC4200...system only recognizes 1 memory SIMM, regardless of which slot or which chip (new or old)...speed of both chips are the same!
  • thetrooper44 May 11, 2010
    does your computer tell you how much memory it thinks it has..and are the new memory sticks the right speed i presume you know how to check how much memory is installed ;-)
    Master:
  • 413 Answers
If you do not get the right memory for your computer it will not work. the memory you need is listed in the table below. And pay attention to the max amount of ram. Your system can only hold 2 gig and it comes with one gig installed
Component Attributes Memory Installed 1 GB Maximum allowed 2 GB (2 x 1 GB) Speed supported PC2-4200 MB/sec Type 240 pin, DDR2 SDRAM
Posted on Jan 14, 2009
  • Dan rogers
    Dan rogers Jan 14, 2009
    the speed is what you are paying attention to. I found this information at http://h10025.www1.hp.com/ewfrf/wc/docum...
    this page also tells you the rest of the specifications for any other upgrades you might want to do to your computer. Let me know if the link doesn't work of you need more help. And please don't forget to rate this response
Video wont show
This would be caused by several things.
1) bad power supply causing the computer not to start
2) bad video card
3) bad monitor (does the monitor light come on?)
4) other component bad--disconnect them all except the CPU, memory, and video card and see if you get an image.
Feb 28, 2012 | HP Compaq Presario SR5210NX Desktop PC...
Compaq presario cq57 PCI drivers
Use a computer with Internet access to download the drivers and then copy them to an USB memory stick. You then insert the USB memory stick inti your Compaq and install the drivers.
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
www.compaq.com/country/cpq_support.html
Feb 23, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
INSTALLED NEW RAM UPGRADE TO BOOST FROM 1G TO 2G COMPUTER DOES NOT RECOGNIZE NEW RAM STILL SHOWS 1G.
Make sure it is the correct ram for your computer. If you just added one ram chip then try swapping them and make sure they have a tight fit.
To test the new chip replace the old one with it and turn on your machine. If it doesn't see it then it is either bad or not the correct one.
Let me know how it goes.
Dec 14, 2010 | HP Compaq Presario SR2170NX (RK549AA#ABA)...
HOW TO OPEN THE TOWER CASE OF THE COMPAQ PRESARIO SR2170NX TO ADD MORE MEMORY
This is how to open the tower case of the Compaq Presario SR2170NX:
John
Jun 26, 2010 | Compaq Computers & Internet
Bsod when adding 1gb of ram to my compaq 2200 laptop
jayson30
In regards to the memory issue the problem is that your notebook only support 1gb of memory so you will have to split it between 2 512 sticks as that is the max the computer can handle. This is why the system blue screens with the 1bg stick.
Let me know if you have any more problems or questions
Issken
Mar 04, 2010 | HP Compaq Presario 2200 Notebook
Will compaq presario v2000 support windows 7
If you want to run Windows 7 on your PC, here's what it takes:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
Nov 04, 2009 | HP Compaq Presario V2000 Notebook
Mixing Memory
You can't install two RAMs with different MHz on a single motherboard. Sometimes it works but, usually one of the RAM gets busted. This is based on my experience though.
Sep 24, 2009 | Computers & Internet
Upgradw memory for compaq 2190US
Memory Max 1024 MB DDR SDRAM (2 x 512 MB)
that what it says so its up to u but i think u just should not take the risk!!
by the way dont forget rating me
Aug 16, 2008 | Compaq Presario 12XL125 Notebook
Memory problems
im unsure whats wrong but run the disks that came with ur pc to repair windows. that shud fix it
Jan 23, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
HP Compaq Presario SR2170NX (RK549AA#ABA) PC Desktop Logo
350 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
