Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
Lost wireless connection
Yesterday, all of a sudden, I lost my wireless connection and all the troubleshooting hasn't repaired it. Please advise.
  • Anonymous Jan 20, 2009
    I cannot access the internet nor send/receive e-mails.
    Problem Solver:
  • 13 Answers
Try unplugging the router. then plug it back in (the power that is)
Posted on Feb 04, 2009
Hi I have a e systems laptop on windows xp and yesterday it all of a sudden lost the wireless connection and now it will not find it I no it's not the Internet as I have my phone and ps3 connected no...
Check the following command... Open the run box and type cmd and hit ok.
Now type as ping www.Google. Com and hit enter
Ishould respond with packets sent received, sent and lost
Check the lost packets and it should be zero
If found another contact ISP
Mar 26, 2014 | Computers & Internet
My HTC Wildfire was connected to Optus 3G but I suddenly lost the connection a few weeks ago. I need to reset the APN. Can anyone please advise settings. Thank you.
Reset APN Settings Back to Default - HTC Wildfire S
  1. Tap the Menu key
  2. Tap Settings
  3. Tap Wireless & networks
  4. Tap Mobile networks
  5. Tap Access Point Names
Note: If you are still having issues with data connection please ensure mobile data is enabled, see Enable or Disable 3G Data Connection for more information
Aug 29, 2013 | HTC Wildfire
Wi fi adapter all of the suddenly cant connect
There are several possibilities, but without some details I can only guess what's going on. I'm going to assume the problem is on a home network and you're using a current version of Windows in hopes of sending you some quick help, but if those are bad assumptions, please send details.
You can run Windows wireless diagnostics by clicking on the icon that looks like cell phone bars at the lower right hand corner of your screen. Next choose Open Network and Sharing Center, then Troubleshoot problems. That process may solve the problem or it may make a suggestion on your next step.
You might turn off your cable or DSL modem, and then turn it on again.
If you're using a laptop, you might check to see whether there's a wireless radio switch that has been accidentally turned off.
You might restart your PC.
I'm guessing that you know the WiFi hotspot you're connecting to hasn't changed its security settings or name. However, if someone else manages the WiFi network you're connecting to, ask that person if they've made changes.
These should address the most likely culprits. If not, please send info about your computer, your network, whether you can access the Internet outside of your web browser (e.g. can you get email in Outlook), and what you've tried so far.
A wonky PC is the pits. Best wishes on quickly getting it going again.
Jun 01, 2012 | Addlogix MaWlUsbN150x IEEE 80211n Draft...
Dell Latitude D 410 has suddenly (worked yesterday) stopped connecting to all known (and working) wireless networks. Is my internal wireless card gone?
If you get a 'Limited connectivity" on you wirelessconnection on your laptop, it means that the wireless card on your laptopprobably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and thenclick Repair.
This will force the wireless router to issue a IP address to the wireless cardon the laptop.
Apr 13, 2012 | Dell Latitude D410 Notebook
Windows cannot connect to the wireless network
I would remove old cache wireless network connections. Example is when you once connect to a free wireless access at Library or Coffee Shop. Windows save all of these profiles and this will cause problems connecting. Then use Microsoft Wireless Troubleshooting resource:
http://windows.microsoft.com/en-US/windows-vista/Troubleshoot-problems-finding-wireless-networks
Good luck
Dec 30, 2009 | Intel PRO/Wireless 3945ABG Network...
Wireless Router suddenly stopped working.
Try resetting the Linksys back to the factory defaults and configure it again.
Power up the router and press the pinhole RESET button on the back of the router for 30 sec
Connect a LAN cable to the wireless router and open a browser and enter to router's configuration IP address and configure the wireless settings, remove the LAN cable when configuration is completed.
You need to configure then wireless card in the computer/laptop with the router's wireless settings.
Dec 10, 2009 | Linksys Wireless-G Broadband Router
No wireless networks found in range
Are all the LEDs on the wireless router are on?
When you reset the wireless router wait at least 1/2 min before powering the router up.
Right click on the wireless connection and click on Repair, this will force the wireless router to issue a new IP address to the wireless card. If the the red x is still on the wireless conection then :-
To check if the wireless card can communicate with the wireless router, ping the IP address of the wireless router, (this is the IP address that is used to login and configure the wireless router) if you get no reply and all packets are lost, then connect a network cable from the laptop's RJ45 port to the wireless router's RJ45 port and do the ping test again.
If you still get no reply and lost packets then most likely you have a faulty wireless router.
Get back to me on the results of the tests and I can then advise what to do next.
Jul 16, 2009 | Dell Inspiron 9100 Notebook
HP Wireless Assistant
mmm a mystery...
are you part of a network or adhoc are others able to connect to ur pc.
you could download the drivers and reinstall them and if spyware doctor and win defender are registered you can always retrieve them.
after doing this I would consider installing norton antivirus or norton 360..I use norton 360 on all my machines.
Jan 14, 2009 | HP Pavilion dv4000 Notebook
Connect to wireless
here you get the manual sir:
ftp://ftp.dlink.se/Products/di-products/di-524/Documentation/DI-524_manual.pdf -
or
www.amazon.com/D-Link-DI-524-Wireless-Router-802-11g/dp/B0001PFQ08 - 256k -
or
reviews.cnet.com/routers/d-link-di-524/4505-3319_7-30839580.html - 79k -
thanking you
Jul 09, 2008 | D-Link AirPlus DI-524 Wireless Router
Belkin/problem with connection
you tried turning it off and then back on the router, sometimes they just need to reacquire the ip
Dec 22, 2007 | Belkin (F5D7633UK4A) Wireless Router
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
117 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
