Question about Bosch 24 in. SHU43 Built-in Dishwasher
Problems with my bosch dishwasher
Every time i add salt to m dish washer, its full and is setfor programme number 1. In the middle of the wahs the salt light appears to show it is empty, and after finishing the load all my utensils are not cleaned and have a salty appearance on items. On opening the salt compartment, it is completly and i have filled it with almost 3 bags of finish dishwasher salt. I have enough conditioner(rinse aid), the light is fine for that. Please can you help me thanks jayanil
  • Anonymous Mar 21, 2014
    where does the salt go
    Sergeant:
  • 236 Answers
There should be no salt getting into the wash cavity. if you are sure that it is leaving salty water on the items then either the salt cap is loose/damaged or the regeration system is faulty-this is an expensive fix.
Posted on Jun 16, 2007
Paul uses 212 teaspoons of salt in each bowl of salad. How many teaspoons of salt will he need to prepare 5 bowls of salad?
Oh come on, that is so easy. Get a calculator, and multiply 212 x 5. The answer is?
Or add up this column of figures starting with the right hand column, carry the 1, add up the middle column, add the 1. Add up the left column.
212
212
212
212
212
And incidentally, as a professional chef, that is FAR TOO MUCH salt unless the salad bowl is the size of 4 baths!
212 grams would do a garbage can full.
Mar 23, 2017 | Kitchen Appliances - Others
Why are dishes clean but still seem to be greasy?
hi,you can take off the washers that spin and clean them ( sometimes the holes get blocked on them ) also make sure you have salt in the machine and rinse aid
Apr 24, 2015 | Dishwashers
Built in water softener
really don't know have you got the manual. Normally you have to test the water ph level and then adjust the dish washer to that ph level and then fill the salt reservoir. Not sure on your model of dish washer . However you could add a water softener to the water inlet to the dish washer . Just search for
Water softener device
see
http://www.uvguard.com/hwc-home-series/
Oct 29, 2017 | Magic Chef CDB6100 Built-in Dishwasher
Cloudy dishes
cloudy dishes, white generally means an overdose of salt in the dishwasher, try turning down the salt setting usually set to 4 from factory
Oct 24, 2012 | Bosch Dishwashers
Where do i put the salt
Hello Maria,
The salt goes in the salt compartment in the base of the washing compartment. Unscrew the lid of the salt compartment (counter-clockwise), pour in salt until the compatment is full or nearly full then screw the lid back on firmly, but do not overtighten it.
If the dishwasher is new and you are using it for the first time, pour about 1 litre of cold clean water into the salt compartment before adding the salt. If you spill any salt or the water spills over the top of the salt compartment, it will wash/drain away the next time you use the washer.
The most important thing is to only use dishwasher salt. The salt is used for water-softening and only salt sold specifically for dishwashers can be used for this purpose.
The picture above is from a Bosch dishwasher. You may have another brand or model of dishwasher, but the salt compartment will still be in the base of the washing compartment and will have a cap which you unscrew as above.
Hope this helps. If you need further assistance, please let me know the brand and model number of your dishwasher.
Regards,
BElectric
Mar 14, 2011 | Dishwashers
I cannot get my smeg dishwasher to programme the salt container light is on i have put salt in the dispenser but it is not full will that stop it from working
It is possible that water has gone into the salt container or the salt container sensor is faulty.
It might help find a possible cause if you proivde the full model number of dishwasher
Mar 13, 2011 | Dishwashers
Just moved into a house with fitted NEFF dishwasher, never had one before and no manual left. Where do salts go? Thanks
The salt goes in the salt compartment in the base of the dishwasher. Open the door and pull the lower basket out. You should then be able to see a cap near the front-left corner of the base of the dishwasher. Unscrew this cap (anti-clockwise) and fill the compartment with salt all the way to the top - or with as much salt as you have in the packet - then screw the cap back on firmly, but do not over-tighten it. The salt compartment will (or should!) be full of water and some will spill out as you fill it with salt. This is totally normal and not indicative of any problem.
Do not use any type of salt which is not sold specifically for dishwashers. The dishwasher can be used without salt but it is not advised and may result in a white film being left on your cutlery, glassware and/or dishes.
It may also be possible to provide a user manual in PDF format which you can download, but I would need to know the model number. If you don't know the model number Most Neff/Bosch dishwashers have the model number laser-etched into the stainless-steel at the top of the inner-door or the rim of the washing compartment. Please click on the link below for a guide to locating the model number of your dishwasher. (Neff is a Bosch owned brand)
http://www.bosch-home.co.uk/type-plate-details.html?aftersales=dishwashing&aftersales=dishwashers~16468
Hope this helps. Please let me know if you would like the manual or need further assistance.
Regards,
BElectric
Feb 28, 2011 | Neff S5946 Built-In Dishwasher
The cycle has finished and the dry light is on and it keeps beeping. Usually it beeps 8 times then all lights go off and cycle is finished. i ahev just filled it with salt but this has never happened...
ok why whoud you put salt in dish washer you screwed it up from doing that the salt sweld up and cloged the sencer the sencer is your intake and your intake takes water in out clean out with dish soap 1 or twice with mild water mixed with dish soap[
Feb 15, 2011 | Dishwashers
Bosch 24 in. SHU43 Built-in Dishwasher Logo
897 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
