Question about Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis top load always out of balance and bangs
Customer advised that while spinning her washer (Oasis) bangs and goes out of balance. Is there any fix to this problem? It is causing clothes not to spin out properly.
  • lesf115 Jan 15, 2009
    Hey duby1990 it has a newtator and I thank you for all your help.
  • Justin Duby
    Justin Duby May 11, 2010
    Does it have an agitator or a newtator?
  • 370 Answers
First just to let you know, the oasis is very sensitive to the load level and water ratio if its too heavy the load has to be perfectly balanced inside the tub. Next check to see if any of the straps are broke. The next thing is that the newtator has tighted up all on its own so when it spins the newtator grabs the tub while it spins at high speed. I have never had to fix this but i know it is a common problem. I hope i helped a little. Good luck!
Posted on Jan 19, 2009
My oasis washer when it goes into its last spin it shakes so bad it shuts off
sounds like unbalance load. if it happens alot u may have bad counter weights or bad suspension rods, another solution may be its just not properly adjusted legs to balance machine, check with leveler ad see its its even all around
Oct 18, 2014 | Kenmore Oasis HE 27082 Top Load Washer
Washer goes thru cycle ok untill spin cycle gets error code out of balance, but machine not out of balance
That is not to say that the drum is not out of balance. Try running it empty and see if it happens.
Aug 09, 2013 | Kenmore Elite Oasis 27052 Top Load Washer
When washer goes into spin cycle it starts to tub starts to bang against side walls and shortly after error out, with an error on electronic display. Kenmore Elite Oasis
either unit is unlevel or one of the tub supports has come disconnected .... these washers have a slanted top lid so you must put level at side of washer on front and both sides and check front to back with level at side cabine seam as your leveling point
Jan 24, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Constantly off balance
I have a kenmore elite oasis top loading washer about 3 years old. I took it apart and checked the springs and the rods and the plastic ends that hold the rods in place and all of them look fine. I run an empty load in the washer and it still goes unbalanced on the spin cycle. My water bill has tripled due to the fact that every load takes 3 to 4 washings. I need help please!
Jan 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Spin cycle goes out of balance even when empty.
The stem is bent or fractured or the bearing is shot. This is a rebuild job for a techo.
Oct 20, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis becomes unbalanced all the time
Its a tricky repair. there is a spring that sits on the base of the motor. You need to remove the pulley and plastic gears to gain access. This spring is slipping causing drum not to spin correctly. Remove it and clean properly with solvent . If broken replace. Reinstall and retry.
Sep 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Oasis he washer,,keeps saying ul .
Uneven Load.
The sensor should be checked for proper operation, and the vibration dampers too.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Spin cycle noise problems
It is likely that you have an unbalanced load. Try spinning the machine with only water in it. If there are no noises now, you will need to re-distribute the load. We clothes are heavy!!
Jan 13, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
599 people viewed this question
Sal De
fordexpert
Robert Rankin
